Amunsen MIB1 Firmware
On 14/08/2018 at 18:55, Raffaz said:
How do you tell the difference between MIB1 and MIB2 units?
Mick
What year is you car?
  • Replies 982
  • Views 227.6k
  • I have updated my Amundsen from 0435 to a newer version which can be found on the net. I don't want to share the link here to avoid deletion but I will kindly PM it together with the instructions.
  • If you have instructions they'd be appreciated
  • Guys,   From now on a newer firmware is available for MIB1 Bolero/Amundsen. I have installed it without issues. Users previously contacted me: check your PMs. Others just contact me for the deta
Hi,
Car is 2015
Mick
11 hours ago, Raffaz said:
Car is 2015
Then if it's early 2015 (like mine) it will be MIB1, but if it's late 2015 it will be MIB2.
What's the build date of your car? You can see that in the online service information or in the App (on iOS at least).
Vink17 & Raffaz sorted B)
Just checked the app and it shows 11th May 2015, guessing its the MIB1 then
I've MIB1, HW 041, SW0435. Can someone please PM me 0490? Thanks!
On 04/07/2018 at 14:18, neomancer said:
Device Part number:  5e0035874A
HW: 040
Software 0421
can someone give me the link please :)
still looking if someone can help me out..
neomancer Sorted B)
Hi. I too need the MIB1 update file.
Device part: 5E0035864A
Hardware: 041
Software: 0435
I would really appreciate it.
himpinen Sorted B)
9 minutes ago, BATVANVRS said:
himpinen Sorted B)
 You are the man! Thank you!
Your very welcome :thumbup:
Hello guys i would also ask for newer version with instructions please.
Hardware:041
software:0435
thanks in advance
Hardware:041
software:0435
thanks in advance
 You was sent the information before! There is no newer version than 0490 but If you don't have it, I will send it again but please don't keep asking for it if you have not applied the MIB1 firmware update. B)
EDIT: Sorted :thumbup:
Edited by BATVANVRS
Hi, I have:
Hardware:041
software:0435
Please can someone send me the update?
7 hours ago, Adr91 said:
Hi, I have:
Hardware:041
software:0435
Sorted B)
Hi all
I'd really appreciate download of the update - use nav every day for work. Currently HW 041, SW 0435 on mkIII Octavia
I have MIB1 with below version:
Hardware:040
software:0421
Can you please send me PM with download link and howto for the latest update to 0490?
Thanks a lot.
brgds,
FGD
1 hour ago, skodie-me said:
Hi all
Hardware:040
software:0421
Thanks a lot.
brgds,
FGD
Send me PM.
FGD Sorted B)
Skodie-me Sorted B)
Hello,
I have an Oktavia 2018 VRS.
I would like to update the firmware of my head unit to benefit from the last updates for smartlink. (I have some slowness with Android Auto that I use everyday)
Material Reference is : 5Q0035874C
My Hardware is :H41
My Software is :0456
Could somebody guide me to the firmware update instructions ?
Many Thanks,
5 hours ago, bichodoido said:
Hello,
My Hardware is :H41
Many Thanks,
MIB1 Firmware is for Skoda 2013-2015 so this thread won't be able to help you out! you will need to check other threads for your year related Skoda.
Can someone send pm for me too.
5E0035020C
Software Base: H15.17.1518-201405071236
S: 0411
On 12/11/2015 at 11:28, aki78 said:
I have updated my Amundsen from 0435 to a newer version which can be found on the net. :)
VCDS or VAS is needed for the last step of updating (to confirm SW version change and clear some fault codes).
This update is suitable for MIB1 Amundsen and Bolero and can solve some issues (sound quality, FM reception, graphics, touchscreen).
In my case (0435 Amundsen with Canton) I noticed the following:
- far better playback quality (decoding) of lower bitrate mp3's (now it's hard to tell the difference between 192 and 320 kbps)
- some change in EQ frequencies (slightly deeper bass / clearer treble)
- noticeable gain in treble (now +6 is like +9 before)
- some gain in maximum volume without automatic bass limitation
- better shuffle playback algorythm in case of hundreds of mp3's in the same folder (mine kept repeating the same 40-50 mp3's)
- better (but still not perfect) access of SD card on start (occassionally the HU still switches to CD/radio)
I never listen to the radio so can't tell anything about FM reception. :)
UPDATE IS DONE AT EVERYBODY'S OWN RISK!!!
hy aki78! unfortunately I can not send you a message, pls mail me! =(
mralien4c kukac gmailpontkom. köszi, pacsi! ;)
