David's Citigo 2.0
  • Replies 294
  • Views 102.1k
  • Exhaust vid for your ears to enjoy -     I realise it's probably to loud for some, but they did do a dB reading for me static at 3800 RPM and it read 89 so I don't think it's too loud if you wi
  • Footage from yesterday at Bedford trying to shake a Saxo off my tail
  • Big thanks to andsoutham for getting my brake pads the right way round tonight Also shiny things Sent from my SM-G920F using Tapatalk
Are your discs are on the wrong side? The internal vanes look like they're facing the wrong way
Good question, but as far as I was aware, if the vanes are straight, it makes no odds as to which way they do go, some have them facing forward, others facing rear, I found the below online which hopefully makes some form of sense :D
- If the supplier's instructions elude to the need to throw dirt/water/heat out and away from the disc then fit this way...
Name:  discsback.jpg Views: 0 Size:  20.2 KB
- If the instructions elude to having to have constant airflow to the grooves to aid cooling, then fit this way round...
Name:  discsforward.jpg Views: 0 Size:  22.4 KB
The grooves on the disc face can be either way. I meant the internal vanes. Looking at your pic they appear to be be grooved rather than straight? It might have been the angle of the photo though
A small update, I've put some parts up for sale for anyone who's interested in a few bits
I've also gutted the rear a little more and taken the passenger seat out so I can get the leather seats up for sale, the cars also now in a garage away from home so it can get off the drive.
Edited by Hyphons
Looks great stripped
I hadn't intended on it :D I was just going to remove the drivers seat, but then decided to remove a little more whilst I had the tools out
  • 3 months later...
Long time no update, rarb fitted, just, kinda..
Those with a keen eye will spot that it's not all quite spot on, nevertheless, it fits (just) and works brilliantly, it might just be self conscious that it feels much better, but it certainly carries itself round the corners at whatever speed you want to throw it into the corner
  • 5 weeks later...
Got round to swapping out the filter today, this was much needed, its current position probably won't be forever, but the old one was in rubbish condition
Out with the old..
Which was in bad shape..
In with the new..
It's a little excessive for the size of the engine, but who am I to complain? :D it sounds a lot happier.
I can also report the rear anti roll bar is superb, it should have been added a long time ago
Decided to mess about and gut the interior a bit more :D
You'll also note the gear knobs changed back to the VW Up! one and I've fitted the passenger bucket seat ready for a track Saturday. I've actually ordered proper bases for them at a whopping cost of just over £300, but they haven't arrived yet, I was hoping they would've arrived today!
Bit of track action from Saturday
Learning the track and following @BJB540 for a while
And a couple of good runs in the afternoon
And then I had a bit of a moment on the last session of the day
Stripped the car a little more :D
Might add the carpet and sound deadening came out too :)
Having removed near enough all the trims in the car, I realised I had a new problem, closing the boot without putting my hands on the outside (I'm one of those people who literally can't stand hand prints all over the boot from where it's been shut :dull:).
Cue 1 spare tow strap and a void nut from where the wiper motor used to sit, what do you get? A new handle to pull the boot shut :D
Get it on a weightbridge mate see how much she weights :)
Nothing to see here B)
Another box arrived, this took a while to get here B)
Bit of TLC done over the weekend, you'll remember in this post:
All the wiring dangling about the place, this was for the W8 light and the interior light as well as the dash cam front camera and GPS camera, all that wiring is no more
Used some cheap sticky back wiring clips to tuck the dashcam wiring out the way as a temporary fix, those with a keen eye will see there's a new dashcam, I finally replaced the absolute rubbish Koonlung front and rear camera with a used DOD RC500S, which is the same one I run in the Fabia
There's a bit of foam in the rear that's used to hold the rear seatbelt wiring in place, I finally got rid of this and took the no going back route of chopping back the rear seat belt wiring itself, this'll eventually be taken back as far as possible.
Before:
After:
You can also see the new seat mount on the passenger side that's fitted, I need custom side mounts made up as there an inch shorter than I need them to be.
Last photo for you, you'll spot the stupid and useless tow hook that I added ages ago has finally gone, this'll be replaced with either a strap or a tow eye, probably drilled straight into the rear crash bar, the rear bumper will need to come off for that
Looking tidy
looks good mate, I'm sure ive got a big towing eye somewhere at home...
  • 3 months later...
@Hyphons
Did you ever get it on the Scales ?
  • 4 months later...
On 27/12/2018 at 19:13, BashRacing said:
@Hyphons
Interested to know that as well.
Hey buddy, absolutely loving the build and where it’s going ! Great job
just curious as to where you got the rarb from ?
