I need Bolero Update :-)
I'd like to update my swing radio please, could you send me an update link please ? Does the language have any importance ?
Thanks !
Thanks !
  • Replies 1.2k
  • Views 217.8k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
14 minutes ago, Will1113 said:
Thanks !
Yes I can send a link, from memory you can update to 8755 version.
Can anybody tell me if there is an update for this cheers
I am 99.99% sure that there's 0253 version, but you should press and hold Menu or Setup button for 10 seconds to find your Software Train information (this also has the firmware update button)
3 hours ago, Philsko said:
I will send you a PM in a few moments.
Hi guys, here is the little tease ;)
I have now done the following, made the folder structure on a stick. And tried to push the update without success! Attached is a picture of the service information from the radio, maybe it's different?!
On 06/11/2022 at 15:00, nj3turbo said:
Just to remind you, that this is the correct screen to update firmware.
Hi, I have software version 8740 and looking through this thread looks as though I need the 8755 update. Is there a link to that anyone can provide? Or is more information needed? Would be greatly appreciated
I will send you a link via PM, odds are it's the correct file.
Hi thank you so much for your help but it says error the software train is attached.
Was it the right file? Understand if it is and it just didn’t work.
appreciate your help on this
MEN2_EU_SKGPx_P0080L_MU8755.7z
This should be the correct file for the software train.
SD Card in FAT32?
Are the files in the root of the drive, and not in a folder called "MEN2_EU_SKGPx_P0080L_MU8755"
SD Card in FAT32?
Amazing, makes sense. Any chance that when you have time you could send it over again? The link has timed out.
no rush! Thank you
no rush! Thank you
Done, best of luck
On 21/10/2022 at 13:50, varooom said:
Keep your £70 in your pocket, will send you a link to download and install yourself.
Usually nothing is lost in the process, unless unit was "hacked" to enable something it never had.
Roughly 3 weeks later I can confirm all went well with the update.
This certainly did fix the phantom touches the screen was experiencing too much during cold/damp weather and it's much more responsive too!
Thanks @varooom for the software and help with this!! Without brilliant people like you around we would be at the mercy of the dealer (and that wouldn't be very nice).
All the best,
TSiTorque
Dies sollte die richtige Datei für den Softwarezug sein.
SD-Karte in FAT32?
Befinden sich die Dateien im Stammverzeichnis des Laufwerks und nicht in einem Ordner namens "MEN2_EU_SKGPx_P0080L_MU8755"
Greetings varoom,
I was supposed to get back to you last week, but I had a lot on my plate.
The update has worked without problems, what it was now I can not tell you! I have taken another card in NFTS format, and there it went without problems. Either it was the actual card or the formatting. I do not know!
Thanks for your help anyway
Newbie here...
@varooomis there FW update file to this:
5 minutes ago, ddude said:
Newbie here...
Off top of head, yes to 0490 version.
Will PM a link over.
Hi, hello.
Could there be any updates to my old Bolero with canton?☺️
Thank you :)
5 hours ago, MattiasRM said:
Hi, hello.
Thank you :)
You can try MSTD_EU_SK_P6230
MU 0490
Will PM you a link over
Hello, i'm new here. I'm looking for a help. A bought a car. Skoda Fabia Combi. Now it seems radio has mirrorlink, but don't have apple car. Could update fix that?
Device part number: 5Q0035819
Hardware: H11
Software: 0137
Media codec: 1003.113.1.15 prod
If anyone has update please send me pm.
Thank you
Hardware: H11
Software: 0137
Thank you
The update cannot fix Apple carplay, those features are turned on by release codes.
0138 is latest for your information.
varoom how can i do it for myself? If this is even possible. Or i have to take the car to dealershop and pay a lot :)
Either dealer or possibly an independent workshop.  Might not be worth the trouble/cost.
What about change the entire system? If i change mib1 to mib2. Beacuse i have to plan drive this car for the next 6 years or more. Maybe is cheaper to change the phone but still...
