Daniels Blue 182
They look like beasty top mounts :) if only they did those for the Fabia :)
  • Replies 282
  • Views 28.8k
  • Got my wheels back from the powder coaters, £90 all in at Cas coatings in bradford
  • Well today I bit the bullet. It was already half getting there so decided to just go for it.   It's mad how much this weighs and adds up!   20160710_134952 by dann2707, on Flickr   20160710_14
  • Thanks mate. All lacquered!   Really pleased with them for a rattle can job. I don't expect them to last forever / be super durable but they've got to be better than this...     DSCN2074 by dann270
Found the source of my problems! Fingers crossed anyway
But basically I identified that the n/s bearing was totally gone when wobbling the wheel at 12 and 6 oclock positions, clonking loads and just really sloppy compared to the offside.
15444840280_53a11a61e2_b.jpg20141025_112620 by dann2707, on Flickr
There is a lip on the bearing carrier. Picture doesn't really show it but running my finger along that shaft (:D) shows a big lip. I'm not exactly sure how long it's been like that. When I first got the car the bearing was loose so maybe tightening and loosening, tightening again has worn away some of that material.
The new bearing is still sat in my bedroom as I am just using the one that came with the replacement hub that I bought yesterday. I'm not sure whether to just run this one into the ground or replace it anyway seeing as though I have it here anyway.
The replacement bearing is on and i'm fairly certain I didn't hear a single clunk when changing gear but I only had a 1 minute drive to the shops.
Hows the top mounts?
Bit of an update. From the very first day of owning the car I noticed a few imperfections with the paintwork that have constantly niggled at me. These being:
• both wing mirrors have scuffing on the edges from where the previous owner looks to have tried to fit down a spot they can't make. Along with the offside wing mirror having a crack in it and the nearside having specs in the paint
• offside trims have one scuff on them each as shown!
15633846862_7761b32938_b.jpg20141026_103541 by dann2707, on Flickr
15446368649_570380718d_b.jpg20141026_103548 by dann2707, on Flickr
15609182176_41a367008e_b.jpg20141026_103606 by dann2707, on Flickr
15446789968_14e7a1596b_b.jpg20141026_103611 by dann2707, on Flickr
15012752923_d3659a3bdc_b.jpg20141026_103617 by dann2707, on Flickr
15446817988_6fcb4ae745_b.jpg20141026_103621 by dann2707, on Flickr
So I ordered some wing mirrors and side trims and started to spray them up over a week.
The final finish on them wasn't too great but I knew that i'd be able to get them looking fairly decent with some 2000 wet and dry, the machine polisher and some megs #205 cutting compound. Just a finishing polish as not much cutting would be required!
This was after spraying
15630293471_ea3e71c2d5_b.jpg20141026_103757 by dann2707, on Flickr
15633808522_dbc6f374c1_b.jpg20141026_103812 by dann2707, on Flickr
I then started flatting them back with the P2000
15446901238_50407dbd24_b.jpg20141026_105728 by dann2707, on Flickr
And removed the old trim off and cleaned behind it (after this pic)
15632987765_6d623dda2d_b.jpg20141026_110503 by dann2707, on Flickr
I then put the new trim on and polished it
15447447600_d3d9381506_b.jpg20141026_111101 by dann2707, on Flickr
Much better
15609276496_4c68f49b56_b.jpg20141026_111130 by dann2707, on Flickr
Same for the front
15633873022_c9a208981f_b.jpg20141026_112057 by dann2707, on Flickr
This shows a 75/25 shot of it being polished and just flatted back. Difference is unreal
15447459180_e48dcddd5d_b.jpg20141026_113547 by dann2707, on Flickr
Close up after the polishing, so happy to say it was just done with rattle cans :D
15632998825_07c656fb3d_b.jpg20141026_113600 by dann2707, on Flickr
15630383561_c9402d6e35_b.jpg20141026_113610 by dann2707, on Flickr
Both trims now on and polished
15447481660_68e6541000_b.jpg20141026_114321 by dann2707, on Flickr
15012906793_cd9685d155_b.jpg20141026_114328 by dann2707, on Flickr
Wing mirror caps also on too. Same process as the side trims
15012926663_4b465aff6e_b.jpg20141026_114338 by dann2707, on Flickr
15012245614_9b0195569d_b.jpg20141026_114353 by dann2707, on Flickr
Edited by Dann2707
I then gave her a wash :)
15630445291_2f1cbe8abd_b.jpg20141026_121044 by dann2707, on Flickr
No more scratched trim! Gave it two coats of collinite #915
15630454231_3122ac480a_b.jpg20141026_122510 by dann2707, on Flickr
I then dressed the plastics and the tyres and took a few more pics
15633146195_a279faa6e3_b.jpg20141026_133219 by dann2707, on Flickr
15630483561_aba6245fd4_b.jpg20141026_133224 by dann2707, on Flickr
15633997882_1a20562b04_b.jpg20141026_133233 by dann2707, on Flickr
So high at the front ughh
15633168195_2c3aca73a8_b.jpg20141026_133240 by dann2707, on Flickr
My favourite picture I think
15447609580_5f65b9551f_b.jpg20141026_133328 by dann2707, on Flickr
15609519166_26e0a6a0b6_b.jpg20141026_150124 by dann2707, on Flickr
I'm nearing the end of my Collinite #915. I've had this for 5 years now haha
15446560119_20ee8b9ef6_b.jpg20141026_133410 by dann2707, on Flickr
Then gave the interior a clean seeing as though I hadn't done it for a few weeks
15609290816_03c3f87708_b.jpg20141026_150029 by dann2707, on Flickr
I had a further play with photoshop :D and I'm pretty much dead set on this now.
I've darkened the side bullets, lowered and put the headlight washer blanks on.
Before:
After:
What are people's thoughts?
I prefer the trophy nose down stance.
Before:
After:
Looks great but then I'm biased about Clios. Coming to FCS 2015?
What is FCS matey?
What is FCS matey?
French Car Show its £20 for the ClioSport club stand ticket.
I do like these, ended up driving to Wales so my friend could pick up a track ready 172, had a bit of a play with it on the drive back, what a cracking little car to drive...Total different kettle of fish to the Bluemotion Polo I ended up driving back from Wales to Hampshire!
I lowered the car yesterday thanks to a kind member on Cliosport giving me some front eibach sportlines :D
15703320765_5654ddfe81_b.jpg2014-11-03_07-55-47 by dann2707, on Flickr
Seems to have levelled it out a bit compared to what it was like before
It's just a stop gap until I get my coilovers xmas time :D
I got a few parcels through in the post :D But I forgot to take a pic of the other one, but it's a spoiler!! And the other is a ramair induction kit. Thread on Cliosport showed a guy doing a before run on a RR and after with it on and gaining 10bhp. All for £37?!
15732880471_a05cc11dd8_b.jpg20141107_195942 by dann2707, on Flickr
15734804385_462ce126f0_b.jpg20141107_201200 by dann2707, on Flickr
Had some wine to keep me going after a stupidly long day at work
15549351398_664e8f75ea_b.jpg20141107_201217 by dann2707, on Flickr
Original airbox
15736341462_67ca931ea9_b.jpg20141107_201229 by dann2707, on Flickr
Removed
15732867571_e23997e679_b.jpg20141107_201658 by dann2707, on Flickr
New induction kit in
15736334482_2eea7c9be2_b.jpg20141107_202830 by dann2707, on Flickr
15734787415_e28739f486_b.jpg20141107_202844 by dann2707, on Flickr
I also replaced my centre exhaust hanger as that had snapped.
15114825414_19ccb83772_b.jpg20141107_204745 by dann2707, on Flickr
Block of wood and widowmaker to lift up the exhaust and put in the new hanger
15549947450_e6186388ec_b.jpg20141107_205900 by dann2707, on Flickr
15114808774_568f08de7b_b.jpg20141107_210051 by dann2707, on Flickr
Lovely :D
Here is a video of the induction kit
I saw the induction kit thread, really wanting a sport now ;)
Was on track with a turbo'd 172 today, he paid £500 for the parts mostly second hand on a low boost ~260bhp set up.
Crazy wheel spinning machine lol
Today I started stripping the spoiler of its paint. Paint stripper doesn't seem to be doing much so I might have to get the heat gun on it.
15716935036_35b9cbc66f_b.jpg20141108_115122 by dann2707, on Flickr
The spoiler is in great condition bar a few chips and a scratch however it is the wrong shade of colour as it's from a 172 so isn't arctic blue. Not a problem.
15121256193_75076b7c4a_b.jpg20141108_114537 by dann2707, on Flickr
I then went for a drive and i'm really starting to get a bit weird about where I park in order not to get door dings :( haha Parked like this and crawled over into the passenger side to get out lol. This is it in a different location as opposed to my driveway like every other shot is haha
15120689484_de31e96e3b_b.jpg20141108_155208 by dann2707, on Flickr
15121236783_f19da59c6c_b.jpg20141108_155214 by dann2707, on Flickr
Thanks for reading.
OOOOOh one thing I forgot, to day I changed the wishbone bushes to new ones just because really. The old ones look standard, not much play but I thought whilst i'm refreshing the suspension parts i'll do it. No pics though as it was chucking it down whilst I was doing it.
Heres the vid of induction kit driving btw.
I bought a cup spoiler, and messed up the spraying so sold that for a tidy £30 profit (accidently) haha!! so i've ordered a Clio V6 spoiler for the rear :D :D
But anyway a little update:
This is a pretty common mod to do but easily one of the best value for money mods. RS197 badge :D Tidies the back end up so much!
Before:
15812347326_ebae35e37c_b.jpg20141120_184822 by dann2707, on Flickr
After:
15650184429_8608da948e_b.jpg20141120_194025 by dann2707, on Flickr
I like this car so much. Jealous
Love the video driving with your Mrs kicking off. Mine does the same!
Hahahaha that's my Mum!!
My Mrs is the opposite! We were driving a few weeks ago going to a bonfire in Leeds and there was another clio 182 infront and she was egging me on to overtake him. Properly shocked me as she's not like that normally haha loved it.
Edited by Dann2707
Haha wow. I've had a nightmare there!!
Cracking car by the way, you've done a great job. Especially like the detailing but that's because I'm biased.
Me too, the shot of you hitting the bottom of a tin of 915 (after 5 years) should put a lot of us on here, me included, to shame with our purchasing antics.
Dan, how do you fancy a meet up before Christmas, I have a weird noise in the Superb when setting off in the Superb which I can't tell if it is related to Clutch/Fywheel or the haldex drivetrain.
I figure as you are mechnicaly gifted you can perhaps help me diagnose and fix and i can hook you up with a replacement for the Collinite?  Let me know bud.
Hey man, thanks for the comment :D That sounds really good!! I can't promise i'll be able to diagnose it but it would be great to meet you too, maybe we could make it a detailing day?
Anyway, my largish update is here albeit not finished in anyway shape or form.
The V6 rep spoiler from Italy arrived. I ordered it Tuesday and it came Friday. Can't believe how quickly it arrived to be honest!!
Looks like a great addition to my bed lol
15665843139_a7e0ebe5ac_b.jpg20141122_121137 by dann2707, on Flickr
To my surprise it came with bolts and the new rear screen washer and pipe and also fitting instructions!
15232210353_1919064ebb_b.jpg20141122_121238 by dann2707, on Flickr
15232214803_3c26fed9a4_b.jpg20141122_121242 by dann2707, on Flickr
The underside
15666108187_bbf6ebb1ed_b.jpg20141122_121337 by dann2707, on Flickr
The topside
15826058856_c31a8da30a_b.jpg20141122_121348 by dann2707, on Flickr
This is where the brake light goes, the little dimple to the right (might even call it an inverted nipple for the lols) is the location of where you are to drill a pilot hole for the brake light. It's there for a reason.
15666116787_3a6f1f0ae1_b.jpg20141122_121419 by dann2707, on Flickr
And the bigger cavity is for the brake light connector to fit through, this was filed down so that my brake light fit through.
15229613894_1f18a2cf0f_b.jpg20141122_121422 by dann2707, on Flickr
My new windscreen wipers came. They're genuine Bosch flat ones which I got from the bay
Before:
15229618304_fd88bd94a6_b.jpg20141122_122220 by dann2707, on Flickr
After:
15851907805_855f560fd9_b.jpg20141122_122433 by dann2707, on Flickr
I then started removing the old spoiler to test fit the new one before painting. Spoiler off!
15232248383_73ea7a0e6f_b.jpg20141122_123444 by dann2707, on Flickr
Fitted my original brake light.
15664336418_57edac26f3_b.jpg20141122_125631 by dann2707, on Flickr
And on the car. I didn't do it up tight so it looks like it doesn't fit flush but the bolts are on baby tight. Reason for doing this is just to make sure everything lines up correctly as i'm not going to want to faff around marking and drilling new holes once it's been painted. Good job I did this.. later pics will show.
15665893059_c4108c495b_b.jpg20141122_131014 by dann2707, on Flickr
15232259363_cde02ce7ff_b.jpg20141122_131021 by dann2707, on Flickr
15665905029_7e8286d055_b.jpg20141122_131033 by dann2707, on Flickr
15232270083_8648840933_b.jpg20141122_131037 by dann2707, on Flickr
15664411928_4bcf1b9a2c_b.jpg20141122_131044 by dann2707, on Flickr
The best thing about it is that it doesn't catch the roof like the proper renault V6 spoiler does which requires shorter boot struts, the final price of the renault spoiler and boot struts comes to £515!! :o
15826113346_2f40eaa471_b.jpg20141122_131100 by dann2707, on Flickr
15665922329_3b0d7ee5fe_b.jpg20141122_131103 by dann2707, on Flickr
And my biggest complaint with the spoiler is that the middle two bolt holes do not line up with the cars original holes. Not an issue as i'll just mark and drill new holes there but still, you'd think they'd line up.
15666174097_62bb881b2e_b.jpg20141122_131130 by dann2707, on Flickr
15851856455_ed56c3f389_b.jpg20141122_131134 by dann2707, on Flickr
Overall i'm impressed with the spoiler for the price I paid £73. The quality of it isn't fantastic due to it being fibreglass and having a few manufacturing marks but i'm sure once i've sanded it down, keying it for paint it will look great.
Really happy with it and I think it's going to transform the rear end completely. Thanks for reading
First coat of paint is on. It's turned out much better than the Cup spoiler!!
15859350031_1e8d5e0b83_b.jpg20141123_182823 by dann2707, on Flickr
The rest of the coats will be going on tonight too.
