VCDS options on Superb III
PS: Publishing your VIN number is not a good practise... I suggest you to delete it.
VIN's removed
  • Replies 2.5k
  • Views 827k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
Yes MTL, you are right.
I coded something before, and now I look to find what I changed. I found today in debag folder what I changed and I will try to restore on previous stage.
VIN's removed
Thnx :)
Yes you can:
·         Number of operations front windsceen wiper washer per SRA activation" (in German - Frontscheibenwischer Anzahl Betätigungen Frontwaschanlage pro SRA Aktivierung auswählen
Change this
Thank you, last time i looked it was showing 10, i will take a look again. Is this meaning after every 9th operation 10th one will also wash headlights?  But the headlights must be on, i keep it at AUTO setting.
He coded something before this and that has lead to this fault code. He has to go back to factory config and then start new coding.
You cannot expect that you will get gold out if you start with garbage... And more he will poke around it and not solve it, harder will be to resolve it.
This is the same problem i had on 2 other S3's where i talked about
This one works on MY16/MY17 cars:
STG 17 > Codierung > Byte 4 > Bit 6 - aktivieren ("Spurhalteassistent/Lane Assist aktivieren")
STG 17 > Codierung > Byte 11 > Bit 1 - aktivieren ("Spurhalteassistent/Lane Assist Information BAP verbaut aktivieren")
STG A5 > Codierung > Byte 16 > Bit 7 - aktivieren
STG A5 (Front-/Vorfeldkamera) auswählen
STG Zugriffsberechtigung -> Funktion 16
Zugriffscode 20103 eingeben
-umcodiert (ADP-Personalisierung BAP) (BAP personalization,not activated ) von aktiviert auf nicht aktiviert
-umcodiert (ADP-Warnungsintensität Spurhalteassistent)(Warning intensity; lane depart. warning,Medium) von Mittel auf Auswahl über Menü
STG F5
-umcodiert (ADP-(49)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19) von nicht aktiviert auf aktiviert
-umcodiert (ADP-(21)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning) von nicht aktiviert auf aktiviert
-umcodiert (ADP-(23)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high) von nicht aktiviert auf aktiviert
STG 44 > Codierung > Byte 3 > Bit 4 - aktivieren ("Spurhalteassistent HCA verbaut")
Work perfect now!
I've returned everything on the very begining and coded again.
Thanx @mtl for advice
Edited by djole
Does enibody has experience with Trafic Jam Assist coding?
I think you don't have a 2016 model. I tryed to activate on 4 2017 models. but when cheking the option in the Columbus or gaugemenu the systeem won't want to activate (Option is at this momenterrily not available) . I made a logfile and find out the A5 give's a fault code: See attached file.
Resetting everything won't work. waiting for a day wont work. Made a lot of scans and logfiles but can't find the solution.
Regarding your image with fault code, I had the same probelm and I solved them.
You have mistake in long coding.
My car came with factory fitted HBA (and the A5) and electric drivers seat, and I´ve succesfully coded Lane Assist. So you don´t need an electric passenger seat for that :)
Hi Gaselle, i am living in Denmark and i am driving an s3 hatchback, can you help me with coding lane assist on my car?
Best regards
Peter
Best regards
Peter
Possibly. Send me a PM :)
Is there anyone near Brighton UK who would be able to help me? I am interested in modifying the throttle response.
What software version are you using?
Can you grab a screenshot of byte 11 (a full scan would also help)
Hello
I tried the the DRL control menu
After i enter the security code accepted
I go to the next step to activate the menu but the vcds tells me unkown process
Can any one telks me why ?
Can the intermittent speed on the lowest wiper option be adjusted by vcds? When on auto, I find that it activates too soon and is causing noise when drawing across the windscreen as there isn't enough moisture on the screen. I came from a 2009 octavia which had a much longer time delay. I know the speed of the car is taken into play but I'm comparing it to the normal speeds I did with the octavia.
Hello
I fallowed the tutorial in the link below and i can´t enable de speed display on the fan blower ,there is no Byte 11 Bit 6 on my vcds can someone help me here please.
thank you
http://www.briskoda.net/forums/topic/380829-superb-mkiii-vcds-adaptations-tried-and-tested/
Enabling fan (blower) speed display in AUTO mode
Surprisingly I got the same result , "code cannot be accepted - value to high" :(
Hello
thank you
Original thread updated:
On a MY17 car the longcode needs to physically changed (in my case from 01 to 41) as there is no longer a tick box for Bit 6 and it was not possible to save the change in the Binary code.... PLEASE ONLY DO THIS IF YOU FULLY UNDERSTAND WHAT YOU ARE ABOUT TO DO.
As with all coding I always use a genuine VCDS interface and the latest software available (currently 17.1.1) if you chose not to do the same then on your head be it.
i also can not enable by tick box but i dont know in long code which one to modify. i just worry i might change wrong one.  Should i just find the 01 in the long coding and change to 41?
Is it possible to disable via VCDS the boot opening with long press on the key fob?
Definitely not. Which vcds version are you using?
With VCDS no. I presume you have Kessy, right?
+1, you really need to understand the longcode and binary code before changing any coding this way.
Coding via the tick boxes is pretty idiot proof and hard to get wrong, with the longcode and binary codes it's very easy to get it wrong.
Do some research, there are loads of YouTube clips about showing how to code, but if you have ANY doubts leave well alone.
Can anybody show me which sensor is for automatic long/short beam? I have 2 sensors at my rear mirror, one is probably for rain an other for day/night light.
The top triangle is the (A5) camera which is used for the auto main beam,
the sensor underneath the camera is the rain / light sensor that turns the wipers or Auto lights on.
Yes, my car has Kessy. Why?
Sorry for the late response, my laptop broke so i cant use vcds but my version is 16.8.0 in byte 11 there was no thick box only 2 scroll down optiond for what i can remember. My car doesnt have heated seats mabe that makes the diference.
