Trevorb33's Fantasy Green Fabia 1.8t Sleeper
It isn't? They all look the same man! :sweat:
Uptown's was a classic.
Trevor has a Comfort, That at the time of purchase was one owner from new with a full history.
It was also pretty clean.
  • Replies 906
  • Views 120.7k
  • A few pics
  • Been on a maiden drive today, insurance is all sorted £360 helps being an old git now, got some funny looks with the recirc valve noises:), goes pretty well as is, no abs light on which is excellent,
  • Been at York raceway today to give her abit of bedding in, managed 7 runs, very pleased with times ran a pb of 15.23 , surprised a couple of things, namely a mapped Leon Cupra 180 and a caterham 7, an
I'm not sure if you meant to make that error in Updowns name, but I shall forever know him as Uptown (girl) :D
Wahey! What an awesome build. :)
Damn it :P stuck in my head now...
Update, have completed most of the rear loom, rear lights connected and wired in, have working side/brake and indicators, no reverse and fog so I'll have to investigate that, aerial connected, rear speakers wired in, all rear boot side trims back in, put a few dash trims back in too, wheel and airbag are on, and fitted facelift rear lights, were a bargain at £10
Some pics
Is it too late to buy it back? ;)
Great work mate, really amazed how you have cracked it out.
You have enough toys already Mr Fox :D
No chance haha
Ah just remembered why no reverse or fog, there in the boot lid loom so I'll need to extend then across do'h
Excellent work mate - you also need to amend your signature and car in your profile. Now far more interesting than a Toyota! ;)
Nice work bud you don't hang around haha
Little bit of progress started running her up today and got the dreaded low oil pressure light on, thought cleaning the strainer would solve it, but obviously not, so annoyingly new oil pump and another lot of oil ordered, job for Saturday by looks of it, it's holding coolant fine though which is a good sign, bit more wiring to do but getting there, may be test drivable by Sunday
Cool Trev can be our 1.8T conversion go to guy. :D Excellent work!!
Pleh you blow up one engine and everyone moves on :(
I'm not the first by any means, and hopefully mine will be ok after the oil pumps changed.
Tonight's update, side indicators wired in, got manual original heaters working woohoo, all abs sensors wired up and connected, abs light is now no longer on the dash, one down many more lights to go lol, bulkhead panel and rubber trim in engine bay fitted, Ecu clipped into place and a brake servo repair kit fitted as a end was split, that is all.
Top work Trevor.
What are the plans for the Tip / induction? Are the FPR and injectors standard?
Top work Trevor.
Yeah everything's standard, I'll be fitting a carbon enclosed air filter I have lying around as long as it fits, be good to have a bit of a induction roar/recirc valve noise, exhaust will stay pretty standard just going for diesel middle pipe so no silencer for a slight more note
Got driveshafts on tonight, much of the dash back in, starting to look normalish again now :)
So left to do is
Front bumper on/wire in front fogs
Oil pump/oil change
Mount air filter
Bleed brakes/abs
Get a key coded so I can use original fab key for doors and boot etc
Code out airbags not fitted on vcds
Wire in reverse and rear fog
Fit door looms
Fit exhaust
So left to do is
Oil pump/oil change
Mount air filter
Bleed brakes/abs
Fit door looms
Fit exhaust
About 30 mins work at your current rate! :)
Great progress again Trev really looking forward to seeing this in the flesh at Rockingham!
Yep I'll be there should have my private plate on too by then
Front bumper back on with fog lights wired in, gave the engine a quick clean, inlet manifold came up quite well, brakes are all bled, going to finish the rest of inside tomorrow, get the sump off again ready for oil pump coming on Monday,
Looking like a Fabia again :)
Engine bay looking a little better, never going to be a show car, mounted air filter too and made a bracket to secure it, will do for now
Just need to wash it with a sponge and washing up liquid and it will be a perfect sleeper :yes:
Insides done bar one bit of trim under seatbelt that broke on removal, need a trip to scrappy this week some time to pick up another.
courtesy lights wired in and dash dimmer and headlight adjuster wired in, got oil drained ready for sump removal again tomorrow once bits arrive, and hopefully get to skoda to pick up exhaust clamps at some point, then getting a key cut and coded tues afternoon, so should have a few good days of testing before the national:)
All coming together nicely Trev!
