I need Bolero Update :-)
Give me around 5 minutes and I shall send file over.
  • Replies 1.2k
  • Views 216.5k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Thank you for everything
Hi all! Just stumbled on this topic. I also have Skoda Fabia 2015. Is it possible to update my infotainment system?
Thanks for all help
Thanks for all help
Welcome, sadly that is the latest version already installed in the 01xx series of SW Trains
Hi please help me
1 minute ago, gumuskurt22 said:
Hi please help me
It cannot read a file for some reason, was you able to begin any copying stages?
If yes, then maybe just one file/folder is missing or corrupt (looks more missing)
You will need to take an image for me of the SD Card contents
Yes
@gumuskurt22 You are using SD Card, and not phone or USB to SD Card adaptor?
Have you done a full (slow) format on the SD Card, and no errors found?
Here is the original package, and checksum of overall 7z file
Sdcard.device stays on. Is it okay if I buy a new sd card and try it?
Yes buy another card, I presume you are using PC (though issue usually affects maps)
Thank you! the update is complete. but nothing changed. He got hopeful when he saw MirrorLink in the update files, but it still doesn't show up in the menu. Is there anything that can be done to enable MirrorLink?
I am glad that you have cured the firmware.
Speaking of, the firmware as you see, does contain all the features inside, but they are not all activated!
This is done by modifying the firmware to enable SWaP functions to be patched.
I have not done this myself, but Mr Fix has made a very nice video of process.
7 hours ago, varooom said:
Firmware'i düzeltmene sevindim.
Bahsetmişken, gördüğünüz gibi ürün yazılımı içindeki tüm özellikleri içeriyor, ancak hepsi aktif değil!
Bu, SWaP işlevlerinin yamalanmasını sağlamak için bellenimi değiştirerek yapılır.
Bunu kendim yapmadım ama Bay Fix çok güzel bir işlem videosu çekmiş.
How can I find out if my unit is compatible?
This is written under the YouTube video in his notes, along with links
This method will work only on MIB2 Standard unit, made by Technisat/Preh, with navigation, with firmware version within the 01xx - 04xx range. Other unit (MIB1, MIB2 HIGH, Delphi, non-nav, firmware 05xx) are not supported by this method.
This is your firmware
MST2_EU_SK_ZR_P0369T
Being 03xx, you are in the range, and the T=Technisat model you have.
9 minutes ago, varooom said:
Bu, notlarında YouTube videosunun altında linklerle birlikte yazılmıştır.
Bu yöntem yalnızca Technisat/Preh tarafından yapılan, navigasyonlu, 01xx - 04xx aralığında ürün yazılımı sürümüne sahip MIB2 Standart biriminde çalışacaktır. Diğer birimler (MIB1, MIB2 HIGH, Delphi, non-nav, firmware 05xx) bu yöntemle desteklenmez.
Bu senin donanım yazılımın
03xx olarak menzildesiniz ve sahip olduğunuz T=Technisat modeli.
Does that mean it supports it?
Yes, the tool works with any 01xx 02xx 03xx 04xx firmwares
I have never used the tool, so cannot support many questions, have to watch video guides on process.
Thank you for you aşk supports
Hey @pab567@RomanB & @varooom,
I've been recently following this thread and noticed you guys are the leading experts in the matter.
I tried updating my Skoda Fabia 2015 Bolero system by Technisat.
I'm corrently running the following:
440887041_SkodaFabia2015.thumb.jpeg.b16fce2fcea00425a65186d3bfe59300.jpeg547802958_SkodaFabia2015(1).thumb.jpeg.3bdabb0b3c1ca44033846ccdd6db6eba.jpeg
If i understood correctly the latest firmware for my system is the 253?
I've downloaded it from the "mibsolution" link @RomanB provided and extracted it into a usb thumbdrive, which was formated to fat32.
As I go to update through the "service menue" I encounter the following error:
"Error file access
Code 15
Cannot find the correct medium"
Could any of you assist me as of what is going wrong and how to do it correctly?
I've tried 2 different USBs and also the older version 245 & 252 with the same error occuring.
Any assistance would be very appreciated.
Thanks in advance!
@MaShu Stick files onto SD Card, and forget USB!
Remove all USB and other cards from car.
Use battery support, or start the engine before update, do not start engine during update, it needs stable power for up to 1 hour, usually 20mins average time though.
That should make success.
@varooom i dont have an SD card reader, or cant seem to find it anywhere(glovebox, handwrest, media panel, etc).
is a USB sd card reader good enough?
nvm i found the SDC slot, will try it out tomorrow and update.
Thanks!
@varooom worked like a charm!
Thanks alot!
Hi, Please can you help me to update my software?
My software train is as follows:
No update, you have current
Hi 5GD 035 280 B multimedya Skoda rapid 2016 spaceback
Is it compatible?
