Amunsen MIB1 Firmware
My problem is that when I want to choose the source, either usb or sd card the the 2 options are not highlighted. The unit recognises the usb stick or card when I insert them. Any ideas please?
Thank you
  • Replies 982
  • Views 225k
  • I have updated my Amundsen from 0435 to a newer version which can be found on the net. I don't want to share the link here to avoid deletion but I will kindly PM it together with the instructions.
  • If you have instructions they'd be appreciated
  • Guys,   From now on a newer firmware is available for MIB1 Bolero/Amundsen. I have installed it without issues. Users previously contacted me: check your PMs. Others just contact me for the deta
3 hours ago, BATVANVRS said:
0490 es el único disponible más reciente que tengo, ¡que ya tienes!
They told me on the skoda that they had to update it to a new one that was already available, but not wait for the review to touch it because I wanted to install it myself.
Thank you anyway 👍
Thank you
 As long as you have extracted the MIB1 file, followed the instructions! It really is simple, only thing I can suggest is make sure the USB key is inserted & hold down the power button on the stereo until it reboots & see if you can then do the update! do you need a set of instructions? PM me your email address.
I have the instructions from a couple of years ago & had the same problem then. I'll do what you suggest & re-boot with the usb already inserted & try the same with the sd card if that doesn't work.
Thank you for your reply.
Tried several times re-booting it & suddenly it gave me the source option on the sd
Tried re-booting a few times & then it suddenly gave me the source option. All went thru smoothly, so thankyou for the advice.
Glad it worked for you mate. B)
Hi @BATVANVRS,
I am new to this forum and spent hours searching for an upgrade to my MIB1 unit. I believe from what I have been reading you might be able to help me out.
If you would be able to send me a link to the firmware as well as the instructions for installation that would be greatly appreciated.
Unit HW/SW
Device part number: 5E0035045C
Hardware: H43
Software: 0371
Navigation database: V03959800BLO033 ROW 2014/2015
[email protected]
Cheers and Thanks in advance
On 04/02/2021 at 12:10, trueevol said:
Hi @BATVANVRS,
Unit HW/SW
Hardware: H43
Software: 0371
smoloney@me.com
Sorted B)
Hi guys can anyone send me the new software.
E-mail:
[email protected]
This is my setup at the moment:
Device part no. 5E0035043B
Hardware: H42
Software: 0292
E-mail:
[email protected]
Hardware: H42
Software: 0292
Sorted B)
Hardware number: 5E0035864A
Hardware version: 041
Software version: 0435
My email address is vortal [AT] o2.pl
Please send the latest version of soft.
Thks
14 hours ago, vortal said:
Thks
Sorted B)
Hi @BATVANVRS
I appreciate if you can please send me the latest firmware upgrade for the following Amundsen MIB1. Thanks a lot.
Sorted B)
32 minutes ago, BATVANVRS said:
Sorted B)
what is the latest version?
I got 0490
1 minute ago, Vahids said:
I got 0490
Thanks 👍
Hey, could somebody send me the Update for my Amundsen?
Part Number: 5Q0035874A
Hardware: H25
Software: 0245
Skoda Octavia III
Thanks in advance!
Greetings
Your
Hardware: H25
Software: 0245
Skoda Octavia III
Thanks in advance!
Greetings
Your unit is not MIB1, it is MIB2. You should ask in the MIB2 topic!
Hi Guys,
Can anybody send me the latest 0480 firmware ?
Hardware number: 5E0035874A
My email address is [email protected]
Many Thanks !
Sorry, I meant 0490. Thanks !
Hey together,
I got the 5E0035842A
HW: 041
SW: 0435
Medien-Code NA
Could i also get the newest Version please :)?
And is there a kind of a changelog, which tells, what is fixed?
Greetings
I am from Germany and new here and hope you can help me.
I am looking for a firmware update for my Amundsen
DeviceNo 5E0035874
Hardware 038
Software 0171
 Is it possible to update this MIB1 at all?
Best regards
hughes2112
[email protected]
Having recently managed to update the software, it's all a bit of an anti-climax.
What differences should I expect please?
On 12/11/2015 at 11:28, aki78 said:
Hey, Aki
I noticed you engaging in various debates on briskoda forum and I noticed one post from you in which you said you have files for amundsen/bolero update so I was wondering if it would still be possible for you to send me files regarding Amunsen mib1 0490 firmware update. I drive Škoda Octavia III with this system, except, it has 0435 firmware version. I would be glad if you could help me.
Best Regards
Just now, Dragomirski said:
On 23/02/2021 at 12:42, lapkandeX said:
Hi Guys,
My email address is martinlapcak@gmail.com
Many Thanks !
Sorted B)
