VW UK Action plan for EA 189 EU5 engines
Andy, what do these modifiers look like?
  • Replies 606
  • Views 94.9k
  • People make me laugh!! Let's just for a minute ignore the fact the government have promised that affected cars won't be re-banded and therefor have to pay more tax. And let's pretend that the sole
  • This whole saga is very boring. I wonder how many people really consider emissions when buying a motor. A few tree huggers possibly and those who worry about saving a bit on VED but who there's bigger
  • I was amazed to read that a Which Survey only found 9 out 10 affected owners expected compensation; and also surprised that contributors on this forum are trying to minimalise the effects of the 'Issu
Unfortunately in German (I think) but this video explains the 'fix' and shows the flow modifier:
It looks like this:
Another good website explaining the problem, difference between 1.6 and 2.0TDi and shows the different air intake flow conditioners:
http://www.thetruthaboutcars.com/2015/12/vw-flow-straightener-really-works/
Edited by S400DDS
Photo added
Interesting that the modifier is positioned in front of the Mass Air Flow sensor. It effectively disrupts the air flow which will give the effect that the air density is less and the ECU will meter out less fuel at the injectors, pretty much the same way as it does on hot days which decreases power. The emission will be less due the combustion being even leaner.
Not really as the updated software will take in to account any difference due to the flow modifier.
If all they need to do was run the engine leaner, a simple map would have sufficed.
Instead of running leaner, the ECU will now have a more accurate reading of flow and therefore correctly match the fuel and EGR rates to reduce emissions.
Is that to reduce emissions to meet those that were at the original EU Euro 5 emissions tests, and to allow the vehicle to be driven without issues outside of a Temperature Controlled building, only maybe having more Regens than before 'The Fix' 'No worse MPG or lack of BHP / Torque, just at a different RPM range...
It would be better if somebody could dub over this in English explaining how this new cheat is better than the old cheat and the effects it will have long term on the EGR/DPF
They have removed the original cheat. There is no 'new cheat' to my knowledge, instead the newer software is able to meet the Euro5 requirements without it. This is likely to be by changing when the fuel is in injected and changing the EGR rates as combustion simulation technology has improved. The real world emissions will still be higher than the Euro5 figures but that's "normal" for more vehicles.
From the information I've seen so far:
- Maximum torque/power haven't changed although the torque curve has
- MPG is harder to confirm, some people have had increases whereas others decreases
- EGR rates are likely to be higher to reduce combustion temperatures and therefore NOx emissions
There is no information about long term effects on the EGR/DPF, if there is an increased failure rate it'll be very hard to prove it's the fault of the update. Plenty of the cars having the fix are already at the age where EGR/DPF issues aren't uncommon.
As for your vehicle, it's completely up to you currently:
- If you worry about NOx emissions and do the majority of your driving in areas where it's an issue, get the fix done
- If you worry about the changes in performance/economy/longevity of your car, don't get the fix done
If you refuse the fix, you can have it done at a later date where there may be more information about long term effects.
I was initially referring to the jokey vids you get on YouTube with a video of Hitler's being dubbed over with any sort of social comment,but for me your comment  "If you worry about the changes in performance/economy/longevity of your car, don't get the fix done" sums it all up,especially longevity with my car coming out of warranty as I had always thought of Diesel cars good for many miles but it appears some manufacturers are getting higher than thought failures with EGR/DPF which was a fix/design to achieve better omission figures still we live and learn.
The grid before the MAF will disrupt the airflow which will not allow it to get a more accurate reading as it is a hot/cold wire type sensor that is used. If the aim was to create vortex that can then be measured with a different type of MAF sensor that would be fine but that is not the case as the same type of MAF is being used. The vortex MAF would normally just have one or two bars in the air intake otherwise the air flow is too turbulent. That turbulance from the grid would be impossible to measure economically.
Also amazing if this grid works so well that it's not fitting to the latest cars too :o
Langer's I love your faith but I'm not convinced. I've already driven my brothers VRS back to back with mine and the difference was very noticeable when driving normally i.e. below 2500rpm, it felt gutless requiring more revs to perform the same. As for the DPF and EGR faults this could just be compared to older models and if failure rates increase in younger models that have been updated then there must be a reason for it.
I have little faith in the fix which is why I've refused it. I'm also fortunate enough to have the ability to flash the pre-fix SW version if the dealer updates it ;)
In my pervious post I was giving a relatively unbiased explanation of how I've seen this play out so far. The change in torque curve could explain the issues your brother is facing as some Tiguan owners are reporting similar symptoms.
It seemed like you were defending the magically air flow modifier in that it would help the MAF get a more accurate reading. It is doing anything but improving the accuracy.
If they do fix yours it would be interesting to see how your car performs especially as you could revert it back in the same day for a comparison.
If I do end up with fix I'll probably run it for a few days so I can monitor EGR/DPF as they are the undocumented areas :)
Hadn't realised the comments were in response to the 'flow transformer'. Unfortunately, I have little knowledge in regards to fluid mechanics and understanding air flow, therefore the following may have little basis in reality so please correct me if I'm wrong.
VW claim that it's there to create a 'laminar [smoother] air flow that can be more easily measured'.
A quick search for laminar flow shows filters containing tubes/holes suggesting a properly designed 'flow transformer' could create a less turbulent flow.
If a flow is less turbulent, it seems sensible that a more stable and accurate reading could be made.
I assume this would hold true for a system using a hot wire MAF?
Laminar flows are important in maintaining a constant steady flow rate with no peaks and troughs. This is near impossible in a forced induction engine as the air intake varies with the increase in rpm as more air is required especially with the pull from the turbo.
After the air filter the air has more turbulence but as it is pulled into the ducting to the turbo it decreases as it is slightly compressed. The closer is gets to the turbo the more it is pulled which removes the turbulence more. If you add a grid into that air flow it is creating more turbulence not less.
A quick Blue Peter experiment to prove this is run your kitchen tap. This normally has a fine mesh at the end of the tap, count this as your air filter. Now put a kitchen sieve into the flow of water and you will see it creates more turbulence in the stream.
The hot wire MAF cools down quicker the denser the air. The ECU then measures the amount of fuel supplied to match the air density. Cold weather the engine feels more powerful compared to a hot summer day. If you break up the density of air by creating more turbulence the MAF will take longer to cool down.
Another Blue Peter experiment concentrate the air flow from a desk top on your self and you get cold quick. On the same speed setting set it to oscillate and the air flow is no longer directed at you and you're not as cold.
I really think this is nothing more than a parlour trick by VW to fool the public.
  • Sponsor
See here, you have it backwards.
Crude or not with the finished part required at the agents doing 'The Fix' on Euro 5 Emission 1.6TDI the Worlds Biggest Car Manufacturer apparently
can not Manufacture or have Manufactured enough so that the various VW's, Skoda's, Audi's & SEAT can get done where the Owner is prepared to have it done.
Strange or what, as a Judge in the USA is approving the 'Fix' or Buy Back of 3 litre Diesels in the US.
VW are really not trying very hard in the RoW, or is it just in the UK that they are allowed to kick their heals while Dealership Employees say
things like 99.99 of owners that have had the fix are happy with it.
Has anyone that had the Fix had a communications since from the VW Group asking their level of satisfaction with the Recall Action?
Chimaera's explanation would make sense with any other design other than a grid or grill as it would reduce velocity around the walls of the tube due to the moulding of it into a tube which it mounted which creates obstructions around the edge. A perforated cone would have been a more effective design.
This again is only relevant on constant flow rates which you do not find in a cars combustion engine.
  • 3 months later...
On 2017-2-15 at 10:51, langers2k said:
I see that there are several articles re an Autocar test of the fix on a 1.6 Tiguan.  Seems it says that MPG goes down, CO2 up but NO may be down.  Hum!!
I have just read in a car magazine the following:
Your findings that showed VW's diesel emissions recall has brought a fuel penalty are no great surprise to powertrain engineers.
Without resorting to the expensive addition of selective catalytic reduction (SCR) after-treatment  (which does not harm fuel economy buts adds the cost of AdBlue) there are only two engine management reprogramming measures available to cut NOx.  One is to increase the exhaust gas recirculation rate.  The other - which no one seems to talk about, but which VW must know about - is to retard injection timing.  Both reduce combustion efficiency, though, bringing down the critical high peak combustion temperature that creates the undesirable (and law-breaking) NOx
So did VW knows this and so save money by not going for an AdBlue solution??
Hi,
Is it correct that if you bought your used Skoda after 01/01/2016 you will not 'qualify' ?
Not qualify in terms of taking group legal action
Best wishes,
John
Edited by Guest
Not qualify for what?
If you have a 1.2,1.6,2.0 TDI Euro 5 Emission VW Group vehicle with a 'Defeat Device' in the ECU you qualify to take part in the European Lottery
of having 'the fix' done and your car maybe running worse than it is 'pre fix'.
Edited by Awayoffski
At least in a Lottery one has the chance (remote though it may be) of winning a prize.
There are no potential gains for owners in the so called "fix". (or codge)
Just had my Skoda letter to get the fix.  I think not.  Also as I have extended warranty I assumed (what does assume mean!) that they would have a view on what to do re costs for EGR and turbo issue costs.  They do not it seems its up to me to decide.  Bet that any claim is going to be meet with a raft of questions and caveats!
I've just had my letter as well.
1. Has anyone in the real world had the modification and what were their findings on MPG and power?
2. What effect will this mod have on the DPF with regards, blocking and regeneration?
