VCDS fault - 1048578 No Basic Setting
VCDS scan shows a fault in the "Instruments" control unit. Details are give below
Vehicle details :- Skoda Octavia -3 , 2L TDI
   Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 5E0 920 861 D    HW: 5E0 920 861 D
   Component: KOMBI         233 2210
   Coding: 27A502002080000801082A00000000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_SK37.rod
   VCID: 285988E25384715EF3D-807D
1 Fault Found:
1048578 - No Basic Setting
          B2010 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 206
                    Mileage: 14557 km
                    Date: 2014.09.29
                    Time: 15:46:40
In some sites it is mentioned as if the fuel lines are flushed (yes it was flushed at 14557km during the 1st service to change fuel filter) then need to provide the basic settings again but no info on how to do it. Experts please help.
Edited by B747
Which software version of VCDS are you using?
I am using 12.12.3.
In the fault details mileage is mentioned as 14557km and it is exactly during this time 1st service was done and fuel filter got replaced, so I am suspecting it is something to do with it.
Replacing a fuel filter should not upset the instrument cluster.
I did find this though, but it does not mention the procedure to recalibrate the fuel gauge and on this thread they left the fault present as everything was working.
http://www.vwaudiforum.co.uk/forum/archive/index.php/t-160883.html
Download version 14.10.0 and rescan.
What happens if you clear the fault - does it come back?
You have to go in to the controller and clear the fault from there.
Why do people still insist on posting VCDS questions when they are using superseded versions that do not offer full support for the MQB platform?
