Dennis's mk1 Fabia
Hi everyone! I am new to this community and the forums, looking to meet new people & their cars.  :clap:
I recently bought an mk1 fabia mpi, its a 1.4 and very basic 'classic' model. So i am looking to change a few things, mostly cosmetic because imo there is no point modding an 8 valve 1.4 engine. Nothing too expensive, I'm only 18 so money is tight /:
Here are a few pictures:
Plans:
Planning on removing the rear fabia badge and the 'classic' badges on both sides.
Pressed plates on both sides.
Skoda wheel centre caps
Leather Skoda vrs steering wheel
Thinking of spray painting the front chrome grill black, not sure yet :\
Removing the mud flaps and thats about it atm
Anything else you would recommend that I could change? Thanks! :clap:
Edited by DennisRU
remove the side bump strips? I did it on my first polo and it made a massive difference.
try colour coding a few bits like mirrors, front and rear bump strips.
The grill in black would be good too, I personally reckon colour code it to the cars colour :thumbup:
Then LED number plate lights, LED side and interior lights would help with the pressed plates too.
The grill in black would be good too, I personally reckon colour code it to the cars colour [emoji106]
Oh thanks man, great ideas!
But if I remove the side strips wouldn't there be a hole or is it just glued on.
Edit: don't worry mate, just looked at another thread of something doing it on their vrs. Makes the difference, definitely going to try it
Edited by DennisRU
Glued-on side strips, as with grille and rear badges.
NOTE: rear tailgate gate and front grille badge will have 2 locating holes visible on badge removal.
Wheel centres measurement vary, so you'll need to know the outer and inner diameter.
Any badges look on E-Bay with badges sizes on tap.
Good-luck.
Boot and grill badges are 80mm if I remember correctly
331000530989
These are the centre caps I got fit bang on
Thought id reply in here instead of clogging that other thread up haha
Sounds like good plans mate, i need to spray my grill black i hate the chrome.
You could always just lower it 40mm with some springs, couldnt see there being any problem with ground clearance with just a 40mm drop
Hmm, lowering 40mm would make a difference but not too much I guess. I would still pay more for good coilovers then some springs that lower a little bit, however I might consider it in the future :) scrape the floor or nothing haha
Will probably be gtting some plasti dip, colour coded paint and badges this weekend.
Thanks for the info
Haha i know what you mean, may aswell go all the way if your going to drop it. Mine isnt even wound all the way down and it nearly gets beeched on the speed bumps around mine
Order part number
6Y0857231B41
From Skoda, or buy off ebay. It is a cheap mod to maky your interior look complete.
Its the little trim that goes above the stereo to fill in the hole that is present.
You're welcome :P
Order part number
6Y0857231B41
You're welcome [emoji14]
Thanks man, but I actually found the plastic bit to fit exactly right. It was in the glove box and I didn't even check before buying the car haha
The interior photo is like the first day of owning the car, since then I put the plastic on and removed the stupid led light that was on the ceiling.
I will still keep the part number though, thanks! [emoji3]
