Amunsen MIB1 Firmware
21 hours ago, TonisT said:
Hardware 040
Software  0421
Device 5E0 035 874 A
Can someone please pm me fw and instructions
Thanx
4 hours ago, CCAU10 said:
Device Part Number: 5E0035864A
Hardware: 041
Software: 0435
I also have a question. I calculated the index from 'Confirmation of installation change' and give me CE 43 xXOR C9 D2 = 7E6. How should I be entered? 07 E6 or ...?
7 minutes ago, PHuxo said:
Hi Croat
Your warning is probably very wise words and I guess that people should update at their own risk. Do you have a link though or able to point in the right direction for MIB 1 update?
SWBoy, do you have it?
Many thanks everyone.
PM me guys.
  • Replies 982
  • Views 227.6k
  • I have updated my Amundsen from 0435 to a newer version which can be found on the net. I don't want to share the link here to avoid deletion but I will kindly PM it together with the instructions.
  • If you have instructions they'd be appreciated
  • Guys,   From now on a newer firmware is available for MIB1 Bolero/Amundsen. I have installed it without issues. Users previously contacted me: check your PMs. Others just contact me for the deta
I got sent a link when I requested it on here, sadly it isn't in my inbox anymore - sorry :sadsmile:
TonisT & PHuxo sorted.
Thanks very much BatvanVrs!
Sal. Am O3 cu vers. soft 0421. Ma poate ajuta cineva cu update la 0490?(am inteles ca apare si functia Mirror Link)  Multumesc.
Can you help me with a update from 0421 to 0490 and a tutorial? Thanks.
No MirrorLink in MIB 1 in any version of fw .
pm to send you  fw 490 and how to .
Thanks a lot! But i want it for Mirror Link. No chance to have it on MIB1?
Nope as MIB 1 does not have the hardware to support it .
You need to update to MIB2 which is costly and not that straightforward.
Hello, what is the new version of Columbus MIB1 software, currently I have 4.21, please send a link to the new version, thanks
from 4.21 to 4.90
no link here . pls send pm
I have the following:
Hardware 040
Software  0421
Device 5E0035874A
Can someone please pm me the latest firmware and instructions?  Is the VCDS part necessary as I don't have it?
Thanks in advance
djmalin, upthealbion have pm
Pls send pm
Device Part number:  5e0035874A
HW: 040
Software 0421
can someone give me the link please :)
Hey! Anyone here available who can share the link for the latest Amundsen MIB 1 software update? Thanks in advance!
Bol by som rád, keby mi niekto mohol poslať odkaz na aktualizáciu!
Hardvér 038
Softvér 0132
Zariadenie časť 5E0035864
Mnohokrat dakujem
4 hours ago, petermio said:
Opatrne s tímto HW já aktualizoval jednotku 5E0035864 a nedpadlo to dobře.
update pro jednotku 5E0035864A není kompatibilní s jednotkou 5E0035864. Nakonec mně oprava stala skoro 100€.
Výměna memory v jednotce přímo v Panasonicu.
Hardvér 038
Softvér 0132
Mnohokrat dakujem
Dňa 6. 7. 2018 o 15:27 petermio povedal:
I would be glad if someone could send me an update link!
Hardware 038
Software 0132
Device part 5E0035864
Many thanks
Edited by petermio
On 6. 7. 2018 at 20:17, Frydom said:
Frydom   Ďakujem za upozornenie na problém ...
A dá sa aj tento môj soft aktualizovať ?
Tu na fore píšu že sa dá, len treba ten správny tam dať.
Hello!
After downloading both of the archives, there are 2 folders mib0490
with different dimensions: one has 4.99 GB and the other one has 1.97
GB. Wich one should i choose?
Hi,
Can some one please help me with software update for my amundsen unit.
Looking forward to some reply.
I have Octavia 2013.
Thank you
Hi,
Could someone send me the link for the software update, currently running:
Hardware:041
Software:0435
Thanks very much
Mick
On 11/08/2018 at 06:03, Vink17 said:
Hi,
Thank you
20 hours ago, Raffaz said:
Hi,
Hardware:041
Software:0435
Thanks very much
Mick
Send me a PM guys.
How do you tell the difference between MIB1 and MIB2 units?
Mick
