S3 Winter wheel / brake sizes
Just look for the Obvious which is not the Sticker, look at your Owners Manual for the vehicle you have which i linked,
then get the Homologation information for your particular vehicle from Skoda Fance or CZ.
  • Replies 208
  • Views 69.6k
  • Scudo wheels and Pirelli Sottozero rubber worth their weight in gold down here in the Pyrenees. Sent from my iPhone using Tapatalk
  • Just crept in before you.
  • These are what are the sizes fitted from the factory:   ET40 (7x17”) ET41 (6½x16” & 6½x17”)   ET44 (8x18) & 8x19”)   Your car will come with either: 17” alloys: 7” (wide) x 17” (diamete
I appreciate the help, but as I cannot buy an IV with 16” wheels in France (the options list state the option is not available for the IV), the sticker also shows me I can fit 17”, 18” or 19” wheels, I am pretty sure 16” are not homologated on the IV here in France.
The manual is a generic document, and not specific to the IV.  It covers all models. Yes, the snow chain section applies to all models, but if I cannot fit 16” wheels to my car, then the information is not of much use.
I will of course confirm with the dealer and I will ask if I can fit 16” wheels. I have a good idea what the response will be….
What is the issue with fitting 17" wheels anyway on a car the size you have?
People at Skoda Dealerships are even telling people with a Scalla or Kamiq they can not fit 16" wheels yet they are available to buy from Skoda Dealers for that fitment.
Simple enough to ask Skoda France Customer Services if the 16" wheel are homologated.
That is what they are there for, and not to give wrong information if they do not know, they should know who to ask.
I never said there was an issue fitting 17” wheels.
I just wanted to know what my options were. 16” wheels opens up more options on the 2nd hand market.
I found the below information in the owner's manual. It looks like you need to look in the declaration of conformity (in the so-called COC Document) to find out the Skoda approved tyre sizes.
Approved tyre sizes are specified in the technical vehicle documentation and in the declaration of conformity (in the so-called COC Document).
The declaration of conformity can be obtained from a ŠKODA Partner (valid for some countries and some models).
I found the same info. I will check my paperwork.
  • 3 years later...
Introductions first am about to become the owner of a 21 plate superb estate which will replace a 61 plate passat. Travel to french alps at least 4 times a winter for which snow tyres are invaluable. Currently have a set of 235/45 r17 snow tyres on 7.5j et47 rims. If I understand correctly I should replace these with 215/55 R17. Questions I have (apologies I’m sure this info is on the forum and I have searched):
Will my existing tyres fit as a short term measure.
Can I  continue to use my existing wheels with new tyres.
Will I be able to use snow chains with proposed new tyres.
Kindest Regards,
Trevor
Edited by brovert
Technical data
The below information is an extract from the Superb MK3 owner's manual. As you can see there are only two tyre and rim combinations shown.
Superb MK3
Permitted rim/tyre combinations for mounting of snow chains:
Rim size
Tyre size
6,5Jx16 ET41
215/60 R16
6,5Jx17 ET41
215/55 R17
Only fit snow chains with links and locks that are no larger than 13 mm.
Edited by Carlston
21 hours ago, brovert said:
215/55 R17
add to options list also to 225/55r17, recommending especially for winter usage
