2005 Frozen White Fabia VRS
Is it alive again :)
This Saturday should see ignition live again! Then time for it's MOT and some body work to be touched up before Snetterton if all goes according to plan. :D
  • Replies 247
  • Views 28.8k
Woohoo
She lives again!! Still some work to do to get her road worthy but coming along nicely.
Treading water but looking promising..ish for Snetterton. Still a little more work to do but major thanks must go to Taylor and Danny for being excellent with the tools. Majorly nice to have a set off ramps to do some work on as this makes life a LOT easier.
Such a shame about yesterday after all the work that's gone into it recently. Small issue to overcome and it will be boosting its way round track.
Two cars.. one with a broken engine and one with a very good engine.
If anyone can tell me what "You must enter a post" means when trying to put a picture up I'd be extremely grateful. I've done it a fair few times by now... yet tonight the system hates me.
Can't see it on my mobile but are you freedom? Might have met your limit
Sent from my SM-G920F using Tapatalk
Nope definitely Freedom. :)
Ooh dunno then :/
Ooh dunno then :/
Thanks anyway. Already had an argument with Photobucket when it wouldn't upload multiple pictures... until I checked the library and found I have 5 of each... sometimes more...
Thanks Danny, I think I'll send you the rest of the photos to put up LOL!
Wow so you'll now be kicking out a lot of power with that engine/ turbo :)
What are you doing with the black Fabia? Is the passenger side wing straight? Mines got a bit of a dent in it.
Good to see it back
That picture of Taylor in the engine bay is class.
Nice work guys.
The black Fabia is having another engine put in with PD150 and will be a daily hack. Circa 200bhp economy mode. :)
Shame i forgot to change the MAP sensors over so when it made it to snet it wouldnt boost properly. I hope you got that sorted in the end steve
Looks good. One weekend danny wasnt able to make it and i had quite a few sump related problems (trying to repair a stripped thread on the sump plug) then a replacement sump that was actually from an octavia wouldnt fit and finally we sourced a Fabia ASZ one which was quite stressful but with a late finish I did get it sorted in the end.
Hope its all running well steve.
Edited by Taylor93
Nice work guys.
TDI - Taylor D Inside :D
Good effort, but did the whole engine take a poo poo, or was it just the turbo? :)
The top end needed a rebuild and the bottom end most likely suffered wear so wasn't worth preserving. Turbo had quite literally split in two where the bottom bolt hadn't been put back on when they fitted the rebuilt hybrid...
Yes I took it to Unit 18 who cured it in about an hour. Turned out to be a vac hose/N75 issue which they sorted post haste.
We did swap over the MAP sensor in the early hours before Snetterton but unfortunately wasn't that, hence my lovely unforgettable road trip up there with no boost. And back.. which sucked as equally if not more.
Now running very well Taylor, just need to remember how to drive it now. And get used to the OMP steering wheel which leaves you miles from the switches lol.
Ouch. :( hope it's awesome now done though
