Amundsen MIB2 Firmware Update
Hi guys!
I am new to the forum and I would like to upgrade my MIB 2 Amundsen software.
Radio info:
MST_2_EU_SK_ZR_P0245T
SW MU Version 0245
Part nr 5Q0035864A
From extra info smartlink is still locked 😞
Could you help me with software and some instructions so I do not kill the radio? :D
Thanks!
  • Replies 4.7k
  • Views 905k
10 minutes ago, SyossuPL said:
Hi guys!
Radio info:
MST2_EU_SK_ZR_P0245T
SW MU Version 0245
Part nr 5Q0035864A
Thanks!
Welcome to the forum,
There is 0253 available, but let me curb your expectactions, this will not turn on features.
They are done by SWaP/FEC codes, where they enable features already "baked" into the firmware you already have.
To enable, you have to pay for the feature at a dealer/independant garage.
There exists a free way also, but you need to enable what is called "Developer Menu" and you need to use a tool like VCDS or similar to do this.
Let me know if you still want the update file.
I do not expect to get a anything extra :)
An update is all I need for now. :) Thanks you
Ok, next few minutes, open your private message when it lands.
44 minutes ago, SyossuPL said:
Hi guys!
Radio info:
SW MU Version 0245
Part nr 5Q0035864A
Thanks!
Locked?
Just now, mattft86 said:
Locked?
yeap, need "activation" :)
I use an iPhone so from what I know the USB post has to be changed anyways to make it work
Hi
Is there an update for this one ? if so please can I have the Firmware & some instructions please
Many thanks
Hi.  If I upload update 0480 to this unit, will anything happen or can I update safely?
27 minutes ago, piotrswiderski12 said:
You will probably brick the unit.
You are supposed to stick with your software train if 02xx
03xx
04xx
Cannot change from one big version as different hardware numbers.
Guys, Does anyone has or give me any link where I can download my original version of firmware. DEVICE PART NUMBER 5Q0035874C, HARDWARE H41, SOFTWARE: 0456, SHIELD: SHIELD 2016-44 (BUILD 309).
0468
0475
0478
0480
So no "original" has been released, as they placed 0456 at factory, unless Google reveals a download
4 hours ago, varooom said:
0468
0475
0478
0480
Is it? 0480  version seems no good to me..the globe is always red unless i connect it to my mobile hotspot. once i turned the hotspot off it turns to original colour (silver/white). otherwise it is always red and its bugging me. Another problem is my viber calling is not connecting to the bluetooth. whatsapp, facebook massangers calls are okay with bluetooth.
Hi guys,
Just bought my first Skoda Octavia iii, and the touch screen has a mind of its own sometimes, can you help me try a S/W update.
I Have the following:
DPN: 5Q035874A
H/W: H25
S/W: 0245
Thanks in advance
15 minutes ago, Brokenbarrow89 said:
Hi guys,
DPN: 5Q035874A
H/W: H25
S/W: 0245
Thanks in advance
Sent PM
Do not try to update from 02xx to 03xx, 03xx to 04xx as you risk damaging your unit. It will usually refuse to update though. the version you have is the latest I think.
hello pab567
could you please have a look, if there is also an update available for me ?
thank's
Romain
@varooom could you please share same firmware to my pm?
My version is same as @SyossuPL. Dziękuję :)
>> 0245
>> 5Q0035864A
9 hours ago, Romain74 said:
hello pab567
thank's
Romain
@pab567You have a request sir.
My version is same as @SyossuPL. Dziękuję /cdn-cgi/mirage/7f3a4109b7c9db5275ba0696e58b3cb7d9ae65c743ad6ace706caf7e66e199cc/1280/https://www.briskoda.net/forums/uploads/emoticons/emoticon-0100-smile.gif
>> 0245
>> 5Q0035864A
I shall send in next few minutes.
Edited by varooom
Hi, could I get the latest firmware update for this system please? Thanks
Link for MST2_EU_SK_ZR_P0480T sent via PM to both :)
Hi, Can I have an update for the below? Thanks in advance.
An upgrade to 1433 awaits you in your PM
Hi, I would also really like some help with the update.
Which update will be best for my Amundsen? Can you please also send me the file? Thank you :)
Now:
5Q0035864C
H41
0472
