OPS display disappeared
Thanks for the tip, did manually change byte 21 value from ED to 6D but as you can see below still reports issues with the wiper motor.
As for the Webasto, it is fully functional, I did switched it on a few minutes before entering the car and ran the basic settings 011 steps.
But the can still reports errors.
As for the OPS display, still not there. Drove a little bit the car, used the assisted parking functionality, but still no display. Depending on the Columbus
selected functionality (radio or map), display stays on the selected functionality.
See below tonight's VCDS dump.
uesday,30,July,2019,21:17:21:16291
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
http://www.Ross-Tech.com
VIN: XXXXXXXXXXXXXXX   License Plate:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 22 25 2B 2E 36 37 42 44
          46 47 4F 52 55 56 62 69 6D 72 77
VIN: XXXXXXXXXXXXXXX    Mileage: 122640km-76204miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (0-32-CDVA)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 CF    HW: 03H 907 309 C
   Component: 3.6 FSI EU5   H04 5770
   Revision: MFH04---    Serial number:
   Coding: 001D0012242600000000
   Shop #: WSC 33361 790 00060
   ASAM Dataset: EV_ECM36FSI01103H906023CF 001002
   ROD: EV_ECM36FSI01103H906023CF.rod
   VCID: 68884CD012F02177629-803C
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 016 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4002
   Revision: 05652104    Serial number: 00001307251298
   Coding: 0000020
   Shop #: WSC 33361 790 00085
   VCID: 127C4E38486C7BA76CD-8046
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 843DA016192400FA211305E7981F0041350950
   Shop #: WSC 12345 123 61029
   VCID: 7DA60D846DF294DFA1F-8028
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0194240129
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02013
   ROD: EV_KESSYPQ35G_A02_SK46.rod
   VCID: 3430E8A01EB895971E1-8060
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 CG    HW: 3T0 907 044 CG
   Component: Climatronic   H19 0607
   Revision: 00001008
   Coding: 0010000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 79AE1994795AA8FF8D7-802C
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 AN    HW: 1K0 937 087 AN
   Component: BCM PQ35  H+  112 0771
   Revision: AF112771
   Coding: 40190ABBE80508C0400800C0710089EC4B7100AE776DADF080814004A040
   Subsystem 1 - Part No: 3T1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 28081  26  0700
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 280813 05  54  0403
   Coding: 0630ED
2 Faults Found:
00077 - Windshield Wiper Stop Switch (F229)
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 130
                    Mileage: 122648 km
                    Time Indication: 0
                    Date: 2019.07.30
                    Time: 21:27:06
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01753 - Windshield Wiper Motor (V) Stage 1
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 130
                    Mileage: 122648 km
                    Time Indication: 0
                    Date: 2019.07.30
                    Time: 21:27:06
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J791)       Labels:| 3T0-919-475-V2.clb
   Part No SW: 3T0 919 475 D    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0005
   Revision: --------    Serial number: 56261323500419
   Coding: 158102
   ASAM Dataset: EV_EPHVA2CAS46X0000 001003
   ROD: EV_EPHVA2CAS46X0000_001.rod
   VCID: 3E24CA8820F44FC7F85-806A
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
   Component: J234__LDG VW10 HI   2118
   Revision: 24019000    Serial number: 003LEPHD20GP
   Coding: 0017479
   VCID: 42DCBE78588C2B279CD-8016
   Subsystem 1 - Serial number: 6332MTS616852313
   Subsystem 2 - Serial number: 6342MTS617062313
   Subsystem 3 - Serial number: 6351HTS6QTOP7CKJ
   Subsystem 4 - Serial number: 6361HTS6PQIO7CKJ
   Subsystem 5 - Serial number: 63727TS6OHDK6CKJ
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Component: LENKS.MODUL   016 0140
   Revision: FF010042    Serial number: 20130713201618
   Coding: 1012140000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA60D846D7294DFA1F-8028
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5E0 919 719 G    HW: 5E0 919 719 G
   Component: E221__MFL-PR6  H04 0120
   Coding: 830000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 3T1 920 841 LX    HW: 3T1 920 841 LX
   Component: KOMBI         H09 0811
   Coding: 111F01
   Shop #: WSC 31698 001 1048576
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 147048207EF875977E1-8040
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 5K0 963 272 F
   Component: Standheizer     022 4008
   Revision: 00022000    Serial number: 09029167000000
   Coding: 0021112
   Shop #: WSC 23370 002 1048576
   VCID: 3332EBBC173692AF07B-8066
1 Fault Found:
01406 - No Flame
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 156
                    Time Indication: 0
             Freeze Frame:
                        Start
                    Temperature: 67.0°C
                    Temperature: -48.0°C
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 240813F1000220
   Coding: 359302
   VCID: 7BA2039C73E69AEF9FB-802E
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   Shop #: WSC 00000 000 00000
   VCID: 45D6A56449A21C1FB9F-8010
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H09 0811
   Coding: 000007
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8C36D80CFC136774D-803E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Component: ELV-PQ35      H21 0240
   Revision: 00000000    Serial number: 13000175815003
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3038E4B0EAA0A9B77A9-8064
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7665414159
   Coding: 010100
   VCID: 2B02F3DCC306CA6F4FB-807E
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
   Component: Sitzmemory    H05 3001
   Revision: 00H05000
   Coding: 00003B
   Shop #: WSC 12336 024 394758
   VCID: 372ADFAC0F4E7E8F3B3-8062
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3T0 035 686 C    HW: 3T0 035 686 C
   Component: RNS-MID       H10 5274
   Revision: AB001001    Serial number: SKZ6Z7N5233097
   Coding: 00060002000000811000
   VCID: 3634D2A808448787205-8062
   Subsystem 1 - Part No: 3T0 051 859 M
   Component: EU West V9  7918
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Revision: --------    Serial number: --------------
   Coding: 011D0220DE00001000
   VCID: 52FC8E3884ECBBA72CD-8006
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 197    3501
   Revision: 00H22000
   VCID: 392ED994355A68FFCD7-806C
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0078570
   ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
   ROD: EV_AudioVerst10KanalBNO1.rod
   VCID: 261402E8D864F707905-8072
Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
   Component: EZE_2         H55 1642
   Coding: 050B0500
   VCID: 6FBA27CC379EF64F233-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Serial number: 0123456789ABCDEFGHIJ
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   VCID: 51FE813481EAC0BF157-8004
Address 55: Headlight Range (J745)       Labels:. 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 F    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0111
   Coding: 014A00003F000000
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 372ADFAC0FCE7E8F3B3-8062
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 8E0000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 8E0000
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H07 0415
   Coding: 010C00200000001000
   VCID: 50F884308AE0C9B71A9-8004
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00008030489976
   Coding: 410D000100000000
   VCID: 3038E4B0EA20A9B77A9-8064
Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 E    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0243
   Revision: 41011001    Serial number: 240301001
   Coding: 083301C003
   Shop #: WSC 00874 223 93488
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK46.rod
   VCID: 392ED99439DA68FFCD7-806C
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H07 0415
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007665117447
   Coding: 0101000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2CC6983CDC63E7C4D-806E
End----(Elapsed Time: 01:49, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
I've seen that wiper fault on new cars, is it not just coincidental and you actually have a fault with J400? The limit switch comes up on brand new Rapids and the fix is to replace the motor?
Mind you on those, to get them to work, you need to disconnect J519 with the battery still connected to get them to work again, sounds like your motor is working, just showing a switch fault which is within the motor. Also happens if the wiper frame bushes are starting to seize or iced up wiper blades.
Your battery voltage is too low looking at the log, Don't try making ecu code adjustments with voltage that low, should have a bench power supply.
I would charge your battery for 24 hours to bring it up or you could damage or reduce the battery life.
Edited by 3T51704x4
That's got rid of a couple of faults and the wiper now shows up on the scan :)
I think at this point, I'd try the following:
- charge or take the car for a drive to get the voltage back up
- check the front/rear wipers work in all positions and park properly
- disconnect the battery for a minute or two to 'reset' all the modules
- do a short drive or move the steering from lock to lock and centre it
- clear all the fault codes
See what faults come back and if the OPS now works. I can't see any obvious coding issues that would stop the OPS at this point 😕
Yesterday evening did a short drive (20km) , as it was raining points 1 and 2 were checked :-)
Will check points 3-4 tonight.
I also saw something strange, comparing OBDEleven forums for the Superb 3T
with the first OBDEleven scan output back in May .
In the Forum they quote for navigation system Module 37:
OPS Vision Change
Select Control unit 37 (Navigation)
Control unit Long Coding
Byte 6
Values:
2C = Scoda Octavia
2D = Skoda Octavia Kombi
2C = Skoda Yeti
2D = Skoda Superb
2E = Skoda Superb Kombi
Read more:  http://forum.obdeleven.com/thread/177/coding-adaptations#ixzz5vF5VE6lM
And the long Coding string in May showed:
With VCDS the Long coding yesterday was:
Thus I am wondering if their documentation is wrong or if Byte 6  not being set at 2D would
explain the mystery.
If this is indeed the case, then there seems to be some bug somewhere in the software which at some point changed
values and committed them to the module.
Given the wipers work, the faults might now be flagged as intermittent with any luck.
I believe when byte 6 is set to 00 it'll ask the car what it thinks it is and use those graphics for OPS. I'd leave it as 00. Feel free to try it, just remember to reset the Columbus after coding changes  by holding <  >  star/mic buttons :)
4 hours ago, LBLJ said:
Yesterday evening did a short drive (20km) , as it was raining points 1 and 2 were checked 🙂
OPS Vision Change
Byte 6
Values:
2C = Scoda Octavia
2C = Skoda Yeti
2D = Skoda Superb
Byte 6 has nothing to do with OPS on the Columbus. Byte 6  relates to the DAB radio frequency and DAB inactive setting. I can see no reason why byte 6 should be relevant, unless you're following instructions for a different make or model of car. Something here doesn't add up.
Edit: Indeed, it doesn't add up, because those instructions relating to Byte 6 are for the RNS310 unit.
Edited by Rustynuts
Just goes to show be careful when changing settings, try to stick to Odis or VCDS
I've just read the link provided to the OBD11 forum. It doesn't instill me with much confidence in the product or its support.
Thus tonight the battery was disconnected for 5 minutes.
Time went to zero on the maxidot display
But the radio kept memory of the settings (likely columbus has an in-built battery)
Drove the car a few kilometres so that it could learn about itself (side mirrors would not fold, power window would not work when
long pressing the unlock button, .... )
Performed a scan, no errors reported .... but still no OPS display.
As for the software, I stick to VCDS, did use OBD11 in order to get started and __NOT__WASTE_TIME__ ==> This proved to be a  huge mistake :-( Lesson learned :-)
See below VCDS dump. That car is a mystery
Saturday,03,August,2019,20:22:36:16291
VIN: XXXXXXXX License Plate:
VIN: XXXXXXXX  Mileage: 122800km-76304miles
09-Cent. Elect. -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
Coding: 0000020
Revision: 00H31001
Coding: 030C0C
Revision: 00001008
Coding: 0010000002
Revision: AF112771
Coding: 00D7B7
Coding: 0630ED
Coding: 158102
Coding: 0017479
Coding: 1012140000
Coding: 830000
Coding: 111F01
Coding: 0021112
Coding: 359302
Coding: 0000005
Coding: 000007
Coding: 010100
Revision: 00H05000
Coding: 00003B
Revision: 00H22000
Coding: 050B0500
Coding: 8E0000
Coding: 8E0000
Coding: 083301C003
End----------(Elapsed Time: 01:43, VBatt start/end: 13.8V/13.9V)-----------
Good to see there are no error codes :)
Columbus doesn't have a battery, any settings are likely to be stored in it's EEPROM. the code is stored by the instrument cluster's EEPROM so it's expected to just work after a battery replacement.
As for the windows/mirrors, they just need to learn the end stops. For each window, press down until it hits the bottom and hold for a few seconds, then hold up until it hits the top and hold for a few seconds. That should sort the one touch up/down and probably the folding mirrors on long press too.
Next questions...
- In 10: Park/Steer Assist, can you grab pictures of each byte so we can check the coding looks sensible?
- In 37: Navigation, byte 8 is 10. Might be worth trying 00 and doing the < > * reset, not that I expect it'll make much difference (boot logo?)
edit:
Have you tried doing a factory reset on the columbus using the on screen options?
Edited by langers2k
So, worked on the car yesterday.
Funny thing, or translation error , trying to factory reset the Columbus unit fails.
I got an error message saying "Factory settings not loaded". It is deterministic, tried with engine on or engine off.
Always the same result.
As for the screen captures here they are.
Setting byte 8 to 0 for the navigation system, now I have a beautiful startup screen with the old logo and green color which I tend to prefer to the new one.
In 10, only one thing stokes me, but better ask before than trying to poke around randomly : Byte 0, bits 2 and 3 are set to 10 (if I get the endianess correctly), which is 2 hex or dec.
and from what is described on the drop down it should be 11 which is 3 . Does it need to be set to 3 in order to have the display on the head unit ?
Attached below pictures.
Tonight was working on the car, enabling fog lights as CH/LH as well as emergency rear blinking.
Don't know why, but decided to enable debug on the radio.
Rebooted the radio <>*
Low tire pressure sensor lighted thus drove 2km to the gas station.
Engine stopped the time to inflate the tires.
Engine started, then suddenly display was back as you can see from the picture !!!
What a relief , I can finally see where the obstacles are located :-)
But still is a mystery why OPS disappeared .... then came back.
Problem sovled. But for sure, I won't use  OBD11 ever again, totally lost faith in the product.
Glad it's solved! No idea what caused it though 🙂
