Lowering
@JR RS Thank you for your advice :)
I note the Eibach's lower the front more than the rear, whereas the H&R's lower both by the same amount. Why would I want to lower the front more, when it's the rear of my car that sits naturally higher? Won't this just accentuate the difference?
Both sets are comparable price wise, what would you go for, especially as I'd like to limit the lowering to produce a 'tasteful' aesthetic?
Just for reference, I do not have DCC (I don't believe it was available on this engine/model) and it's just FWD (I believe there was a 4x4 1.4TSI variant).
  • Replies 102
  • Views 47.2k
  • Finally the Eibach Pro-kit is in!! woOot 😁 Its less wallowy now in Normal mode.  It's good now. Sport mode is nice n firm.  Comfort mode is still comfortable 👍 Before - 690mm from fe
  • Now Eibach pro kit installed. Forgot to measure before installation but to me looks better and drives much better  Next I'll have to start looking for new wheels.
  • Currently on b6 with prokit springs (octavia) and as newbie says they offer support and control but without being overly crashy/firm.  Used the B6 on stock springs for a while too and definitely somet
The Superb's body by design is nose down, rear up, liftback & wagon.
Ur not exaggerating it with the Eibach springs....if any, it will b minimal.
Mine sits evenly (based on the wheel arches) front & rear on the Eibach Pro-kit springs.
i have answer :)
Eibach Pro AWD springs on 220ps FWD ŠS with four passengers on board
-> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/page/3/#findComment-5681084
Eibach Pro Kodiaq springs on 280ps AWD ŠS
-> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#findComment-5854160
@MartiniB Thank you for your reply. I'm not the sharpest tool in the box, so can you help clarify whether it actually helps with my desire to only lower my car by 20mm (max 25mm)? Lowering springs specifically for my vehicle all want to lower it by 30-35mm, which is too much. I was wondering whether I could employ shorter (?) springs designed for a different variant or even model (maybe one that sits lower out of the factory e.g. maybe a SportLine model?) so as to achieve my desired look.
Eibach Pro F11-79-008-01-HA will add 10-15mm lowering on FWD Superb
@MartiniB We're getting closer! 😄 So that code is for just one spring, would I need the same for the front and back? The kit that includes the part you have listed is E10-79-008-01-22, which also includes F11-85-012-03-VA. This kit claims to lower the compatible vehicle (Yeti) by 30-35mm, so how does it only lower my vehicle by 10-15mm? Please excuse my ignorance, I really don't know anything about the mechanics of these things, but I imagine I'll understand the concept once informed appropriately.
Yeti is on longer springs as standard.
@netman82
i can suggest rear springs due weight isn't so much different on the rear axle,
but front springs, which were confirmed on my 2.0, will be too hard and high on your 1.4 Superb
for front axle you have to play lottery by your self, as i did, looking in to table,
both red, will give less lowering on your 1.4 than on 2.0
Thank you @MartiniB The options in red appear to be shorter in length according to your table, so surely they will lower my car the most? Perhaps I have misunderstood what length means in this context.
@netman82
if 11-85-042-03-FA lowers 2.0 engine for 30 mm, then 1.4 will bee 10-15 mm higher
length is without load
@MartiniB
Ok, so with your spreadsheet in mind, 11-85-042-03-FA may lower my car by 15-20mm on the front end, and 11-85-041-01-VA may lower it further, perhaps 25-30mm?
You mentioned above that you can suggest rear springs, which would they be?
Given these springs aren't specifically for my vehicle, will they likely make the ride firmer, as presumably they are designed for heavier vehicles?
F11-79-008-01-HA for rear axle
Before - 690mm from fender to ground (front & rear)
After - 670mm from fender to ground (front & rear)
Should drop another 5mm or so in the next few weeks.
I'm very happy with it.
Not too much.
Not too little.
Top half of each pic is After.
Bottom half is Before.
Hi @JR RS
Im also looking for the right solution for my Superb and wondering which EIbach lowering kit you went for.
The E10‑85‑042‑02‑22 or 04-22
1 hour ago, rsna said:
Hi @JR RS
Check out his project thread here - he uses E10‑85‑042‑02‑22 according to that
Thanks.
By mistake, when ordering, I selected the 04-22 and im trying to figure out if it would still be suitable for the car. (1.4 IV with DCC)
Do you by any chance know if i can move forward without getting into trouble with the dcc
@rsna
my guess is made by looking to springs specs -
with E10-85-042-04-22 kit iV front will have ~ +5 mm and rear ~ +25 mm instead E10-85-042-02-22
in any case that will be lowering when compare to OE
E10-85-042-02-22 = F11-85-041-01-VA + F11-15-007-04-HA
E10-85-042-04-22 = F11-85-042-03-FA + F11-85-016-10-HA
you can start by install just rear, that is cheaper
8 hours ago, rsna said:
Thanks.
Ur DCC will still b happy, however ideally u need to perform a DCC Recalibration procedure after installing the springs.
These r the various Eibach parts numbers for the Superb mk3.
Sedan/Liftback - 3V3
Eibach ProKit 35/30mm
E10-85-042-01-22 (985kg / 1220kg)
Superb 3V3 Hatchback 1.4 TSi
E10-85-042-02-22 (1100kg / 1220kg)
Superb 3V3 Hatchback 2.0 TSi 2.0 TDi
E10-85-042-03-22 (1180kg / 1220kg)
Superb 3V3 Hatchback AWD 2.0 TSi 2.0 TDi
E10-85-041-04-22 (1070kg / 1220kg)
Superb 3V3 Hatchback 1.6 TDi 2.0 TDi 1.8 TSi 2.0 TSi
Wagon/Estate - 3V5
E10-79-012-01-22 (985kg / 1250kg)
SUPERB Kombi 3V5 1.4TSi
E10-79-012-02-22 (????kg / 1250kg)
SUPERB Kombi 3V5 1.6 TDi 2.0 TDi 1.8 TSi 2.0 TSi
E10-79-012-03-22 (????kg / 1250kg)
SUPERB Kombi 3V5 2.0 TSi 2.0 TDi
E10-79-012-04-22 (????kg / 1250kg)
SUPERB Kombi
3V5 AWD 2.0 TSi 2.0 TDi
@MartiniB
You're probably right – the plate on the car shows the current specs:
Front 1130 kg
Rear 1200 kg
The ratings from E10-85-042-04-22 is 1200 kg front and 1250 kg rear, so it's a difference of 70 kg front and 50 kg rear.
I'm hoping it'll still settle okay. Maybe not the full 30–35 mm drop like the rates say, but that’s alright with me.
@JR RS
Thanks, I will have it done when everything is replaced.
Further information.
The Tüv states that the F11-85-042-03-FA + F11-85-016-10-HA are the only one compatible with the IV (PHEV)
Here in DK it can be an issue if you need to have the car through an MOT and the person is a jerk.
In this case all documentation needs to be in order.
Let see how everything turn out. Pictures will follow when installed, and thank both of you for your time.
Just to add my 10p worth.
I’ve ran both my previous diesel 4x4 (white one) and my current 272 (4x4) with koni special actives and h&r springs for many many miles and never had an issue.
The konis are a great shock and ride is way better then standard sportline spec.
Fully loaded still really good ride and my current set have done over 120k miles with no issues
Hey again,
Installed and rolling .... Overall a much better feel compared to stock. No more wobbling around like being on a ferry in rough seas. 😂
@MartiniB as you predicted, it's sitting a bit lower in the rear than the front.
The TÜV papers mention that the 11-85-016-10-HA should be installed with a thicker spring plate on top when used on a heavier car.
Anyone who installed this and noticed a slight raise in the rear?
Hmm, nevermind me asking for the thicker top plate. This is most likely already installed when it a IV 🫣
Hey again,
I hope u didn't put the E85 springs in ur wagon.
If u did, that would explain the lower rear end drop.
E85 is for the liftback/sedan (3V3), which has a much less heavier backend.
E79 is for the wagon (3V5). Hence if u put sedan springs at the rear, it will drop more.
@JR RS why isn't the 79 then stated in the tuv for the IV estate?
And yes they are mounted 🫣
