Rob's Ur Quattro
I only want white wheels, you can do what you want with the rest of the car :D
btw it's hard to follow threads like this now that the 'My Content' feature no longer works for many of us:( Any ideas what's happened Rob? Sorry a little OT
  • Replies 1.7k
  • Views 177.9k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Colin working on improvements would be my guess :)
Stone Grey metallic looks a bit nice.
12821450_1005254889547946_35415893523850
Paint is ordered :D
It might even be on the car in a couple of weeks.
They're accepted another big project so they'll want to move mine along :D
No progress in the last couple of weeks, trying not to hassle them too much, but also making sure I keep in contact.
I bought some replacement wheel centre cap bolts from the UK which I think will fit - they're actually from a Renault. But they sent the key without the bolts - doh!
Called in and had a chat today - bonnet is looking like new in black primer now and I've seen the paint, in a tin, looks good :)
They had the bumpers test fitted and there's some more metalwork to do to make them sit properly at the front. There's another repair on the front crash bar area which looked a bit untidy but I was going to leave it as it would be invisible under the grille.
So another day's work to pull that apart and fix it properly.
Oh and the car's no longer running - looks like maybe fuel pump, probably wiring as it has had a pump put on from a different car to get it going and the wiring's not the tidiest. Chances are that got damaged then they fixed the hole in the floor nearby.
Edited by RobClubley
Primer and stuff
12525628_10153891773705977_6700084171132
12440247_10153891773685977_1595763009684
980784_10153891773715977_613720104044284
That dodgy repair on the front
12823348_10153891774085977_8943080939462
I went to the garage to do some sorting out of the many quattro parts. It has been a long time since I stripped it and I've forgotten where everything is. It's labelled but not sorted.
But I ended up doing something else. The rear plastic COUPE panel from the quattro has some cracks i it, but the one from the donor GT is much better, so I decided I'd use the GT one, then noticed that the quattro one has a fog light. Swapping it over became a two hour job with a Dremel but it's in there.
12891769_751565554943743_461909637277412
Got it cut out then realised the GT one was silvered inside.
12719578_751565551610410_402426859284747
After a bit of Dremel work :)
12901201_751565558277076_900692330409119
Red lens glued in
12322656_751565621610403_230845789873952
Done
12322654_751565624943736_417003278023874
At least he found a British one :)
It's booked for more work on the 13th. Guess they're busy!
Waiting...
Apparently they did quite a lot on the car yesterday. Pics are promised.
Called to look at this week's work at Just Rust. Trying not to be their most annoying customer.
Front bumper fits well now, rear is almost there.
I have a review car next week so I'm going to take a trip to a scrapyard 300km away to pick some bits from the three Coupe GTs they have there.
http://forum.autoclique.co.nz/attachment.php?attachmentid=4534&d=1460759164
12974482_761417273958571_435603778142869
Have been following this topic from begining... It's coming along really nice!
