Octavia 2.0 TSI differences
Does any one know the technical difference between 2.0 190 TSI and the RS245 2.0 245 TSI .
Is it hard ware as a different turbo and so on they use in this case or do they rely on soft ware tuning ?
Software that’s it
If thats the case than 2.0 is the best buy ever, better than 1.8 was, so much cheaper than vrs.
1 hour ago, Tim1631 said:
Software that’s it
So the 190 definitely has the IS20 turbo? I've seen talk of a possibility it has the IS12 but nothing definitively conclusive.
The 2.0TSI 190 coming in the Octavia is the same engine as the new Seat Alteca/VW Aerton  which appears to map to about 260 max looking at tuners websites so much much less than the 2.0TSI in the VRS.
https://www.celtictuning.co.uk/services/performance-stats/audi/a4-b9-2015/petrol/2-0t-fsi-187-bhp-2015-ECU-remap-chiptuning/stage-1#t3-content
https://www.sedox-performance.com/tuning/cars/seat/ateca/2-0-tsi-190hp-320nm
Celtic and sedox claim 300-320 for the VRS 220, 230 and 245. (Revo dont seem to have a map for the 190 yet, they would be my normal benchmark for comparison)
https://www.sedox-performance.com/tuning/cars/skoda/octavia-iii/2-0-tsi-220hp-350nm
I suspect a smaller turbo in the 190ps version.
I read somewhere that the upgrades from standard for the 245 is a different turbo (or maybe just turbine wheel?), Inlet manifold and injectors. As usual I could be quite wrong :)
In my own experience the 1.8 gave 230bhp at stage 1 whereas my 2.0 gave 302bhp.:evilgrin:
I can't find any info on it, but you might find the gearboxes are different too. The 190PS could be paired with the weaker 7 spd box while the VRS has the 6spd.
2.0 TSI 190 HP is different from the 245 version. Its using Miller cycle compression and has over 11 in comp ratio.
Its a more efficient version than the 245.
All MY2019 Octavia's get a 7 speed DSG if you want an auto.
Smaller than 2.0 get the DQ200 dry clutch.
All 2.0's get the DQ380 wet clutch.
No 6 speed DQ250 DSG anymore.
Lee
Ah thanks for enlightening me. I wish Skoda would just write what box it comes with on configurator.
I suppose it is their belief it is not of your concern.
On VAG there is a simple rule to know what DSG type is paired with with engine:
<250Nm dry
>=250Nm wet
I think there is some point in this, I investigated the turbos we buy to Scania from Cummins Turbo Tech in Huddersfield.
They use different turbine wheels and ceramic bearings to get higher speed, those bearings are expensive.
<250Nm dry
>=250Nm wet
Although VAG have 7 different wet clutch gearboxes, 6 of which are in production.
DQ250, 6 speed transverse
DQ380, 7 speed transverse
DQ381, 7 speed transverse
DQ500, 7 speed transverse
DQ511, 10 speed transverse (Production suspended)
DL382, 7 speed longitudinal
DL501, 7 speed longitudinal
The Turbo on our Cummins 6.7l QSC is rated at 127,000RPM full chat! Seen a Borg Warner Prototype rated at 140k too but not in production yet. It’s an art all itself!
Lee
This is really useful to know - thank you! Please can you tell us where you find the information?
On the bottom of a BEER MAT. LOL.:D
4 minutes ago, kens said:
The pricing & spec brochure tells me that the transmission is a 7 speed sequential automatic. But, unless I'm missing something, I don't see anything about dry clutch vs wet clutch or any mention of DQ200/DQ380.
 The 2.0 exceeds the torque limit of the dq200
LOGICAL REALLY.:dry:
On Seats website here in Sweden.
SEAT Atecs 2.0 TSI 190hk (140kW) 4Drive with the DQ381-7A (RSA)
Seat is always showing the gearbox information, Skoda never does.
  • 6 months later...
Hi,
I have 2.0 140KW
Differences :
Turbo is20 vs is38
Engine 190hp vs 245 hp
Differential - electronic in 140KW - LSD in 245
Coilovers
DCC
It's completely different car.
1 hour ago, martinznet said:
Hi,
I have 2.0 140KW
Differences :
Turbo is20 vs is38
Coilovers
DCC
The RS245 has an IS20 turbo
