VCDS options on Superb III
I have done all three on a MY17 car.
Deactivation of Start-Stop did you use STG 08-HVAC? Is better solution like changing Start_stop_voltage_limit to 12,1V ?
For "Activating alarms chirps locking/unlocking" did you use STG 16 - 31347 - adaptations? I can change it to active, but no option to turn the alarm chirps in the infotainment.
Edited by vlk
  • Replies 2.5k
  • Views 827.3k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
mtl:  Enabling DRLs menu - clone vcds
Thought so. There is your problem.
Using latest genuine VCDS version will fix it. :clap:
PS: Kudos for using clones on MY2017 cars. You have guts ;).
Edited by mtl
+1 you need the latest software
Wouldn't touch my MK2 Tiguan with a clone.....
Is possible to change the Lane Assist activation threshold with VCDS, for say 40km/h (~25mph)?
How is it handled in this forum? In germany, we didn`t help someone, with a clone vcds. I like that handling
I usually do not answer to those who have clone VCDS...
I agree, clone shouldn't work on new models as well right?or until they make new clones.
Does anyone activated Traffic Sign Recognition on MY2017 model?
I tried on the new Sportline, but it seems that A5 module is completely different, in case of coding as well:
MY2017:
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 25081612K10036
   Coding: 0204080100000401002613558050A10088000E100040
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB.rod
   VCID: 3A55FDE3BD3F0692BA-806E
No fault code found.
MY2016:
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0024
   Serial number: 15041611P10361
   Coding: 0204080100000401002223468040A00088000E100040
   ROD: EV_MFKBoschMQBB_SK48.rod
   VCID: 3851E7EB833314FE86-806C
I've had that same module (F) on a Superb MY2017 and on Passat MY2017. I haven't coded TSR, because they were factory fitted with it, but TSR coding on both cars was the same as in MY2016 cars.
MY2017:
I coded my 2016 MK2 Tiguan with TSR
   Serial number: 15041611P20577
   Coding: 0003070600000401000213448040A10094000E000020
   Shop #: WSC 01357 011 00200
   VCID: 3A55E97EBD7A5A92BA-806E
When I hook up my bike carrier the rear sensors and blind spot monitoring are de-activated and have to be manually activated when the tow bar is stowed.
Can these functions be activated automatically via VCDS?
My rear sensors automatically switch back on when I disconnect my bike carrier/lighting board.
What am I doing wrong Coops?
Not sure Phil.
My towbar was retrofitted but fully coded on installation. When I use my towbar (detachable), I just connect my bike carrier lighting board to the socket and the rear sensors automatically disable themselves. When finished I disconnect and doing nothing else - they just come back on.
Hello People i have enabled lane assist on my superb i followed the guides in the fourm. The lane assist works but i am missing one of the options on the Columbus screen. Its the Adaptive lane guidance tick box. Does anyone know where or how i can enable this. I have VCDS. Tks
Simple Question. Does anybod found the solution for the following behaviour of DRL lights, depends os light switch position:
0 - DRL off, low beam off
Auto - DRL or low beam ON, depends on light sensor
Parking - parking lights ON (no change here)
Low Beam - Low Beam ON (no change here).
I'm sure I saw it in Superb 2 coding, but cannot find it in MK3.
Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO
Is this to be done by coding or adaptation? The coding in MY2017 are only zeros.
ok, found it in adaptations:
ENG10575-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active
Locking the car while the engine is running can be enabled by going to Central Electronics adaptations and enabling:
Access control-Funk bei Klemme 15 ein.
This is very useful when wanting to defrost the car, especially for KESSY enabled cars as a second key is not needed for locking the doors.
Apologies if this is already addressed in the thread - I've read through it but am not completely sure so...
I'll be receiving a Superb SE Tech (150 diesel, manual, estate) around Feb / March (no build date yet) - so a MY17 I assume (or could it be MY17.5 ?)
Have added TSR as an option (and Colour maxi dot) - so with that in mind what are the key (best) features that I should be able to enable?
Thanks in advance!
Thanks in advance!
what you like to be activated. At first i should activated lane assist the rest what you want
Following on from Mon55's question....
If I was to order my Superb with TSR and therefore having a forward facing camera, can high beam assist be enabled via VCDS? Can someone please confirm this change is possible with VCDS coding.
I'm not fussed about lane assist as I have that now and never use it but I use the high beam assist quite a lot.
Thanks!
Thanks!
It should be possible to activate Light Assist.
