Amundsen MIB2 Firmware Update
1 hour ago, pab567 said:
PM
Hi Pab,
I’ve just collected my 66 plate Octavia VRS, any updates would be much appreciated.
  • Replies 4.7k
  • Views 897.8k
PM
Just sent you a PM @pab567 , I am a "guest" with a VW MIB 😄 thank you in advance!
3 hours ago, pab567 said:
PM
Hi, pab567,
thanks, but that download link doesn't work for me. He will write it to me after opening the page: "You have no permission to access the share folder(s)"
PM
Worked like a charm, thank you! Except for dropping the first SD Card I bought down the void down the side of the chair and having to buy a 2nd 🤬
31 minutes ago, moorhuhn said:
Hi, pab567,
Fixed, new link sent
Hi Pab567,
could you have a look if there is new a firmware for my device:
model: 5Q0035842B
HW: H30
SW: 0363
Thanks in advance
Hello,
Hi @pab567, very grateful if you can share a link to the 480 firmware:
PM
Hello @pab567
Could you please check for the most recent software version for my unit:
Thanks in advance!!
Hi Mr @pab567. I have nasty problems with phone data in my memory. I can't delete profiles and previously paired phones must be paired after every reboot. Tried everything I could imagine.
Do you think upgrading Fw helps?
If so, could you send me a pm with compatible files?
Many thanks
Hi @pab567,
Could you please send me the link to the update for the following Bolero?
Many thanks.
Hello @pab567, i just saw that SW 0480 is out for my H41 unit.
Can you please send me the link to update it?
Reggards
Hi @pab567
   Could you please advise if an update is available for mine too?
Hey guys,
I've jost got my hands on 2015 vRS equipped with Amundsen. So far I've driven my 2014 Greenline, which has Columbus.
The previous owner states his phone to head unit connection worked before having it serviced at a dealer, now the thing says "Couldn't enable bluetooth" and that "SmartLink can be enabled using activation code. Please ask your dealer". I did my best translating these to English ;)
Is there any way to update the software or to enable the feature by myself?
It is device nr: 5Q0035842A
HW: H24
SW: 0245
I know I was able to update my Columbus map data with data from the Skoda site but there is no SW update available for my vRS.
Thanks in advance!
Tydlifuk.
Many thanks
I sent you link via PM however I do beleive that this is rather corrupcted file system in your unit. If I am rigjht you will not be able to proceed with the update so before ypou try it pls make a short test - change user interface language to any other and then restart the unit. If afdter restart unit returns to English by itself then files system is corrupted.
17 hours ago, tydlifuk said:
Hey guys,
HW: H24
SW: 0245
Thanks in advance!
Tydlifuk.
It seems to me tha teither unit has been previously patched and dealer killed this patch when servicing or unit broke down. let me know you VIN on PM so I can check if it was unit originally installed or rather retrofitted.
All others check your PMs
Hi guys,
I have kindly been given the latest update for my car but I'm having difficulty getting it to install.
I have unzipped the folder onto an SD card and also tried a USB stick but I get the following error.
Does anyone know what I'm doing wrong?
Thanks in advance.
thanks for your advice and time, its very appreciated.
Tried changing language + reboot -> As you suspected, language setting was restored after restart.
Any chance to repair/handle the corrupted filesystem? pairing my phone everytime is driving me nuts.
6 minutes ago, golf2 said:
Hi guys,
Thanks in advance.
Why don't you people use search before asking? The answer is: you should start it from SERVICE menu (long press MENU button).
I should be able to have it fixed but I must get it on my bench in Warsaw (Poland). Pls contact me on PM for details.
I've been searching for the last hour before I asked but couldnt find what I was looking for.
Thanks for your help, much appreciated as always 😃
Are there any firmware updates for my system please ?. Thanks in advance.
Thank you for your effort. Any update for my Amundsen available?
I posted in wrong Bolero topic previously.
PS: What are options to get Smartlink enabled?
