Rob's Ur Quattro
  • Replies 1.7k
  • Views 177.9k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
After nearly three hours of mucking about I got the other sunroof drain in place. I used a coathanger to get a small string in there, used that to pull through a rope, then used that to pull the pipe.
It looks a bit squished on the photo, will check that out.
I'm just about ready to get the head liner installed now, then the sunroof can go in.
13585182_799690380131260_290023625755331
13613239_799690360131262_537145047082636
13559011_799690366797928_294168322163540
Some awesome work here! Does it still run (wiring aside), or is there mechanical work to do after the interior/body work?
Is the headliner fabric too like the c-pillars? Have fun, if so! The fabric one on my E30 took aaaages and was a nightmare and needed two people. :( I'd suggest buying a load of bulldog clips if you've not got some already (assuming it tucks under the window/door seals? We glued it to the lip on those apertures, and then held it in place with the clips while it dried)
It does run, yes. The power steering needs sorting out, it makes a bad noise, Maybe old fluid, maybe dodgy pump.
Other than that it needs fluids changed and some new bushes and bits like that.
The headlining, fortunately, is hardboard backed and comes out in one formed piece. Just needs a good scrub before it goes back in.
More scrubbing.
13626604_801170823316549_790655857242818
After
13613199_801170759983222_462205353302397
13569048_801170829983215_505878575217548
13626507_801170793316552_164789584851001
13567526_801170826649882_693833516657053
And it's in!
13615127_801172049983093_558671124069371
13575860_801172069983091_339296397549253
Sunroof is in place. It's not quite closing properly so some adjustment is needed, but it works.
13662152_801683083265323_894755821220491
13603826_801683063265325_826891878823783
13641195_801683096598655_783746959229015
13620988_801683136598651_353093716913252
Did a couple of other small jobs
Aerial installed
13653202_801684669931831_479248547246364
Wiper motor in place. I'm missing one of the rubber washers for under the bolts, no idea where to find one. Any ideas? It's 53mm across, and maybe 0.5mm thick.
13661759_801684683265163_492844586026980
Rear wiper motor installed and parcel shelf in. One of the speaker grilles has gone missing in my storage area, must have fallen down the back of something, it'll turn up.
13569027_801684693265162_888214423214453
Good work, especially the interior cleaning.
I'd probably buy some rubber and cut the washer if struggling to find one.
Plumber's merchant (or Kiwi equivalent!) for the rubber washer Rob?
This is looking really good Rob, it will all be worth it in the end.
Lubricate that sunroof mechanism with some marine type grease - I remember the one in my 80 sport from years ago getting so stiff that it stripped the splines on the drive unit the handle attaches to.
As for prices, they have been steadily increasing over the last few years, good ones like yours are now fetching £25-30k over here. There is a Red one local to me, same owner since new (1990 registered), who I see regularly around (and speak to occasionally), still trying to get a drive in it.....
My wife and daughter went to Disney On Ice, so I went to the garage :)
I re-fitted the dash.
13667866_812224255544539_497074547519122
13613514_812224262211205_510535143536775
Wipers are on after a trip to the plumbing shop for a rubber washer.
13876556_812224535544511_838126143028063
Sam, my "Helper"
13248608_812225062211125_354972768681999
I tested all of the dash illumination and warning light bulbs. One was blown, two were missing.
13765867_812225465544418_673100238611788
Then got the stalks and dash in place
13668883_812226345544330_496218221168027
One of the light switches looked a bit worrying. Fortunately the one from the GT was fine.
13667950_812226828877615_716932373478839
The dash surround needed some work, and some glue, to get the switches in place so while that was setting I fitted the front windows.
The brackets are solid but had surface rust, so I cleaned them up and painted them.
13641071_812227212210910_460553268291075
13909111_812227215544243_682057927714123
13668011_812227205544244_233639054663001
13895153_812227285544236_695622993650257
I really should re-fit the battery and start testing this stuff.
Still finding little things to sort out, like the curiously large number of holes leading from the scuttle tray to the cabin.
Also looking at the state of the seatbelts I'm thinking of binning them and buying brand new. Both for looks and safety.
The only think that might make it tricky is that the universal ones all have an eye for a bolt at the bottom, and the quattro ones loop around a metal slidey bar.
I have a feeling this will need to come off again at some point. but for now it's in place.
13662005_812733112160320_587805456949217
Pulled the carpets out for a look and they're worse than I realised. Apologies for the bad photo.
13908861_815933748506923_856672305662595
Going to get a local upholsterer to make me a new set.
I couldn't wait any longer to add this sticker :D
13668857_816105148489783_555678931519003
All the lights that currently work
13975375_817075201726111_264632521590967
13668875_817620471671584_419486291997788
Got the seatbelts on Friday so I decided to fit them today. I had to cut new holes in the rear shelf so they'd work properly - wondering if the GT had different holes to the quattro. I binned my original parcel shelf as it had big oval speaker holes in it, and this one was in way better condition. I thought they were identical, but apparently not.
13988114_820416324725332_372473006608236
The rear belts it came with - one is a Volvo one but looks identical to the other which has a VAG part number.
13908882_820416264725338_100847384718383
13920648_820416248058673_471220302776499
13958165_820416401391991_382857034834895
I took the tail lights out and put the seals in - not something to forget :)
13907191_820416781391953_649444092217020
13923814_820416838058614_505436722815159
13934676_820416834725281_425348754490353
I have working rear lights.
Brake lights, reverse, fogs and indicators don't appear to work though.
14047284_820416908058607_825860771853849
I don't know if this applies here, but some 1980s cars the brake lights only work when the ignition is on. (found that out when having a towbar installed and the brake lights didn't work although the tails, indicators and hazards all did)
You're probably right - I didn't have the keys in the garage with me and I was too lazy to go get them :D
Tried again with the keys in. I get more tail lights, indicators light up but don't flash, need to check the relay.
Reverse lights and brake lights need sorting out.
And now the fuel pump isn't working and I need to move the car in a few days for new insulation to go in under the house :D
Earthing continuity OK Rob?
Will check when I get time at the weekend. There's a mystery live and earth direct frrm the battery into the dash somewhere which is currently disconnected as I didn't like that!
And it could be the hazard switch. I have a spare so I'll try that.
Reverse light wire isn't connected to anything. I vaguely recall something falling off when i removed the carpet :D
Haven't even looked at the brake lights yet but it wouldn't surprise me if the switch is loose or disconnected.
Copy of possible comment ref crashworthiness of this car:-
I'm not suggesting doing this, but a mate of mine once head-butted the planet* at about 80mph in an Audi Coupe (same shell but FWD, no turbo). His worst injury was a minor cut where his glasses fell off.
The car was about 2 feet shorter, but the doors still opened and closed.
*Well a concrete bridge parapet with about 3 miles of earth behind it.
Ouch. Reassuring at least!
