I need Bolero Update :-)
2 minutes ago, tyusaf said:
Thanks - and is it worth updating, or no real benefit?
haven't had any problems so far with 2 phones and carplay, but i haven't upgraded to iOS 16 yet either
I have updated my own to 0253, you can do this if you wish.
They don't add features, but fix things like Bluetooth, or other general system stability.
So just let me know if you wish to use firmware, happy to help if you need it.
  • Replies 1.2k
  • Views 224.1k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Yes, if it's just a USB update, that would be appreciated - won't have to touch it again for the next 3 years...
SD Card job, not seen anyone that ever got the USB to update it.
Does the Fabia Bolero have an SD card slot?
I can't find one anywhere and the manual isn't helpful - "not applicable to the Fabia model"
Take a look in glovebox area, might be hidden away somewhere like that.
After you do update, you can use VCDS to clear an SVM fault (but not a fault that will cause trouble)
I have infotainment 5qa035846 unit I updated the firmware from 0252 to 0253, then I tried to update to 0369, but I get a message that I have an old version of the software. What update should I upload now so that I can switch to soft version 03xx and will you make the file available for such update, thanks for help
2 minutes ago, Tom_Seat said:
You don't jump from 01xx to 02xx, 03xx, 04xx or 05xx
If you are on 02xx, then you stay on that series (otherwise you could brick the unit)
Yes if you know what you are doing you can change one series to another, but not worth it unless you have way to recover unit.
Hi everyone,
just signed up to the forum and I'm looking to do all the updates on my car radio. I have a 2015 Fabia with a Bolero system. can someone point me in the right direction to the update files?
Thank you in advance.
System Information
Device part: 5Q0035820
Hardware: H11
Software: 0138
Media Codec: 1003.113.1.15 prod
Installed SW Train Version: MST2_EU_SK_ZR_P0138T
Installed SW MU Version: 0138
Part number: 5Q0035820
Software Version: H21.50.93_STD2_EU
VIN: TMBFJ6NJ5FZ061912
12 minutes ago, iFink said:
Hi everyone,
System Information
Hardware: H11
Software: 0138
VIN: TMBFJ6NJ5FZ
You have the latest version for that software train.
Thanks for your speedy response 👍
Hi all,
I'm looking to update the software on my unit to fix intermittent crashes and possibly 'ghost touches' during cold weather. The dealer requested a £70 diagnostic fee to begin, which I kindly declined.
Is there an update available for my unit? If so  please provide a link.
Would updating deactivate any features?
Regards
PXL_20221020_162110569.thumb.jpg.e827b58868c6f7201d3c1f12038af239.jpgPXL_20221021_122420077.thumb.jpg.897eab0adaecb42cdce7af8648de8656.jpg
1 minute ago, TSiTorque said:
Hi all,
Regards
Keep your £70 in your pocket, will send you a link to download and install yourself.
Usually nothing is lost in the process, unless unit was "hacked" to enable something it never had.
Just to let everyone know - the update went fine on my Bolero - took 30 mins
at the end of the update it showed a screen like "connect your dealer diagnostic software", but there was an exit option. It rebooted again, and working fine.
Thanks again to varooom for the firmware
Hello I hope for the radio gibts an update would be really good see pictures attached!
Yours sincerely Nj3turbo
You can update to 0138 version if you wish.  And you can dust car while it loads, especially below the heater and fan speed knobs for the air temperature sensor 😁
will be done ;)
can i also take a usb stick for this? Since he somehow does not recognize sd card or no update package. I must say that this is one of the first MIB2!
Do you guys maybe need a serial number or something?
Can you take a picture of the contents of your SD Card?
Normal is single file in root, and then about 30 or so folders.
Previously I had the folder MST2_EU_SK on Drive F.: , there was exactly the same.
That F Drive looks perfect, in root there is metainfo2.txt (or some name like that)
And is FAT32/exFAT format?
In car, you are in engineering menu, where you see existing software train value?
Now I would have to ask stupid, this engineering menu I find how? If I press long on the button menu, I come into a support menu I say cautiously. And in Setup and Information I also find something similar.
It's this menu, so you can see the update button at the top
1 minute ago, varooom said:
Es ist dieses Menü, also können Sie die Update-Schaltfläche oben sehen
Yes exactly I can see and also the button update I can click and also the SD card and then he grumbles around. No package available. Have just looked if I find the metainfo2.txt. It is also on the SD card. Something else, how long does such an update take?
This is the structure I see, and should be on SD Card
Update depends on amount of changes, as you are on 0137 you may find it's quick.
Most updates take 20-40 minutes as depends on SD Card speed.
3 minutes ago, varooom said:
Dies ist die Struktur, die ich sehe, und sollte auf der SD-Karte sein
Die Aktualisierung hängt von der Anzahl der Änderungen ab, da Sie auf 0137 sind, werden Sie feststellen, dass es schnell geht.
Die meisten Updates dauern je nach Geschwindigkeit der SD-Karte 20-40 Minuten.
This is exactly how the structure looks. Will try it with USB stick tomorrow and would let you know tomorrow. Maybe I can find a few more photos that would help you. Until then....
