Rob's Ur Quattro
New fuel pump has arrived from Latvia, and filter from UK. This is a generic filter with 12mm connections that I bought to replace the plastic pre-pump filter. It's a bit bigger than I pictured, lol. I've been recommended a more appropriately sized one which is on the way.
Out in the spring sun.
Post pump fuel filter arrived. New rotor arm looked great until I compared to the old one. It has a smaller hole! It seems I have the 83 84 distributor.
Cleaned my one up and I'll search for the Topran one same as I have.
  • Replies 1.7k
  • Views 175.8k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Pah, that rotor arm'll go on - you just need to use a bigger hammer! 😇😁
Gaz
Cars and coffee today
Edited by RobClubley
Got the new filters and pump fitted this afternoon. As always things didn’t go totally smoothly. The filter connections were corroded and needed a bit of WD40 and effort to loosen. The filter was dated 2011! I reassembled everything, tested and fuel sprayed out of the pump. I realised I’d used the wrong crush washers so it was easily fixed.
Groovy pipe clamps 😎
G
6 hours ago, RobClubley said:
Hi Rob, was that a type 82 Kubelwagen at the Cars & Coffee meet?
Yes I think so
Some cracking cars and photos there
New paper air filter to replace the ancient K&N. That last clip is a bugger to get on! I ended up using two screwdrivers and a pry bar through the headlight hole. One skinned knuckle and only one dropped screw 😃
Touring Wellington’s op shops!
Rusty is running way better than it ever has since fitting the new fuel pump and filters. Not hesitating, not spluttering at low revs, warm starting quicker. Not threatening to stall when lifting off at low speed.
Very happy!
Very happy!
Great shot of the harbour and international terminal. Do cruise ships still visit?
Not since Covid but apparently they’re coming back this year.
16 minutes ago, RobClubley said:
It pulls hard to the red line, it doesn't stutter or miss, I can power around bends like a boss, it doesn't threaten to stall when manoeuvring at low revs, I can accelerate from low revs in the wrong gear and it just does it, no hiccups, and it sounds just ****ing epic.
But can you take a modern hypercar like a king?
Lol of course!!!
That’s better! This rotor arm fits. Bought on EBay UK, made in Spain, delivered to New Zealand from Latvia.
That's what you call international service! :)
Yes!! Warrant of Fitness passed with no issues!! Happy days! Road trip next week!
"Rear tyres lowish" :D:D :D
Plus a little too much negative camber on the fronts?
Rob's not attacking the corners hard enough 😁 Drive harder and chew up the outer edges to match the inners 👍
(Or mebbe check the toe-out too)
G
G
Doesn't excessive toe cause 'feathering' of the tread pattern?
