Security Access Codes
lkallas
Recommended Posts
Hi!
I am really new to this VCDS stuff but I have come across with something called security access codes that are needed to access modules. Where can one find the correct security access codes for the vehicle?
Thanks in advance!
Link to comment
Share on other sites
VCDS normally provides any security access codes needed for common procedures.
If you're trying to do something that's needs a code that's not provided, asking on the rosstech forums is your best plan.
  • Like 1
Link to comment
On 28/08/2018 at 22:11, lkallas said:
Hi!
Thanks in advance!
Same issue here, code 12345 works for some things but for engine it doesn't work.
Link to comment
If Ross-Tech know the security access code(s) for a module then hovering the mouse over the box where you enter the code will show them.
Link to comment
@SWBoy thanks but I’m using obdeleven as it’s just a home project for me. I’m guessing obdeleven is not well liked by Ross-tech? As there are not that many guides/help for it.
Link to comment
While VCDS and OBDeleven are both diagnostic tools they are not developed by the same companies, and neither get support from VAG.
Ross-Tech write and support VCDS, if you use OBDeleven then you need to contact obdeleven.com for support.
  • Like 3
Link to comment
@SWBoy thanks, yes I see what you mean, but I thought this was a Skoda support forum? So I don't understand why I can't ask here for obdeleven advice. In all seriousness am I missing something?
Link to comment
Vcds can only show a login code when it's connected to a module so unless someone has vcds, the same module and it's running the same software version, there is no guarantee that it'll work.
Given you've got given any details it's hard to help.
Even then, contacting obdeleven may still be quicker :-)
  • Like 1
Link to comment
You can definitely ask for OBDeleven  advice, but in your first post you said
Quote
so you were asking for help on VCDS not OBDeleven :)
Anyway now that's cleared up, the security access codes are something that VAG tend to keep secret and have to be discovered (often by trial and error) for each and every module that uses them (not all do), so there is no definitive list available AFAIK.
What specific modules do you need a security access code for and what are you trying to do that you think needs one?
  • Like 1
Link to comment
I see the confusion, the first post wasn't by me, i never asked for vcds help. But anyhow a fair assumption :)
... the security access codes are something that VAG tend to keep secret and have to be discovered (often by trial and error) for each and every module that uses them (not all do), so there is no definitive list available AFAIK.
Yes I guess VAG do not want us poking around. I was having trouble yesterday with coding the audi throttle mod. Strange, I went in today and it worked first time via long coding and didn't ask for a security code. I also coded the "driving profile switchover" as per this thread, the code 19249 worked :)  but have not noticed any difference with either after a short drive around.
This is what I have coded so far (in reverse order), thanks for the replies!
OBDeleven vehicle history log
Date: 2018-09-02 19:34
    VIN:
    Car: Skoda Octavia RS
    Year: 2018
    Body type: Estate
    Engine: CUNA 135 kW (184 HP) 2.0 l
    Mileage: 1902 KM
Adaptation
    Control unit: 44 Steering Assistance
    Name: Driving profile switchover
    Values:
            Old value: Incremental, controlled over time
            New value: Direct, controlled over threshold value
    Mileage: 1904 km
    Date: 2018-09-02 17:40
Long coding
    Control unit: 01 Engine
    Old value:
        011D0012032501080000
    New value:
        021D0012032501080000
    Mileage: 1904 km
    Date: 2018-09-02 17:32
Adaptation
    Control unit: 17 Dash Board
    Name: Ignition active message, actuator
    Values:
            Old value: Driver door
            New value: No display
    Mileage: 1904 km
    Date: 2018-09-02 17:27
Adaptation
    Control unit: 09 Central Electrics
    Values:
        Spiegelabsenkung bei Rueckwaertsfahrt:
            Old value: not active
            New value: active
        Menuesteuerung Spiegelabsenkung:
            New value: active
    Mileage: 1902 km
    Date: 2018-09-01 20:26
Long coding
    Control unit: 52 Door Electronics Passenger Side
    Old value:
        001C00208001048000001100
    New value:
        001C00208C01048000001100
    Mileage: 1902 km
    Date: 2018-09-01 20:20
Long coding
    Control unit: 5F Information Control Unit
    Old value:
        03735201FF00000041111201008800002F0209C601200500CF
    New value:
        03735201FF00000041111201008800002F0209C6012005008F
    Mileage: 1889 km
    Date: 2018-09-01 15:22
Long coding
    Old value:
        27A5090869808600010A6B021001000000000000
    New value:
        27A5090869848600010A6B021001000000000000
    Mileage: 1889 km
    Date: 2018-09-01 15:21
Long coding
    Control unit: A5 Front Sensors Driver Assistance System
    Old value:
        0203070200000401000213408150A80084000E200000
    New value:
        0203070200000401000213408150A80094000E200000
    Mileage: 1889 km
    Date: 2018-09-01 15:19
Adaptation
    Values:
        menu_display_road_sign_identification:
            Old value: Not activated
            New value: activated
    Mileage: 1889 km
    Date: 2018-09-01 15:15
Adaptation
    Values:
        traffic_sign_recognition_0x21:
    Mileage: 1889 km
    Date: 2018-09-01 15:11
Adaptation
    Control unit: 6D Deck Lid Control Unit
    Name: Warning signal when closing with button
    Values:
        Rear lid unlock button in remote key:
            Old value: active
            New value: not active
    Mileage: 1862 km
    Date: 2018-08-28 19:26
Adaptation
    Name: Activation using rear lid remote unlocking switch
    Values:
        Tap function for closing:
            New value: active
    Mileage: 1862 km
    Date: 2018-08-28 19:24
Adaptation
    Name: Activation using rear lid opening button in remote key
    Values:
            New value: active
    Mileage: 1862 km
    Date: 2018-08-28 19:23
Adaptation
    Name: Warning signal when opening with button
    Values:
        Rear lid remote release button:
            Old value: active
            Old value: active
    Mileage: 1862 km
    Date: 2018-08-28 19:21
Adaptation
    Control unit: 19 Gateway
    Name: Start/stop start voltage limit
    Values:
            Old value: 7.6 V
            New value: 12.0 V
    Mileage: 1862 km
    Date: 2018-08-28 19:11
Edited by 877
Added coding log
Link to comment
  • 3 years later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
