SmartGate wifi direct
Odd that in flight mode the WiFi gets turned back on. What version of Android are you running? Lollipop should have settings for Downtime or Do Not Disturb, might be a better way of achieving the same end result?
Sent from my HTC One_M8 using Tapatalk
  • Replies 59
  • Views 14.3k
  • Good luck with that Sent from my HTC One_M8 using Tapatalk
  • My Golf has carnet so when it has a data connection can provide weather, live traffic (instead of TMC based traffic reports), news feed, fuel prices and parking info with available spaces with car par
  • From a laptop via web browser Sent from my HTC One_M8 using Tapatalk
5.0.1 on a S4.
I can replicate it,
Open Smartgate app and tap Connect.
Put device in Flight mode.
Go to Smartgate App and watch it going from being Connected to Disconnected.
Watch the WIFI symbol come on and connect to house WIFI.
And if you tap disconnect on the Smartgate App before enabling flight mode?
Try using the DND feature of Lollipop instead of flight mode?
Samsung make a right pigs ear of customising Android though, it might be something to do with Samsungs implementation of WiFi Direct.
I'll try and replicate on mine at the weekend on a couple of HTC's, one on Lollipop and one on something older, can't remember what without looking other than 4.xxxxx
I have 3 Moto E G2's I could try as well if the HTC does the same as you are getting.
Edited by andyvee
To be honest I'm not sure how it behaves but I will try it.
Do you connect & disconnect everytime you get in & out of the car?
I assumed it would self connect when WIFI in range then disconnect when not. Im guessing that I would be in car (connected), then get out of car (disconnected). But for some reason the App decides to try reconnect (even though Smartgate unit is out of range and in Flight Mode).
Edited by GAFF
Meanwhile I can confirm that Smartgate is only taking the fuel consumption into account.
The gas consumption is completely disregarded.
Therefor the Smartgate numbers and indications (Skoda Drive and MFA Pro) are totally useless for G-Tec owners.
content updated in new post below
Edited by GAFF
It does NOT turn on my WIFI
Steps
Tap "Disconnect from Smartgate"
Status button shows "Connect to Smartgate" (i.e state Disconnected"
Put phone in flight mode
Status button continues to show "Connect to Smartgate" (i.e state Disconnected".
****Updated with correct link ****
Andyvee,
I have been able to replicate the issue using x2 devices (S4 & S6), see behaviour using screen capturing software. Captured steps show the behaviour of BOTH connection settings.
I'm able to consistently replicate the Smartgate issue of turning WIFI on when in flight mode on two Android devices using Smartgate App 1.1.25
- Samsung Galaxy S4 v5.0.1
- Samsung Galaxy S6 v5.1.1
Video of issue, along with the steps below can help clarify the issue. I've shown the 2 connectivity options, but the issue is with Option 2.
https://drive.google.com/file/d/0B_fLW3swTqFTMk5MYnM1Q3F4QTA/view
Steps to reproduce:
Option 1- WIFI Client
Open Smartgate
Set Connection type: Setting - type of connection - WIFI Client
Kill app
Reopen App with new connection type
Note the Green connection status button swapping from "Connect to Smartgate" (i.e state Disconnected") to "Disconnect from Smartgate" (i.e. state connected). The app is doing that.
Note the Green connection status button stays on "Connect to Smartgate" (i.e state Disconnected")
Option 2 - WIFI Client Direct
Open Smartgate
Set Connection type: Setting - type of connection - WIFI Client Direct
Kill app
Note the Green connection status button stays on "Disconnect from Smartgate" (i.e. state connected).
Note this time the Green connection status button stays on "Disconnect from Smartgate" (i.e. state connected).
Watch how the devices WIFI gets turned on even with the device set to Flight mode, and as a result of no Smartgate unit switched on it connects to my house WIFI.
Edited by GAFF
Seems to do the same on my HTC as well, if I use WiFi Direct it turns the WiFi back on. Seems you have to manually disconnect to stop it controlling the WiFi.
Thanks for checking. IMHO it's not a very good experience for the app, overriding a phones flight mode request.
My delaer is going to feed it back to Skoda so hopefully they can get it fixed for the next version of the app.
