Misfiring cylinder one
  • Sponsor
Just buy a couple, one for the suspect damaged one, one spare. I'll search out a post I wrote a while ago about a much cheaper source of these.
  • Replies 221
  • Views 25.2k
  • Breezy_Pete
    Breezy_Pete
    Doesn't sound like a good plan to me; timing of the input signals to the two 'mis-fed' coilpacks will be all wrong, won't it, hence the shaking. Surprised it started at all.
  • sepulchrave
    sepulchrave
    Incorrect firing order correctly diagnosed, 2,3,4,1 as opposed to 1,3,4,2, oh dear, schoolboy error.
  • sepulchrave
    sepulchrave
    What I mean is, you altered the firing order so the engine wouldn't run, you needed to physically swap over the coil pack between 1 and 2 but keep the wiring in the same orientation to see if the misf
I could do, got to collect them tomorrow so my plans today are ruined lol, should've ordered them yesterday.
It's almost certainly the ECU shutting down the injector due to a detected misfire, the misfire itself will be caused by a coil pack, spark plug or the wiring loom.
And this, along with the insulation "breaking down" when hot and under load, would explain everything.
  • Sponsor
Injector O-rings cheaper source.  Not that cheap if you only want one or two, but much better value than VAG if you want a full set.
Have you checked the new parts, it's quite easy to crack a brand new spark plug while fitting it as well, when you say the loom 'seems' fine, have you had the plug off the ECU, shorted the plug at the coil and tested for continuity while wiggling it?
This is why you should always use a proper spark plug socket for them, even if you think you can use a normal long reach, or a ratchet spanner.
I got a spark plug socket set from halfrauds
Nice, £6 for 10? Have these been tested? I mean, its quite a big difference from £40 for 8, and that's with a 15% discount lol.
  • Sponsor
Currently £7 or so delivered (for 10) if you weren't in a hurry.  As I edited into the first post of that linked thread, installed in my Golf and working without issue, as far as I can tell.
No brainer really then - I'll get them ordered today.
Constant 750 idle now, been idling for 10 minute so far, some slight bogs and shakes but as expected with this engine anyway lol. Gonna leave it as long as I can before it starts to misfire, had the negative battery terminal off for a hour.
How do I depressurize the fuel line? Will it say in my Haynes book or is there a guide on here somewhere? I've tried using the search function.
  • Sponsor
Avoid pressurising it as per suggestion in post #115, or if too late for that, there's a tyre-type valve on the nearside end of the fuel rail, isn't there? Poke the middle bit of that.  Haynes would cover it, I imagine.
I believe I've found the problem! :)
Edit: Oh, fitted new o-rings too.
How do i go about solving this problem? I presume electrical tape isnt an option somehow?
Edited by Avante
I've got error code 00819, would that be anything to do with removing the flap in my engine cover?
Other DTC's:
00819
01598
01314
01316
16685
Edited by Avante
  • Sponsor
Interesting...
Can't really make out how much corrosion or damage there is to the wire cores themselves? Wants mending for sure, or if the copper looks OK, at least sealing against the atmosphere. If the copper cores are OK, I wouldn't think that just being exposed like that was causing your problem, unless they're touching something metal (or each other!).  Is it the engine cover that's been wearing on them? What's that hose at the bottom of the picture? That has a funny looking area in the photo, is that damaged too?
  • Sponsor
00819 is an aircon sensor telling you that it's low on gas, I think; nowt to do with your airbox.
CBA to google the others just now.
I believe it's something to do with coolant? Comes from near the expansion tank and runs parallel to the fuel rail. Its just a bit of insulation tape lol.
I got quoted about £120 for 4 new injectors, which i refuse to pay, is there anything I can flush through them or something, they don't look gunked up but just to make sure. Any other things I could try? I need VCDS lol, suppose they aren't cheap.
  • Sponsor
Carb cleaner, but you need to open them with 12V applied across the connections. Mind out for the combination of carb cleaner and sparks...
If I were you, I'd clean these two areas of damage with meths etc and apply a small blob of sealant like rubber solution or something like that to avoid any further degradation as it looks okay at the moment. My only worry with this cylinder maybe misfiring is that when that damage was done, the wire either at the connector or further back where it disappears into the conduit might have been damaged in a worse way and that damage shown in the picture is just cosmetic, maybe check both these points. I'd think that replacing all the injectors would just be a bit of hit or miss use of your money.
Edited by rum4mo
Did somebody mention Terraclean?
  • Sponsor
The marketing department of Terraclean may have. Only heard of it in a negative context on here, try a search.
I thought the only bad news on here was with a TDI engine, it was only a joking suggestion though if I had a simple petrol engine and could not stop considering that the injectors were a bit cloggy and the inlet tract and head very coked up, I might risk Terraclean - so far avoided giving in to temptation and used lots of V-Power+ instead.
  • Sponsor
Petrol's a good solvent.
Bah, Terraclean, what a load of old nonsense that is, massively useless on direct injection diesels since all the clag is in the air plenum.
