VCDS options on Superb III
As people started to get their hands on their Sportlines, anyone may look at the Infotainment codings for Performance screen?
  • Replies 2.5k
  • Views 827k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
This is not possible to code and even purchase - it's SWAP function.
Can you activate Lane Assist if the car is equipped with Traffic Sing Recognition ?
Yes you can
Does anyone know if the Performance Monitor - standard on SportLine - can be activated via VCSD for Non-Sportline versions ?
Edited by Norian
This was looked into last year on several MY16 cars and it was not available, until someone does an admap / scan of a sportline we will not know for sure if they use the same controllers or just different software.
Admaps was done and nothing interested are in ...
Is not possible. Its is differend software. I already tryed and compare Golf with this option but nothing is showing in the adaption of codings yet
I coded them always on with the option 100 Active Then the always burn looking nice at daytime
Can You explain how you do that?
Thnx
Lane assist currently not available on superb III 2016YM
I can not find where I made coding mistake
Below are code and images
Please help
<p>
Sunday,18,December,2016,14:12:43:01249
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN:    License Plate: SUEPRB 18-12-2016
Mileage: 17368km-10791mi   Repair Order:
Chassis Type: NP (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55
          5F 6C 6D A5
VIN:    Mileage: 17368km-10791miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
Address 01: Engine (J623-DFCA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H24 2011
   Revision: B4H24---
   Coding: 011D0032036401083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
   ROD: EV_ECM20TDI01104L906026FN_002.rod
   VCID: 7BF23BA7F2E1819AE9-802E
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 042 F    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4901
   Revision: 06354004    Serial number: TFK01605190980
   Coding: 0014
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1C30183B17AF26A240-8048
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61466000000071
   Coding: 1D076A9C34200B74477B060941C549B8562CD0E2608292753861F0F8C28902
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 035019
   ROD: EV_Brake1UDSContiMK100IPB_035_SK37.rod
1 Fault Found:
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 145
                    Mileage: 16969 km
                    Date: 2016.12.16
                    Time: 09:39:51
Address 05: Acc/Start Auth. (J518)       Labels: 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0403755737
   Coding: 032C0C0F03
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB_004_VW37.rod
   VCID: 3C70F8BBB76F46A2A0-8068
   Sensor Controlled Power Rear Lid:
   Subsystem 1 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
   Component: GEB.F.Heckoef  H16 0903
   Serial number: 84383447
Address 08: Auto HVAC (E87)       Labels: 3V0-907-044.clb
   Part No SW: 3V0 907 044 BG    HW: 3V0 907 044 BG
   Component: AC Automat    H34 4001
   Revision: 20K05000    Serial number: 00000B00125289
   Coding: 1101010400011001100510000010110A
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   ROD: EV_ACClimaPrehVW37X_SK48.rod
   VCID: 7AFC3EA3FDDBB892F2-802E
   Rear Climatronic Operating And Display Unit:
   Subsystem 1 - Part No SW: 3V0 907 049 C    HW: 3V0 907 049 C
   Component: E265KlimaHeck  H02 0101
   Serial number: 00000000000000000000
   Coding: 000000
1 Fault Found:
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 22
                    Reset counter: 148
                    Mileage: 16024 km
                    Date: 2016.12.10
                    Time: 14:34:37
                    Outside air temperature: 16.0 ∞C
                    Voltage terminal 30: 13.2 V
                    System run time-Engine running time: 253 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: ERROR
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001613001579
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 017001
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F0ACFB7E6F99DBAC5-802A
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 160503  032 0121
   Serial number: 00000001605020301213
   Coding: 165DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S3Y16M05D30H09M22S55
   Coding: 00084D
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY161060HQ3
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000035514898
   Seat Backrest Fan 1 Front Left:
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0083803
   Seat Cushion Fan 1 Front Left:
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0083738
   Seat Backrest Fan 1 Front Right:
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0083621
   Seat Cushion Fan 1 Front Right:
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0083747
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616131
   Coding: 0271165851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 0D16657FDC55BF2AC7-8058
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 320067C351FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3460D09B9F3F8EE268-8060
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 B    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0121
   Serial number: 03051641350571
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC.rod
   VCID: 3878E4AB83576A8244-806C
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R1TJM03
   Coding: 98CCC000000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   VCID: 091E516FA83DA30AEB-805C
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 002 105 16
   Component: SideSensor_Df  001 0887
   Serial number: 357000000004C9984B1U
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 905 16
   Component: SideSensor_Pf  001 0887
   Serial number: 35800000000FF1146B1R
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 402 405 16
   Component: SideSensor_Dr  001 6149
   Serial number: 3510002C52076342732L
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 402 405 16
   Component: SideSensor_Pr  001 6149
   Serial number: 3520002C32076345530J
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 805 16
   Component: FrontSensor_D  001 6149
   Serial number: 3550002A52076344410I
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 EF    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0235
   Revision: FF035035    Serial number: 20160527501275
   Coding: 6410
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 78F824ABC3D7AA8284-802C
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 3V0 920 751 A    HW: 3V0 920 751 A
   Component: KOMBI         304 8311
   Coding: 07A5011A7F8C000801886B0B5001000000000000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_DashBoardVDDMQBAB 009051
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 326CD683652B80D27A-8066
3 Faults Found:
16777010 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 149
                    Mileage: 17353 km
                    Date: 2016.12.17
                    Time: 17:33:27
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 143
                    Mileage: 16825 km
                    Date: 2016.12.15
                    Time: 15:51:19
16776969 - Databus
          U1121 00 [008] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 149
                    Mileage: 17353 km
                    Date: 2016.12.17
                    Time: 17:32:19
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 23051610803043
   Coding: 0B0100045F087300EB00025A9C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ASAM Dataset: EV_GatewConti 013020
   ROD: EV_GatewConti_013.rod
   VCID: 7CF038BBF7EF86A2E0-8028
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B0512110516
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 6644440004
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: WECHSELRICHTE  H55 0033
   Serial number: 0211593
Address 2B: Steer. Col. Lock (J764)       Labels: 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 16000104909007
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71EE198FA0ADFBCA43-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H07 0020
   Serial number: Y0006PEN10030
   Coding: 0010000000000500018280808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_VW37.rod
Address 3C: Lane Change (J1086)       Labels: None
   Part No SW: 5Q0 907 686 B    HW: 5Q0 907 686 B
   Component: HRE_Master    H12 0071
   Serial number: 0405296977
   Coding: 02011103
   ASAM Dataset: EV_HREntryHella 001028
   ROD: EV_HREntryHella.rod
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 E    HW: 5Q4 959 593 B
   Component: TSG FS        010 0031
   Serial number: 0000201370108
   Coding: 001D0820DE00040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 479A9757FEA9157A3D-8012
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000010110841
   Coding: 110200
1 Fault Found:
589828 - Window Regulator Motor; Front Driver Side
          B1321 4B [008] - Over temperature
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 16052 km
                    Date: 2016.12.10
                    Time: 15:52:22
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000799468
   Coding: 01010010005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_SK37.rod
   VCID: 3D76F5BFAC754FAA97-8068
1 Fault Found:
3158336 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 149
                    Mileage: 17358 km
                    Date: 2016.12.17
                    Time: 21:43:27
                    valid
Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 E    HW: 5Q4 959 592 B
   Component: TSG BFS       010 0031
   Serial number: 0000201619391
   Coding: 001D0220DE00040000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 46849A53F9A30C72C6-8012
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000010158793
   Coding: 090200
Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 06D202003F010000
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 40888C4BDB872242FC-8014
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B20000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B20000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 043 C    HW: 3V0 035 043
   Component: MU-H-N-EU     H50 0702
   Serial number: A677D0GB009662
   Coding: 03840101FF00000051110001000008232F0100C4012001009E
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 2B52CBE74201D11A39-807E
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H46 1031
   Serial number: SKZ8Z9SFP00M4W
   Data medium:
   Subsystem 2 - Part No SW: V03 959 801 JL    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Serial number: --------------------
   Compact Disc Database:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2---  --- 1013
3 Faults Found:
6937 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 17358 km
                    Date: 2016.12.17
                    Time: 21:43:26
                    Voltage terminal 30: 12.3 V
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 149
                    Mileage: 17353 km
                    Date: 2016.12.17
                    Time: 17:54:27
                    Voltage terminal 30: 12.2 V
                    BAP-BAP_Function_ID: 02
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 143
                    Mileage: 16838 km
                    Date: 2016.12.15
                    Time: 18:14:10
                    Voltage terminal 30: 12.4 V
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 04840101A600201F000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
   VCID: 77FA2797CEC9A5FA8D-8022
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30690466600000
   Coding: 1008
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 3F8A8FB7A6795DBA85-806A
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0220
   Serial number: 11051611K11247
   Coding: 020408010000040100222356C050410090000E100020
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB.rod
   VCID: 3A7CFEA3BD5B7892B2-806E
2 Faults Found:
1122656 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 109
                    Mileage: 17356 km
                    Date: 2016.12.17
                    Time: 19:50:52
                    Control Module temperature: 38 ∞C
                    Outside air temperature: 0.0 ∞C
                    Vehicle speed: 0.00 km/h
                    System run time: 420.5 s (second)
                    Voltage terminal 15: 12.1 V
                    mid: 02 10
                    Camera_state: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [009] - Lane-Holding Assistance Not Coded
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 109
                    Mileage: 17356 km
                    Date: 2016.12.17
                    Time: 19:50:52
                    mid: 02 A6
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
End-------------------------(Elapsed Time: 06:40)--------------------------
</p>
[img]
Edited by Welsh_kai_boy
The last rule is not (always)right. I found out that the S3 i had you have to change in module 44 Byte 3 Bit 0. See attachment Lane assist.png
Need help
Edited by djole
This one works on MY16/MY17 cars:
STG 17 > Codierung > Byte 4 > Bit 6 - aktivieren ("Spurhalteassistent/Lane Assist aktivieren")
STG 17 > Codierung > Byte 11 > Bit 1 - aktivieren ("Spurhalteassistent/Lane Assist Information BAP verbaut aktivieren")
STG A5 > Codierung > Byte 16 > Bit 7 - aktivieren
STG A5 (Front-/Vorfeldkamera) auswählen
STG Zugriffsberechtigung -> Funktion 16
Zugriffscode 20103 eingeben
-umcodiert (ADP-Personalisierung BAP) (BAP personalization,not activated ) von aktiviert auf nicht aktiviert
-umcodiert (ADP-Warnungsintensität Spurhalteassistent)(Warning intensity; lane depart. warning,Medium) von Mittel auf Auswahl über Menü
STG F5
-umcodiert (ADP-(49)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19) von nicht aktiviert auf aktiviert
-umcodiert (ADP-(21)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning) von nicht aktiviert auf aktiviert
-umcodiert (ADP-(23)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high) von nicht aktiviert auf aktiviert
STG 44 > Codierung > Byte 3 > Bit 4 - aktivieren ("Spurhalteassistent HCA verbaut")
Thnx GaSelle
I will try and let you know
Thnx GaSelle
Just one best practice advice.
BEFORE your start coding by new procedures RECODE BACK TO FACTORY codings so that you do not have any trouble codes.
After that go ahead with new coding.
Can you explain me how to do that?
Is this safe? I mean, I will have everything the same like before any coded?
Since that coding was from factory, yes it is safe :).
Revert all the codings that you have done to factory settings, delete fault codes and check if they reappear. If they do, you still have some problem.
Combining few coding instructions when you have previous fault codes will not lead to solution, if you do not know exactly what you are doing.
Thank you mtl
Let's do it ????
Is it possible to change the number of cycles before headlight washers activate?
I couldnt find it in Octavia MK3 thread.
Yes you can:
·         Number of operations front windsceen wiper washer per SRA activation" (in German - Frontscheibenwischer Anzahl Betätigungen Frontwaschanlage pro SRA Aktivierung auswählen
Change this
I tried like GaSelle explained and like you suggested but I still have message:
"Lane Assist currently unavailable." - images are below
And I can't remove Fault code on A5:
Tuesday,20,December,2016,19:57:39:01249
www.Ross-Tech.com
VIN:   License Plate: GRESKA NA A5 20-12-2016
Mileage: 17445km-10839mi   Repair Order:
                Address A5: Frt Sens. Drv. Assist       Labels: 3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 654 F    HW: 3Q0 980 654
  Component and/or Version: MQB_B_MFK     H04 0220
           Software Coding: 020408010000040100222356C050410090000E100020
            Work Shop Code: WSC 73430 790 00063
              ASAM Dataset: EV_MFKBoschMQBB 001001 (SK48)
1 Fault Found:
1122656 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 17445 km
                    Date: 2016.12.20
                    Time: 19:55:05
                    Control Module temperature: 35 ∞C
                    System run time: 2251.9 s (second)
                    mid: 02 10
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
Gateway Installation List:  5Q0 907 530 AM
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
17-Instruments -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
I am sticking with my advice: you have to get rid of fault codes before any further coding.
Now you are making a big mess even bigger mess.
PS: Publishing your VIN number is not a good practise... I suggest you to delete it.
Edited by mtl
You must be missing something - or - something is wrong. I have used that method on both MY16 and MY17 cars.
He coded something before this and that has lead to this fault code. He has to go back to factory config and then start new coding.
You cannot expect that you will get gold out if you start with garbage... And more he will poke around it and not solve it, harder will be to resolve it.
Edited by mtl
