Blower fan no blow
yes, can't tell you what the readings were, at the moment, but all different.
  • 7 months later...
  • Replies 63
  • Views 30.7k
  • Eurocarparts...
  • Didnt have to remove a thing other than the fabric stuff held up by 2 stud things.   pressing the heater pipe forward really helped, put fingers in where arrows are in photo and pull lightly
  • Hi all from Downunder.  My extremely well behaved 2011 Superb 11 V6 AWD has only done 102,000 kms, as it is not my only vehicle.  Never had a fault except for a passenger seat electric control module
Hi, just a quick post to say thanks to all for posting this info here.  My Cimatronic heater blower started going intermittent about 2 weeks ago, then just died.  Had the car in for service last week and dealer wanted €660 to replace it!  Got one online, followed instructions here and saved myself €400.  All working great.  Thanks everyone!
Just saw this thread after a search.
Drove 3hrs in my 2011 superb today and the car was steaming up, no blowing from the vents. Barely a breeze.
Got home, popped back out to shop. This time fans were blowing a gale.
Seems like some intermittent issue. My car has had the fan motor replaced in past according to history. Maybe its been a dodgy connection all along.
I will investigate over Christmas
After the help in the topics earlier and the advice followed a new problem has come to light, which is that the fan doesn’t come on immediately when you want it to?
I can still get variable speed and temperature but just it can occasionally take 3-4 minutes before the fan will come on. Very frustrating at this time of year - none more so than when I had to do the 2am rush to the hospital with wife in labour on the first night there was ice inside the car!
thanks in advance
Hi - bump for ideas please?
I’ve got that going on too at the moment. Takes a couple of minutes to come on.
Coincidence or otherwise, I replaced my original fan that failed about a month ago with a new cheap item off eBay.
Thanks so much for this, just fixed the fan blower on my superb mk2 by taking it out, applying a (fair) bit of WD40 and it's working!
Truth to be told, it still takes a bit of force to rotate the fan on the unit, so replacement seems imminent.
Had a call with Skoda dealer in Cork (IE), was told it'll be 100EUR just to have a look at it (diagnostics), said I'll get back to him...
Anyway, even if it does fail, I took some pictures of the fan unit, so it should be safe to order it from eBay and replace when it dies a final death.
https://photos.app.goo.gl/KKwmJUGVUL7w49pz6
As I was afraid, it stopped working again :)
Looks like I need to replace the fan part, can I just take the electronic (resistor?) part from this one and order just the fan?
Hi, I have just removed my blower motor. Should it spin freely or should there be some resistance? mine barely turns.
A quick reply would be great as I have the car in bits at the moment :)
Needs to spin freely, had the same problem and got the blower fan replaced last week.
Many thanks. I think this one is done then. It’s pretty stiff. I’ve done half a can of contact cleaner and wd40 but no improvement.
Local car shop sourced me a new one within half an hour. £115 and I fitted it all back together inabout 10 minutes. I have wind again!
anyone got a VCDS within half an hour of Bolton that can reset my airbag fault (unplugged when I removed the glovebox) because my MOT is at 4:15
pretty please!
  • 3 years later...
Just would like to thank all contributors to this thread.
I too had the dreaded "fan blower no blow" syndrome and was able to fix it thanks to what's been written here. I my case the WD-40 was used to clean the terminals where the loom joins the fan assembly. I've also discovered where the big speed resistor is too; just in case that pops its clogs.
Again, many thanks for helping with what turned out to be a quick fix!  😃
