Amundsen MIB2 Firmware Update
Please send me a link to the latest version - thank you.
Edited by Ciderspace
  • Replies 4.7k
  • Views 899k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
On 02/09/2021 at 08:27, pab567 said:
@dmpc500 I got info that dmpc500 cannot receive messages.
Thanks @pab567, I'll create a few posts to unlock this feature so....
@pab567 Messages are working now
PM
Hello,
please send link to latest firmware (as I read 480)
Hello,
Good day.
I am having problems with my Amundsen system, Bluetooth is not enabled from time to time and the system stucks.
Does someone maybe know where I can find a firmware file to update?
Thanks!!!
I need a software update aswell but is it wort it? I am happy already with how it work, are any new features in update?
Edited by The1effect
If anyone has access to the latest firmware for my system it would be greatly appreciated. I'm having some issues with the navigation and would like to try updating it if possible.
Thanks in advance.
12 hours ago, A-G said:
Hello,
Good day.
Thanks!!!
Hello @pab567,
After searching the web for hours, reading every piece of relevant information and trying enormous amount of URLs, I think that I got to the understanding that maybe you can assist me with a link, and if you can't I will have to drive to the dealer.
Could you please kindly take a look and share an opinion, tip, or a file?
Thank you very much in advance.
A-G
Thank you Pab567 !
Hello is there maybe some update for me? Please for help.
Thanks!
AFAIK   only a dealer can do it and will only do so if it has a problem.  In 10 years of VAG ownership have never had it done  and even they didnt have too many clues about doing it.
Hello ,
Can somebody help me for the new update  ?
Teilenummer:5Q0035864C
Hardware:H41
Software:0478
Navigation:5L0051236AD
0910
ECE1 2018
Shield 2016-44 (build309)
Thank you pab567!
Update from 456 to 480 went smoth and fast (no 20 mins with class 10 ssd an 4 blocks)
Hello,
can somebody help me pls ?
i want update to 0780 .
On 12/09/2021 at 00:42, A-G said:
Hello @pab567,
A-G
Thank you @pab567 for the file! I installed it and everything went smooth.
I still don't know if it will fix the issues I had before, time will tell.
But, there is another issue which apparently related to the update.
I have a fault code B201A00 which is new and wasn't there before.
I read on the net that there is a formula which I need to use to calculate a value that I need to code, but I can't find any usable information in the net.
Do you maybe know the answer?
Thank you!
A-G
Thank you!
A-G
Use this site http://mib-helper.com/im-so-xory/
Is there a new firmware available to my Bolero? Thanks.
Part number: 5Q0035840A
Hardware: H24
Software: 0241
13 hours ago, gerstemann said:
It is a never-ending story, I really regret that i started with it in the first place...
I hope it won't break my rest of 3 years warranty...bow i can't get into the adaptation menu, it is grayed out in vcds and not working with obd11 also...
Any tips and tricks guys? I will be grateful for any assistance that will help me nail it and remove the errors...
Thank you!!
@pab567
@gerstemann
Cześć pab567 .czy jest możliwość aktualizacji amundsen MIB2 octavia 3 - 2016  ,z wersji 0245 do wersji 0478 z usb lub sd w samochodzie?
I czy masz oprogramowanie w wersji 0478 ?
Greetings to the most willing Škoda technician! Can I also respectfully ask for a link to the update fw?
I don't know if I have Amundsen or Bolero, but I get this data:
Device: 5Q0035864C
Hardware: H41
Software: 0456
Thank you
Hello, I keep getting pronlems with Mirrorlink. Is there an update for my bolero?
Thx
Teilenummer Gerät 565035842
Hardware H41
Software 0478
@pab567
Bonjour, Avez vous une mise a jours firmware pour ma Fabia Combi 3 2016
Merci beaucoup
3V0035045B
Hardware H50
Software ?
I'm looking for an update for this model can you help me?
(Android auto error)
