Trevorb33's Fantasy Green Fabia 1.8t Sleeper
Wow, you'll be getting stuck in at a fair old rate then.
Nice one.
Yep :) hopefully going for engine out of ibiza tomorrow with all the looms etc, then suspension subframe brakes then the shell can be disposed off, to give me abit of room
  • Replies 906
  • Views 120.7k
  • A few pics
  • Been on a maiden drive today, insurance is all sorted £360 helps being an old git now, got some funny looks with the recirc valve noises:), goes pretty well as is, no abs light on which is excellent,
  • Been at York raceway today to give her abit of bedding in, managed 7 runs, very pleased with times ran a pb of 15.23 , surprised a couple of things, namely a mapped Leon Cupra 180 and a caterham 7, an
Looks a great project Trevor, all the best with it. The wiring can be a right old PITA. My experience has been with Impreza wiring, where even the same model can have variations from one month to the next. I went for the engine loom option and a bespoke loom for the rest of the car for my project. Important to spend a bit of time getting it right as electrical associated breakdowns are a nuisance.
Thanks, and yeah I definitely don't want electrical problems, hence why im going to keep it as simple as possible with manual windows, no central locking etc
Word of advice :D  KEEP the shell until the project is done and satisfied.  Nothing worse than throwing something away and realising it had something you needed. :)
I know what your saying Jase, I'm just running out of room with four cars lol
Yeah - I hear you loud and clear.  If you're able to, try and find somewhere to stash the shell for a couple of weeks until you are satisfied you definitely need nothing from it.
OR, just literally bare bones strip it down to metal  :D
This. Just try and remember where all the parts went! :P Mine had nothing on it in the end, except 3 panes of glass
Day 2 :) engines ready to come out just hanging on the mounts, removed the secondary air pump and bypassed the n112/249 while I was there, so much easier to do on ibizas as its all on top of the cam cover, all the engine loom is labeled, I was put a little behind as I had to do a tip run and pick the engine hoist up,
some pics
Before 112/249 bypass, what a mess
And after much better
Day three, very pleased with progress today, both engines out of Fabia and seat, and 1.8t sitting on the mounts in the Fabia:), also managed the change abs unit over and slave cylinder and pipe while engine was out, wiring is separated out the seat completely free now, so next couple of days will be playing with wiring and stripping inside of the Fabia,
Some pics
Abs was abit of a ball ache as the connections were in a different position to the old pump so needed a rerouting of pipes
You can delete the EVAP too (weird looking pump sitting near your fuel lines).
Followed :)
Looking forward to this one  B)
Im following this too.
From my investigation, alot more of the wiring into the cabin is usable than some may believe.
Dont get me wrong, there are differences, but judging by the 1.8T Looms sat at home, they arent that big. Im talking put the 1.8T loom into the engine bay, then modifiy it to fit the Fabias pin out. on the connector block under the windscreen.
I look forward to seeing how this pans out.
Yeah that would be a hell of lot easier
Excellent progress! I wish I had your know how, would make life simpler at times, and cheaper for projects! Keep up the good work!
Day five update
The parts fairy had been
So today I've connected up heater matrix, gear selector swapped and bolted up, down pipe fitted, subframes swapped, new coolant temp sensor and housing, thermostat changed, new dipstick tube fitted, oil filter changed, filled up with oil, and modified the front panel to accept the Ibiza rad. That's all lol some pics
Standard front panel
Ibiza rad fitted and front opened up
Subframe differences, need the Ibiza one to aid downpipe clearance
Not much left now just driveshafts and fuel pipes really, then onto inside wiring :)
Your not hanging about!!
Trying to make the most of a rare week off, back to work Monday so will slow to a halt then :(,
Could possibly have it running by Sunday night! Keep at it. It will be good to see.
I don't think I'll get much more done this weekend:(
Sad times. But your not too far off!
Not too far, at least not really any heavy work left
No more updates till next weekend now :( gotta help put a kitchen in tomorrow
Amazing progress! Well done sir.
