Amundsen MIB2 Firmware Update
Hello All, I was googling and found this forum.
I found out an error with my MIB unit - the back touchscreen is not working-, curious enough seems to work for other purposes, the part number is 5K7035200L SW: MST2_EU_VW_PQ_P0449T.
so I am thinking maybe a reflash or sw upgrade may fix the issue, reading previous post I found out the newest version is the 480, though I was only able to found the P0475T but display an incompatibility error, has someone experience a similar issue or help me getting the latest firmware version?
I was trying to do the upgrade using a 4GB SD card (in case the may cause any kind of issue).
thanks in advance for any help.
  • Replies 4.6k
  • Views 776.3k
MST2_EU_VW_PQ_P0449T I don't have on me the update for the PQ series, just ZR at this location
I am not sure if loading new firmware will help, if you are having hardware issues, but cannot hurt to rule it out.
I will PM you a link you can try.
Hello All,
Is there update for my Octavia MK3 2017 Amundsen
Thx in advance
9 minutes ago, SasaBGD said:
Hello All,
Thx in advance
Yes to 0369, I will try to send link soon to you.
Big thx !
I did upgrade from 361 to 369. I had few open points so maybe someone will need it.
1.unzip in root of SD (if u keep in folder it will not recognize)
2.Format FAT 32 with 4096 cluster size (you need smaller SD card ...e.g. 8Gb)
3.You can keep engine on or drive (start before upgrade)
4. approx. 30min
5.no visible change 361 vs. 369
Once more big thanks to @varooom
I can help out with MST2_EU_VW_PQ_P0480T if you still need it. Pls request a link via PM.
  • john999boy changed the title to Updated software wanted
Hello, I have Ambusend, which is the latest firmware update for the one I currently have
0359 is the latest version in the 03xx series of updates.
On 16/09/2022 at 18:32, gabileata said:
CAN SOMEONE HELP ME WITH UPDATES TO THIS SOFTWARE, PLEASE
You will need to post image of your Software Train, hold down menu/setup button to enter the hidden menu.
Odds are it's 0480
1 hour ago, gabileata said:
THANKS FOR THE ANSWER, I THINK THIS PICTURE IS GOOD.
PM Sent
4 minutes ago, gabileata said:
Hello. something went wrong. can you help me please
Show a picture of your SD Card contents.
The other would be a broken SD Card.
7 minutes ago, gabileata said:
who can help me with this problem. thank you
Move all files in the directory ...P0480T to the root, delete the empty directory and try again.
where can i find lmthe link for download ?
3 minutes ago, sejid said:
where can i find the link for download ?
It's via private messages.
I am busy at the moment, but please reply back with your Software Train value to confirm what is currently installed.
How activation smart link on Amundsen ?
Hey guys
Could someone send me the most up to date version, thx a lot.
1 hour ago, voltaine said:
Hey guys
I will send a PM with 0480 version
Morning all,
Thanks to varooom I know that my unit can be upgraded to 0253. However, I would like to know what benefits/improvements this upgrade brings as I have had several negative experiences when upgrading different devices (phones, TVs, etc). Also, my XIAOMI Redmi Note 10 pro works well with the unit now (streaming Spotify, phone works well .....) And I am weary of things going wrong. Any thoughts on this please? Thanks.
1 hour ago, GerryZabala said:
Morning all,
I have applied this exact firmware to mine.  Many others have applied firmwares from me and others, the unit's have emergency download capabilities also, usually for when someone placed update files into a folder and not the root of the SD Card.
It's mainly bug fixes being done, and VAG don't supply a changelog at all, we need to read TPI documents and best guess what's being fixed.
Would you mind directing me to any tutorial posted within this forum please? I will have to update my sat nav maps too. Thanks varooom. 👍
I can send firmware via PM
Maps too that should get you updated
Thanks a lot mate. You are a star! 👍
Hello Guys!
I'm new here.
I've bought my Skoda Scout week ago.
Can you give me a feedback about latest firmware for mine Amudsen?
Thank you and have a great evening ;)
1 hour ago, arekszg1 said:
Hello Guys!
I'm new here.
Hello,
Press and hold down your menu button for 10 seconds or so, then you will enter the hidden menu with Software Train information and update button for firmware.
