Amundsen MIB2 Firmware Update
@Hede is it possible to go from P0353 to P0480? Wasn’t sure if you needed to stay within the same code eg. 01.. 02.. 03.. or 04.. ?
  • Replies 4.7k
  • Views 904.3k
39 minutes ago, AmolK said:
Hello @Joco776, I'm from Ireland and recently purchased a used 2017 Skoda Fabia Monte Carlo. However, I've noticed that Apple CarPlay is disabled in my Skoda Fabia. After reading through various comments and posts, I'm wondering if you could assist me with updating it, if possible. Trying to send you the message but it's not working so.
Additionally, I have an SD card slot. Can I use any SD card, or is it necessary to use a Skoda-specific SD card?
Here are the details of my car's software:
Software Update:
Installed SW Train Version: MST2_EU_SK_ZR_P0359T
Installed SWMu Version: 0359
Part Number: 5Q0035840b
Software Version: H28.133_STDPlus_EU
Logging:
Current Version: MST2_EU_SK_ZR_P0359T (0359)
Update: MST2_EU_SK_ZR_P0359T (0359-2)
My apple carplay is disabled in my Octavia mklll and it said I had to contact the dealership to get an activation key. I think you can’t solve this with a software update and you need a seperate activation ‘key’
@AmolK Hello, you have to do the activation at the seller. I can only send you an update on 0369T. I would have to have your unit with me to put 0480 there.
what is the advantage of 480 sw version against the 456 version?
Hi, I finally found more info about the software :
Part number : 5QA035824
MU SW : 0241
Train sw: MST2_EU_SE_ZR_P0241T
sw: H25.14.33_STD2Plus_EU
Any updates available ?
@Skiziix Email me and I'll send you an update and instructions
I sent
Sorry, I didn't find the instructions, are there in in the zip file ? @Joco776
Hi, i am searching for the Firmware Update for my skoda superb 3t … Codes Are all legit …
hey all
need help me about mib2 berlo 5Q0035840 B
the orginal software is p363t
and im update swdl 369
im select all option in swdl
the unit after update is off and i try do emergency download but no avail
screen black 😞
imx6 TTL Writes that its being updated but after finish mib screen black
HELP ME OR ADVISEME WHAT TO DO 😞
-Welcome to TechniBoot-
SVN Rev: 636303 - Mar 24 2017 / 07:36:50
Variant: ZR stdPlus sop3n 1GB LPDDR3
CAAM: CAAM_CSTA  0x00000202 - trusted Mode
CAAM: init -> ok
CAAM: open already instantiation ring 0!
CAAM: open ok
Image verified
CAAM: clock 0x00018900
type=00000004, cksum=000059E6, address=10800000, length=002A121C
type=00000006, cksum=00000006, address=10800000, length=00000000
iMX6.QNX.LoadImage.ready: 0x0F7F213B
Enabling only 1 CPU
L2 cache enabled
CPU0: L1 Icache: 1024x32
CPU0: L1 Dcache: 1024x32 WB
CPU0: VFP-d32 FPSID=41033094
CPU0: NEON MVFR0=10110222 MVFR1=01111111
CPU0: 412fc09a: Cortex A9 MPCore rev 10 792MHz
Board version: ZR/20 v1
Detected i.MX6 Solo/DualLite, revision TO1.3
PLL1 - System     : 792MHz
PLL2 - System Bus : 528MHz
PLL3 - OTG USB    : 480MHz
PLL4 - Audio      : 36MHz
PLL5 - Video      : 339MHz
PLL7 - Host USB   : 480MHz
PLL8 - Enet       : 100MHz
IPG clock     : 66000000Hz
IPG per clock : 66000000Hz
UART clock    : 80000000Hz
CSPI clock    : 60000000Hz
AHB clock     : 132000000Hz
AXI clock     : 198000000Hz
EMI_SLOW clock: 19200000Hz
DDR clock     : 396000000Hz
USDHC1 clock  : 198000000Hz
USDHC2 clock  : 198000000Hz
USDHC3 clock  : 198000000Hz
USDHC4 clock  : 306580644Hz
ENFC clock    : 24000000Hz
System page at phys:10010000 user:fc404000 kern:fc404000
Starting next program at vfe056a9c
cpu_startnext: cpu0 -> fe056a9c
VFPv3: fpsid=41033094
coproc_attach(10): replacing fe072ddc with fe089970
coproc_attach(11): replacing fe072ddc with fe089970
Welcome to QNX Neutrino on the Freescale i.MX6 MIBSTD2PLUS_CPU (ARMv7 Cortex-A9 Core)
00:00:00.224     [Info] [tsd.mibstd2.hmi.anim.cpp]      [PERF:0xe2e3b9:IO0] iMX6.earlyRVC.ready
00:00:00.226     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda start
00:00:00.228     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: graphics init
00:00:00.267     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: graphics init complete
00:00:00.291     [Info] [tsd.videocapture.control]      All rvc libs loaded successfully!
00:00:00.292     [Info] [tsd.mibstd2.hmi.bootanim.j5]   initialize video capture complete
00:00:00.293     [Info] [tsd.mibstd2.hmi.bootanim.j5]   mmap_device_memory successed
00:00:00.293     [Info] [tsd.mibstd2.hmi.bootanim.j5]   [PERF:0x128d7e4:IO0] iMX6X.screen.start
00:00:00.294     [Info] [tsd.mibstd2.hmi.bootanim.j5]   try to load screen-mgr.so
00:00:00.294     [Info] [tsd.mibstd2.hmi.bootanim.j5]   watching_thread started
00:00:00.297     [Info] [tsd.mibstd2.hmi.anim.cpp]      Startup Info Thread started.
Thu Jan 01 00:01:00 UTC 1970
00:01:00.010     [Info] [tsd.mibstd2.hmi.anim.cpp]      startup container mapped to addr 0xffde0 (length = 1048576)
00:01:00.056     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
Path=0 - imx6
 target=0 lun=0     Direct-Access(0) - SDMMC: USD Rev:
00:01:00.181     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
Path=0 - imx6
 target=0 lun=0     Direct-Access(0) - SDMMC: MMC04G Rev:
 target=0 lun=1     Direct-Access(0) - SDMMC: MMC04G Rev:
00:01:00.301     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:00.318     [Info] [tsd.mibstd2.hmi.bootanim.j5]   screen is ready to run
Mempool Map addr range[2ba00000-30000000]
Mempool Map paddr range[48e00000-4d400000]
iMX6.QNX.init.ready
[Interrupt] Attached irqLine 41 with id 14.
[Interrupt] Attached irqLine 42 with id 15.
Attached resmgr to /dev/galcore with id:1.
00:01:00.461     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:00.589     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:00.653     [Info] [tsd.mibstd2.hmi.bootanim.j5]   [PERF:0x3e6f807:IO0] unknown.screen.ready
00:01:00.718     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:00.846     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:00.974     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:01.102     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:01.246     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:01.391     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:01.535     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:01.679     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:01.823     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:01.951     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:02.079     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:02.208     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:02.336     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
Current core file directory: /tsd/var/core/startup-33
00:01:02.464     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
00:01:02.592     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
net.inet.udp.recvspace: 41600 -> 131072
net.inet6.udp6.recvspace: 42080 -> 131072
Starting tsd.mibstd2.cpu.root...
00:01:03.082     [Info] [iMX6.mcp]      [FREQ:66000000]
00:01:03.085     [Info] [iMX6.mcp]      [PERF:0xd7857b9:IO1] iMX6.MCP.init.start
Using remote connection for file server.
00:00:00.024     [Info] [iMX6.mcp]      Booting at SWDL Mode (1, 1)...
12:53:16.280     [Info] [iMX6.mcp]      [PERF:0xdbc2c92:IO0] iMX6.DSIStartup.start
12:53:16.281    [Error] [iMX6.tsd.communication.serializer]    Serializer already registered for event 0x14000004
12:53:16.283     [Info] [iMX6.mcp]      [PERF:0xdbf1ea2:IO0] iMX6.DSIStartup.ready
12:53:16.289    [Error] [iMX6.tsd.communication.serializer]    Serializer already registered for event 0x14000004
12:53:16.296     [Info] [iMX6.mcp]      [PERF:0xdcc7621:IO0] iMX6.MCP.init.ready
12:53:16.314     [Info] [iMX6.mcp]      [PERF:0xdde27c1:IO0] iMX6.MountJxe.start
12:53:16.323     [Info] [iMX6.mcp]      [PERF:0xde79115:IO0] iMX6.DispMg.start
12:53:16.335     [Info] [iMX6.mcp]      [PERF:0xdf3cb57:IO0] iMX6.AudioService.start
12:53:16.364     [Info] [iMX6.mcp]      [PERF:0xe109f94:IO0] iMX6.WLAdapter.start
12:53:16.397     [Info] [iMX6.mcp]      [PERF:0xe32406c:IO0] iMX6.USB.start
audioservice: EjectHandler: State.Default (N=1, P=0)
audioservice: EjectHandler: Power <- 1
audioservice: EjectHandler: State.Prepare1
audioservice: EjectHandler: Action.PowerOn
audioservice: Audio service started.
12:53:16.564     [Info] [iMX6.mcp]      [PERF:0xed9cd9a:IO0] iMX6.AudioService.ready
audioservice: CardMounter1: Inactive_Check
audioservice: CardMounter2: Inactive_Check
audioservice: UsbMounter1: Inactive_Check
audioservice: UsbMounter2: Inactive_Check
audioservice: EjectHandler: State.Prepare2
audioservice: EjectHandler: Action.DriverOn
audioservice: CardMounter1: Mounting
audioservice: Mounting '/dev/sd10t12' -> '/media/mp000'
audioservice:   mounted as 'dos' with options 'hidden=dot,sfn=windows,noatime,posix=none,codepage=cp850,fsi=ignore,marking=dynamic'
audioservice: CardMounter1: ActiveMounted
audioservice: CardMounter1: Remounting
12:53:17.448     [Info] [iMX6.mcp]      [PERF:0x125458bf:IO0] iMX6.DispMg.ready
mountjxe:
mountjxe:
12:53:17.609     [Info] [iMX6.mcp]      [PERF:0x12f6c479:IO0] iMX6.MountJxe.end
12:53:17.617     [Info] [iMX6.mcp]      [PERF:0x12fecf85:IO0] iMX6.J9/HMI.start
j9/hmi: ---------------------------------------------
j9/hmi:    echo Runmode: SWDL was detected
j9/hmi:    echo ---------------------------------------------
j9/hmi: ---call ------------------------------------------------
wladapter: tsd.mibstd2.system.wirelessadapter.main: use control connection 'tsd.wirelessadapter.control'
12:53:17.888     [Info] [iMX6.mcp]      [PERF:0x140f579d:IO0] iMX6.USB.ready
12:53:17.940     [Info] [iMX6.mcp]      [PERF:0x14439ba3:IO0] iMX6.WLAdapter.ready
12:53:17.955     [Info] [iMX6.mcp]      [PERF:0x1452ddda:IO0] iMX6.NetMgr.start
j9/hmi: [Log4MIB] Initializing Log4MIB - queue capacity: 2000
12:53:18.328     [Info] [tsd.videocapture.decoder]      Reset Decoder!
j9/hmi: [Log4MIB] logging thread started - 1261783861
12:53:18.425     [Info] [tsd.mibstd2.hmi.bootanim.j5]   Initialization of CaptureUnit and decoder done
j9/hmi: 14   INFO [0x4000, 0x1, 0xf272cf50] Launching MIB ...
j9/hmi: 46   INFO [0x4000, 0x1, 0xf272cf50] Starting HMI with startup order: TARGET
j9/hmi: 55   INFO [0x4000, 0x2, 0xf272cf50] Starting SPI bundles ...
j9/hmi: 9205586590 - [Log4MIB-Heartbeat] heartbeat with watchdog started - frequency: 30000ms, first heartbeat after 10000ms
j9/hmi: 3807   INFO [0x4000, 0x2, 0xf272cf50] Starting autostart bundles ...
j9/hmi: 9201281151   INFO [0x200, 0x4, 0xf272cf50] Using new TimestampProvider by now to create logging timestamps!
j9/hmi: 9325795015   INFO [0x200, 0x2, 0xf272cf50] protocol.version:=1.2;;hmisoftware.version:=H28.28.197_STD2Plus_EU;;hmisoftware.base.version:=H28.28.197-201706191425;;logmessage.count:=24/0;;logmessage.queue.size:=13/2000;;logmessage.data.size:=1KB
j9/hmi: 9349438954   WARN [0x2, 0x4, 0xf272cf50] [DebugProbeManager] Deactivating all debug probes (specified in TESTMODE) ...
12:53:24.083     [Info] [iMX6.mcp]      [PERF:0x2c6e6129:IO0] iMX6.Swap.start
j9/hmi: 9908824651   INFO [0x4000, 0x2, 0xf272cf50] Starting managed bundles ...
j9/hmi: 9945563393   INFO [0x800001, 0x2, 0xf272cf50] [ASLList] Activator started.
j9/hmi: 9949187515   INFO [0x800001, 0x1, 0xf272cf50] [ASL-Framework] Activator started.
j9/hmi: 10090221757   WARN [0x800001, 0x8, 0xf272cf50] [DSIProxy] Could not retrieve DSI adaptor factory.
j9/hmi: 10209679196  ERROR [0x800001, 0x1, 0xe6c15f22] [ASL-Framework] StartUpUtil: Could not load class generated.de.vw.mib.asl.internal.homescreen.info.ASLHomeScreenInfoDeviceImpl
j9/hmi: 10352106000  ERROR [0x800001, 0x1, 0xe6c15f22] [ASL-Framework] StartUpUtil: Could not load class generated.de.vw.mib.asl.internal.webradio.ASLWebRadioDeviceImpl
j9/hmi: 10381564075   INFO [0x8, 0x800, 0xf272cf50] Loading display size dependent translations. Language tag: de_DE-0
j9/hmi: 10487886696   INFO [0x1, 0x1, 0xe6c15f22] [ASLStartup v8]skipping DSI: org.dsi.ifc.upnp.DSIUPNPPlayer ,instance 0 because FeatureFlag was not set
j9/hmi: 10488653257   INFO [0x1, 0x1, 0xe6c15f22] [ASLStartup v8]skipping DSI: org.dsi.ifc.upnp.DSIUPNPBrowser ,instance 0 because FeatureFlag was not set
j9/hmi: 10489393742   INFO [0x1, 0x1, 0xe6c15f22] [DsiInformationService] Information about available DSI processed.
j9/hmi: 10489818363   INFO [0x1, 0x1, 0xe6c15f22] [PersistenceInformationService] Information about available persistence namespaces processed.
j9/hmi: 10515971484  ERROR [0x800001, 0x8, 0xe6c15f22] [DSIProxy] Could not load module reflection configuration for package de.vw.mib.asl.framework.internal.entertainmentmanager.reflection.generated
j9/hmi: 10629923696   INFO [0x1, 0x1, 0xe6c15f22] [ASLStartup v8]Powerstate detected by Startup Manager: 8
j9/hmi: 10630199818   INFO [0x1, 0x1, 0xe6c15f22] [ASLStartup v8]SWDL Powerstate detected by Startup Manager
j9/hmi: 10644641424   INFO [0x1, 0x20, 0xe6c15f22] de.vw.mib.pso.useReadInt=null
j9/hmi: 10644776409   INFO [0x1, 0x20, 0xe6c15f22] initial profile for STD
j9/hmi: 10645582924   INFO [0x1, 0x20, 0xe6c15f22] [InitialStartupProfileTarget] Requesting startup profile for STD (requestConfigManagerPersInformation).
j9/hmi: 10672315621  ERROR [0x80, 0x400000, 0xe6c15f22] DIAGNOSTIC TargetAdaption EV_DIAG_CONTEXT_LOADED event.result == IdResult.ERROR, namespace = 678364556, key = 21
j9/hmi: 10672555257  ERROR [0x80, 0x400000, 0xe6c15f22] DIAGNOSTIC [TargetDiagnosis] EV_DIAG_CONTEXT_LOADED arr == null, namespace/key: 678364556/21
j9/hmi: 10674794939  ERROR [0x1, 0x400000, 0xe6c15f22] DIAGNOSTIC ns/key 678364556/21 data == null
j9/hmi: 10677067454   INFO [0x1, 0x20, 0xe6c15f22] PersistenceService: Initial profile was set to 1
j9/hmi: 10689314181   INFO [0x1, 0x1, 0xe6c15f22] [SpecialMethodInitialStartupProfileReady] Persistence initial profile already set. Continuing.
j9/hmi: 10689978878   INFO [0x1, 0x1, 0xe6c15f22] Domain(s) already reached requested state or higher, moving on...
j9/hmi: 10755786075  ERROR [0x1, 0x4000000, 0xe6c15f22] The method org.dsi.ifc.keypanel.DSIKeyPanelListener[0].lastKey is unexpected and will be discarded.
j9/hmi: 10768733318   INFO [0x400, 0x1, 0xf272cf50] Instatiating class loader: loading JXEs from viewhandler.zip
j9/hmi: 10800365696   INFO [0x3, 0x4, 0xf272cf50] [CIO Visualization] CioVisualizationServiceDispatcher wants to load, but no apps registered yet.
j9/hmi: 10934849303  ERROR [0x10, 0x800, 0x1a290abb] [na]<- DSI-R: org.dsi.ifc.powermanagement.DSIPowerManagementListener[0].asyncException(8305,Not supported exception,1004)
j9/hmi: 11097088909   WARN [0x1, 0x800, 0xe6c15f22] [AslTargetSystemPowerManagementHandling] DSIPowerManagement-ASYNC:ErrorCode[8305] Text:'Not supported exception' RequestId[1004]
j9/hmi: 11148743818   INFO [0x1, 0x800, 0xe6c15f22] [AslTargetSystemPowerManagementHandling] Update Power State: POWERSTATE_ON_SWDL
j9/hmi: 11163338272   INFO [0x1, 0x800, 0xe6c15f22] [AslTargetSystemPowerManagementHandling] dsiPowerManagementUpdateBEMState 0
j9/hmi: 11163920303   INFO [0x1, 0x800, 0xe6c15f22] [AslTargetSystemPowerManagementHandling] dsiPowerManagementUpdateClampSignal ClampSignal(clampS=false,clamp15=false,clampX=false,clamp50=false)
j9/hmi: 11186271045   INFO [0x1, 0x800, 0xe6c15f22] [AslTargetSystemDate] First valid ClockTime: ClockTime(hours=20,minutes=22,seconds=48,timeZone=-4.0,summerTime=false) triggerObserver VALID_TIME_DATE_AVAILABLE
j9/hmi: 11269322090   INFO [0x400, 0x40000000, 0xe6c15f22] [AslTargetLscTNGBullhorn]Get default language from NS(1101) KEY(10):en_US
j9/hmi: 11395474787   INFO [0x400, 0x40000000, 0xe6c15f22] [AslTargetLscTNGBullhorn]Skin found in coding is different from Persistence, setting for initial LSC
j9/hmi: 11395753060   INFO [0x1, 0x1, 0xe6c15f22] [ASLStartup v8]Received initial coding, moving on..
j9/hmi: 11433834818   INFO [0x400, 0x40000000, 0xf272cf50] [AslTargetLscTNGBullhorn]Persisting language data for Instrument Cluster
j9/hmi: 11575176121   INFO [0x1, 0x800, 0xe6c15f22] <cp = ScreenAreaStage> <content = HMI_SWDL>
j9/hmi: 11575705621   INFO [0x1, 0x800, 0xe6c15f22] <cp = ScreenAreaCar> <content = HMI_CAR_BAR>
j9/hmi: 11575909363   INFO [0x1, 0x800, 0xe6c15f22] <cp = ScreenAreaClimate> <content = HMI_CLIMATE_BAR>
j9/hmi: 11576064196   INFO [0x1, 0x800, 0xe6c15f22] <cp = ScreenAreaStatus> <content = HMI_STATUS_BAR>
j9/hmi: 11576194696   INFO [0x1, 0x800, 0xe6c15f22] <cp = ScreenAreaHomeButton> <content = HMI_HOMEBUTTON>
j9/hmi: 11576323621   INFO [0x1, 0x800, 0xe6c15f22] <cp = ScreenAreaMenu> <content = HMI_GRIDMENU>
j9/hmi: 11621066893   INFO [0x400, 0x400, 0xc9eb0801] skin strategy = [3, 2, 1]
j9/hmi: 11621549803   INFO [0x400, 0x4, 0xc9eb0801] Change Simple-Listener_e0000001_TTT_-1/NO_LANGUAGE/-1 with changeId 0 to skin 3
j9/hmi: 11629964515   WARN [0x400, 0x100000, 0xc9eb0801] List of loaded containers not initialized for skin ID: -1
j9/hmi: 11658700606   INFO [0x8, 0x4, 0xc9eb0801] Skin image pool has detected new format.
j9/hmi: 11752965939   INFO [0x400, 0x4, 0xc9eb0801] Change Simple-Listener_e0000002_TTT_-1/NO_LANGUAGE/-1 with changeId 1 to skin 3
j9/hmi: 11756590287   INFO [0x200, 0x2, 0xc9eb0801] protocol.version:=1.2;;skin.short.version:=Skoda_STD_Skin_C_80_S-STD2Plus_EU-3;;hmisoftware.version:=H28.28.197_STD2Plus_EU;;hmisoftware.base.version:=H28.28.197-201706191425;;generic.event.count:=228;;logmessage.count:=120/0;;active.debug.probes:=NONE;;car.time:=1713817369928;;generic.event.queue.size:=26;;logmessage.queue.size:=101/2000;;logmessage.data.size:=6KB;;time:=2024-04-22 20:22:49
j9/hmi: 11759506500   INFO [0x8, 0x800, 0xc9eb0801] Loading display size dependent translations. Language tag: de_DE-0
j9/hmi: 11770425257   INFO [0x400, 0x400, 0xc9eb0801] language strategy = [en_US, en_GB]
j9/hmi: 11819729712   INFO [0x400, 0x4000, 0xc9eb0801] send STARTUP_SKIN_READY
j9/hmi: 11821100757   INFO [0x8, 0x800, 0xc9eb0801] Loading display size dependent translations. Language tag: en_US-0
j9/hmi: 11844306303   INFO [0x400, 0x400, 0xc9eb0801] skinmode strategy = [0, -1]
j9/hmi: 11844540000   INFO [0x400, 0x4, 0xc9eb0801] Change Simple-Listener_e0000001_TTT_3/en_US/-1 with changeId 5 to skinmode 0
j9/hmi: 11845190136   INFO [0x400, 0x4, 0xc9eb0801] Change Simple-Listener_e0000002_TTT_3/en_US/-1 with changeId 6 to skinmode 0
netmgr: 12:53:24.845     [Info] [iMX6.NetMgr.networking.core]  Failed to create directory /tsd/var/networking. 17
netmgr: 12:53:24.850     [Info] [iMX6.NetMgr.networking.core]  Failed to create directory /tsd/var/qnx. 17
netmgr: 12:53:24.857     [Info] [iMX6.NetMgr.networking.core]  Failed to create directory /var/state. 17
netmgr: 12:53:24.885     [Info] [iMX6.NetMgr.networking.core]  clearing rule files.
netmgr: 12:53:24.997     [Info] [iMX6.NetMgr.networking.core.packetfilter]      loading Rule file...
netmgr: 12:53:25.027     [Info] [iMX6.NetMgr.networking.core]  [loadNetworkingConfig()], ActiveTestmodeDHCP=0, StaticIp=192.168.1.4
netmgr: 12:53:25.032     [Info] [iMX6.NetMgr.networking.core]  [initCore()] NetworkConfig loaded.
netmgr: 12:53:25.035     [Warn] [iMX6.NetMgr.networking.core]  [initCore()] HMI not ready
12:53:25.084     [Info] [iMX6.mcp]      [PERF:0x305ecc7e:IO0] iMX6.Swap.ready
12:53:25.101     [Info] [iMX6.mcp]      [PERF:0x306f5f44:IO0] iMX6.SwDL.start
12:53:25.135     [Info] [iMX6.mcp]      [PERF:0x30920d97:IO0] iMX6.NetMgr.ready
12:53:25.159     [Info] [iMX6.mcp]      [PERF:0x30aa76e5:IO0] iMX6.Testinterface.start
netmgr: 12:53:25.176     [Info] [iMX6.NetMgr.networking.core]  restoring default resolv.conf...
netmgr: 12:53:25.425    [Error] [iMX6.NetMgr.networking.control]        Country not supported for WLAN.
swap: 12:53:25.430      [Error] [iMX6.Swap.tsd.mibstd2.system.swap]     parsing exception list failed: couldn't open file for reading
netmgr: 12:53:25.471     [Info] [iMX6.NetMgr.networking.core]  sending NetworkDeviceInformation with IP: 127.0.0.1 | NetworkType: 8 | itnerface name: lo0
netmgr: 12:53:25.637     [Info] [iMX6.NetMgr.networking.core]  registerAppRequest()
netmgr: 12:53:25.640     [Info] [iMX6.NetMgr.networking.core.appManager]        Adding Application with Name: TestInterface InterfaceName:  and Bitmask: 0
netmgr: 12:53:25.644     [Info] [iMX6.NetMgr.networking.core.appManager]        getNextFreeId: 1
netmgr: 12:53:25.647     [Info] [iMX6.NetMgr.networking.core.appManager]        Added Application with ID: 1 | Name: TestInterface on interface:
netmgr: 12:53:25.650     [Info] [iMX6.NetMgr.networking.core.appManager]        Port: 1234
netmgr: 12:53:25.728     [Info] [iMX6.NetMgr.networking.core.pfTask]    loadRuleFile() succedded.
netmgr: 12:53:25.753     [Info] [iMX6.NetMgr.networking.core]  loading normal rule file.
netmgr: 12:53:25.756     [Info] [iMX6.NetMgr.networking.core.packetfilter]      loading Rule file...
12:53:25.789     [Info] [iMX6.mcp]      [PERF:0x33248dc8:IO0] iMX6.Testinterface.ready
12:53:25.803     [Info] [iMX6.mcp]      [PERF:0x33328058:IO0] iMX6.Logging.start
swdl: 12:53:25.880       [Info] [iMX6.SwDL.tsd.system.swdl.device]      GuardedDownloadDeviceList::add(): Registering new download device cpuplus
swdl: 12:53:25.920       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::BluetoothUpdater: constructor, sop3 device
swdl: 12:53:25.929       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::WladapCommClient:: Obtained connection tsd.mibstd2.swdownload.wirelessadapter for Receiver, start=0
swdl: 12:53:25.936       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::WladapCommClient:: Obtained connection tsd.mibstd2.swdownload.wirelessadapter for Sender, start=0
swdl: 12:53:25.941       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::BluetoothUpdater: start returned thread_id=17, BluetoothUpdater, prio=10
swdl: 12:53:25.943       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::WladapCommClient:: start receive and transmit for wirelessadapter connection
swdl: 12:53:25.947       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::getDeviceState:
swdl: 12:53:25.959       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::TestModuleCnf: pending=0, module_ok=1, hardware=0x201a, firmware=0xc194
swdl: 12:53:25.964       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::getDeviceState: return module_state=ready
swdl: 12:53:25.968       [Info] [iMX6.SwDL.tsd.system.swdl.device]      GuardedDownloadDeviceList::add(): Registering new download device bluetooth
swdl: 12:53:25.985       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 1! (msgId=2)
swdl: 12:53:25.989      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x8100005
swdl: 12:53:26.001       [Info] [iMX6.SwDL.tsd.system.swdl.device]      GuardedDownloadDeviceList::add(): Registering new download device powerc
swdl: 12:53:26.010       [Info] [iMX6.SwDL.tsd.system.swdl.device]      GuardedDownloadDeviceList::add(): Registering new download device mainplus
swdl: 12:53:26.013       [Info] [iMX6.SwDL.tsd.system.swdl.device]      GuardedDownloadDeviceList::add(): Registering new download device inic
swdl: 12:53:26.031       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 2! (msgId=3)
logging: 12:53:26.068   [Error] [iMX6.Logging.system.logsrv]   failed to read LOG_REDIRECTION from persistence (12)
swdl: 12:53:26.082       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 3! (msgId=4)
12:53:26.085     [Info] [iMX6.mcp]      [PERF:0x344ec35a:IO0] iMX6.Logging.ready
12:53:26.098     [Info] [iMX6.mcp]      [PERF:0x345b9ff1:IO0] iMX6.Itr.start
swdl: 12:53:26.085       [Info] [iMX6.SwDL.tsd.system.swdl.schedule.plan]       reading download plan from file /tsd/var/swdownload/swdlhistory/swdownload1.conf
swdl: 12:53:26.132       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 4! (msgId=5)
swdl: 12:53:26.182       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 5! (msgId=6)
swdl: 12:53:26.231       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 6! (msgId=7)
swdl: 12:53:26.281       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 7! (msgId=8)
swdl: 12:53:26.331       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 8! (msgId=9)
swdl: 12:53:26.381       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 9! (msgId=10)
swdl: 12:53:26.431       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 10! (msgId=11)
swdl: 12:53:26.481       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 11! (msgId=12)
swdl: 12:53:26.505       [Info] [iMX6.SwDL.tsd.system.swdl.schedule.plan]       reading download plan from file /tsd/var/swdownload/swdlhistory/swdownload2.conf
swdl: 12:53:26.531       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 12! (msgId=13)
swdl: 12:53:26.581       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 13! (msgId=14)
swdl: 12:53:26.632       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 14! (msgId=15)
swdl: 12:53:26.681       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 15! (msgId=16)
swdl: 12:53:26.731       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 16! (msgId=17)
netmgr: 12:53:26.738     [Info] [iMX6.NetMgr.networking.core.pfTask]    loadRuleFile() succedded.
swdl: 12:53:26.782       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 17! (msgId=18)
swdl: 12:53:26.829       [Info] [iMX6.SwDL.tsd.system.swdl]    Start default Downloadmanager with DownloadState: 1
swdl: 12:53:26.831       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 18! (msgId=19)
swdl: 12:53:26.839       [Info] [iMX6.SwDL.tsd.system.swdl.schedule.plan]       reading download plan from file /tsd/var/swdownload/swdlselection.tmp
swdl: 12:53:26.881       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 19! (msgId=20)
swdl: 12:53:26.931       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Received event 10532_FBlockApplicationStatus_FB/255_DontCare with retry index 20! (msgId=21)
12:53:27.438     [Info] [iMX6.mcp]      [PERF:0x39a1072b:IO0] iMX6.Itr.ready
12:53:27.450     [Info] [iMX6.mcp]      [PERF:0x39ad47e0:IO0] iMX6.Debug.start
debug: 12:53:28.077      [Info] [iMX6.Debug.MESSAGE_CPU]       ComMgrInit: Test for JTAG is enabled is 0
12:53:28.104     [Info] [iMX6.mcp]      [PERF:0x3c40107f:IO0] iMX6.Debug.ready
itr: 12:53:28.534        [Info] [iMX6.Itr.devinfo]      DevInfo: SW-Version=0367- HW-Version=H30 PartNum=5Q0035840B  SerNum=SKZAZ2T5130178 Wdog=0 Mileage=0 VIN=-----------------
swdl: 12:53:29.139       [Info] [iMX6.SwDL.tsd.system.swdl]    Service Update pending - DownloadManager start in download pending state
swdl: 12:53:29.162       [Info] [iMX6.SwDL.tsd.system.swdl]    Continue update: MST2_EU_SK_ZR_P0367T
swdl: 12:53:29.175       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] using fused key
swdl: 12:53:29.178       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x7050001
swdl: 12:53:29.179       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x7050003
swdl: 12:53:29.180       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x7050005
swdl: 12:53:29.182       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x7050011
swdl: 12:53:29.183       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x7050009
swdl: 12:53:29.184       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x7050007
swdl: 12:53:29.185       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x705000b
swdl: 12:53:29.186       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x705000f
swdl: 12:53:29.187       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x705000d
swdl: 12:53:29.188       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x7050013
swdl: 12:53:29.189       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x7050015
swdl: 12:53:29.190       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.proxy] will handle event 0x7050017
swdl: 12:53:29.198      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x8100005
swdl: 12:53:29.212       [Info] [iMX6.SwDL.tsd.system.swdl.diagnosis.tpc.theftpr.secComClient.Sender15828]      sent SPRK_REQUEST
12:53:29.251     [Info] [iMX6.mcp]      [PERF:0x40c2a73b:IO0] iMX6.SwDL.ready
swdl: 12:53:29.312       [Info] [iMX6.SwDL.tsd.system.swdl]    Startup Times from main start:
swdl: 12:53:29.320       [Info] [iMX6.SwDL.tsd.system.swdl]    until DSI service registration      : 3625 ms
swdl:
swdl: 12:53:29.326       [Info] [iMX6.SwDL.tsd.system.swdl]    TSD Variant: 20
swdl: 12:53:29.328       [Info] [iMX6.SwDL.tsd.system.swdl]    TSD Version: 34
swdl: 12:53:29.330       [Info] [iMX6.SwDL.tsd.system.swdl]    VW Variant Id: 37205
netmgr: 12:53:31.066     [Info] [iMX6.NetMgr.networking.core]  registerAppRequest()
netmgr: 12:53:31.067     [Info] [iMX6.NetMgr.networking.core.appManager]        Adding Application with Name: tsd.mibstd2.logging InterfaceName:  and Bitmask: 0
netmgr: 12:53:31.067     [Info] [iMX6.NetMgr.networking.core.appManager]        getNextFreeId: 2
netmgr: 12:53:31.067     [Info] [iMX6.NetMgr.networking.core.appManager]        Added Application with ID: 2 | Name: tsd.mibstd2.logging on interface:
netmgr: 12:53:31.068     [Info] [iMX6.NetMgr.networking.core.appManager]        Port: 15361
netmgr: 12:53:31.068     [Info] [iMX6.NetMgr.networking.core.appManager]        Port: 54321
netmgr: 12:53:31.170     [Info] [iMX6.NetMgr.networking.core]  loading normal rule file.
netmgr: 12:53:31.170     [Info] [iMX6.NetMgr.networking.core.packetfilter]      loading Rule file...
j9/hmi: 16573530015   INFO [0x1, 0x1, 0xe6c15f22] DONE WITH ASL-STARTUP
j9/hmi: ####[ASLStartup v8] was: #######
j9/hmi: >> Calling Start on MIB ASLStdTechnisatActivator
j9/hmi: WORKUNIT_STARTUP_DSI__GENERIC
j9/hmi: WORKUNIT_ROOT__GENERIC
j9/hmi: WORKUNIT_EARLY_PERSISTENCE
j9/hmi: SPECIAL_METHOD_INITIAL_STARTUP_PROFILE_READY (modified preconditon)
j9/hmi: ## skipped: WORKUNIT_PERSONALIZATION_PROFILE_CHANGE, Cause: not used in SWDL
j9/hmi: WORKUNIT_EARLY_APPS__GENERIC
j9/hmi: ## skipped: SPECIAL_METHOD_WAIT_FOR_CODING_WAS_READ__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_EARLY_CAR__GENERIC, Cause: not used in SWDL
j9/hmi: WORKUNIT_DISPLAY__GENERIC
j9/hmi: WORKUNIT_LSC__GENERIC
j9/hmi: ## skipped: SPECIAL_METHOD_GET_LUM__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_AUDIO__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_TUNER_DAB__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_TUNER_AMFM__STD_SOP2, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_ASL_APPS_COMMON, Cause: not used in SWDL
j9/hmi: ## skipped: SPECIAL_METHOD_SEND_STARTUP_LUM_READY_AND_WAIT_FOR_GUI_SKIN_READY__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_PICTURESTORE__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_MEDIA__STD_SOP2, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_MEDIA_ADDITIONAL_BROWSER_INSTANCE__STD_SOP2, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_BAP__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_ADRESSBOOK__STD_SOP2, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_PHONE__STD_SOP2, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_SMARTPHONE_INTEGRATION_STD, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_OCU_ECALL__GEN2, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_MIRRORLINK, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_MESSAGING__HIGH_ESO, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_KOMBI_PICTURE_SERVER__GEN2_HIGH, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_PERSONALIZATION, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_CAR__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_CAR_BATTERYMANAGER__STD2_GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_HAS_SERVER__SOP2_GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_EXLAP__SOP2_GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_MEDIA_CONTROL, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_TESTMODE__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_SPEECH_ON_NO_NAV_TARGET__STD_SOP2, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_SPEECH_COMMON_CONTEXTS, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_OCU_ENI__GEN2, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_ONLINE_BOOTSTRAP, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_ONLINE_CORESERVICES_OCU_ADAPTER, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_ONLINE_CORESERVICES, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_INFOTAINMENTREC__GENERIC, Cause: not used in SWDL
j9/hmi: ## skipped: WORKUNIT_WIRELESS_CHARGING_STD, Cause: not used in SWDL
j9/hmi: WORKUNIT_SWDL__STD_SOP2
j9/hmi: ## skipped: WORKUNIT_POST__SOP1_HIGH_AND_SOP2_GENERIC, Cause: not used in SWDL
j9/hmi: ## Storing for Restart purposes: WORKUNIT_MODULE_RESTART_EXLAP__SOP2
j9/hmi: WORKUNIT_MODULE_RESTART_EXLAP__SOP2
j9/hmi: ## Storing for Restart purposes: WORKUNIT_MODULE_RESTART_SPEECH__SOP2_STD
j9/hmi: WORKUNIT_MODULE_RESTART_SPEECH__SOP2_STD
j9/hmi: ########## END #########
j9/hmi: 16590707181   INFO [0x1, 0x100000, 0xe6c15f22] STD_KEY_TRAIN_VERSION: MST2_EU_SK_ZR_P0367T
j9/hmi: 16593811878   INFO [0x1, 0x100000, 0xe6c15f22] STD_KEY_MU_VERSION: 5Q0035840B 5Q0035840B 0367H30
12:53:31.763     [Info] [tsd.mibstd2.hmi.bootanim.j5]   write black image
12:53:31.773     [Info] [tsd.mibstd2.hmi.bootanim.j5]   cda: splash image posted.
12:53:31.774     [Info] [tsd.mibstd2.hmi.bootanim.j5]   show black image
j9/hmi: 16874660318   INFO [0x4000, 0x4, 0x4f3e979a] UI thread started!
j9/hmi: 16929759757   WARN [0x8, 0x4, 0xbbad0b83] Unable to access generated day-image id=0 (missing image (bitmap 1)) - setting to default empty image.
swdl: 12:53:31.807       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::getDeviceState:
swdl: 12:53:31.810       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::TestModuleCnf: pending=0, module_ok=1, hardware=0x201a, firmware=0xc194
swdl: 12:53:31.811       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::getDeviceState: return module_state=ready
swdl: 12:53:31.817       [Info] [iMX6.SwDL.tsd.system.swdl]    DownloadThread::run() -> run software download thread.
swdl: 12:53:31.818       [Info] [iMX6.SwDL.tsd.system.swdl]    Start execution of update tasks:
j9/hmi: 16929915136   WARN [0x8, 0x4, 0xbbad0b83] Unable to access generated night-image id=0 (missing image (bitmap 1)) - setting to default empty image.
j9/hmi: 16934510075   INFO [0x80000000, 0x10, 0xbbad0b83] init screenSimpleDesktopLayout
j9/hmi: 16934761318   INFO [0x80000000, 0x10, 0xbbad0b83] create dude for screen area ScreenAreaPopup
j9/hmi: 16938753924   INFO [0x80000000, 0x10, 0xbbad0b83] create dude for screen area ScreenAreaStage
j9/hmi: 16959838787   WARN [0x80000000, 0x20, 0xbbad0b83] no provider registered for content HMI_CAR_BAR
j9/hmi: 16959994560   WARN [0x80000000, 0x20, 0xbbad0b83] no provider registered for content HMI_CLIMATE_BAR
j9/hmi: 16960081075   WARN [0x80000000, 0x20, 0xbbad0b83] no provider registered for content HMI_STATUS_BAR
j9/hmi: 16960143378   WARN [0x80000000, 0x20, 0xbbad0b83] no provider registered for content HMI_HOMEBUTTON
j9/hmi: 16960197984   WARN [0x80000000, 0x20, 0xbbad0b83] no provider registered for content HMI_GRIDMENU
j9/hmi: 16964827060   INFO [0x400, 0x40000000, 0xbbad0b83] last known requested Language: en_US
j9/hmi: 16964903272   INFO [0x400, 0x40000000, 0xbbad0b83] en_US/ GUI
j9/hmi: 16965050000   INFO [0x400, 0x40000000, 0xbbad0b83] All ok
j9/hmi: 18271656242   INFO [0x40000, 0x10, 0xbbad0b83] ViewCompositor initialized
j9/hmi: 18905451363   INFO [0x40000, 0x1, 0xbbad0b83] First view shown
j9/hmi: 18948249848   INFO [0x1, 0x1000, 0xe6c15f22] [ASLDisplayManagementTarget] First context switch was performed. HMI is displayed now.
j9/hmi: 18952242212   INFO [0x4000, 0x2, 0x75c3c111] Starting lateload bundles ...
j9/hmi: 18991364075   INFO [0x1, 0x100000, 0xe6c15f22] [AslTargetSWDL] normal SWDL detected .. setting notifications
swdl: 12:53:31.907       [Warn] [iMX6.SwDL.tsd.system.swdl]    No download plan for device bluetooth! Is it a new device?
swdl: 12:53:31.910       [Warn] [iMX6.SwDL.tsd.system.swdl]    No download plan for device inic! Is it a new device?
swdl: 12:53:31.911       [Warn] [iMX6.SwDL.tsd.system.swdl]    No download plan for device powerc! Is it a new device?
j9/hmi: 19207167833   INFO [0x200, 0x2, 0x469c13ce] current.gui.language:=en_US;;protocol.version:=1.2;;skin.short.version:=Skoda_STD_Skin_C_80_S-STD2Plus_EU-3;;hmisoftware.version:=H28.28.197_STD2Plus_EU;;hmisoftware.base.version:=H28.28.197-201706191425;;generic.event.count:=81;;logmessage.count:=103/0;;active.debug.probes:=NONE;;car.time:=1713817376928;;generic.event.queue.size:=5;;logmessage.queue.size:=104/2000;;logmessage.data.size:=40KB;;time:=2024-04-22 20:22:56
swdl: 12:53:32.367       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      AbtCanDevice: get device info failed with 255
swdl: 12:53:32.368       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      AbtCanDevice::getDeviceInfo() second attempt!
j9/hmi: 20086506924   WARN [0x40000000, 0x1, 0x75c3c111] [DebugInterface] - Couldn't load Testinterface functions: Class not found!
j9/hmi: 20089148681   INFO [0x40000000, 0x1, 0x75c3c111] --- DebugInterface ready to rumble! ---
netmgr: 12:53:33.522     [Info] [iMX6.NetMgr.networking.core.pfTask]    loadRuleFile() succedded.
swdl: 12:53:34.038       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/system/wd_dump.sh") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.041       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/system/check_fs") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.044       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/system/postcoredump") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.047       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/system/shutdown") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.049       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/system/precoredump") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.051       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/system/pps_ramdisk.sh") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.053       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/system/preshutdown") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.055       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/system/mm-renderer.sh") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.059       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/system/startup") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.062       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "config"-readVersionFromELFFile("/tsd/bin/startup") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.079       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "debugtool"-readVersionFromELFFile("/tsd/bin/debugtool/scripts/GenerateTrace.sh") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.148       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "i2cbridge"-readVersionFromELFFile("/tsd/bin/i2cbridge/Usb2530BridgeLauncher.sh") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:34.435       [Warn] [iMX6.SwDL.tsd.system.swdl.device]      readDependencies "systemimage"-readVersionFromELFFile("/tsd/bin/ifs/system.ifs") throws "couldn't not allocate ELF cookie"!
swdl: 12:53:35.472       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::getFirmwareVersion: updater_hw=2 from alps_hw=0x201a, sop3, updater_fw=3194 from alps_fw=0xc194
swdl: 12:53:35.474       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothDevice::getCurrentSwVersions: hw=2, fw=3194
swdl: 12:53:35.861       [Info] [iMX6.SwDL.tsd.system.swdl.planbuilder] Current version of SWDL: 3367002
swdl: 12:53:35.865       [Info] [iMX6.SwDL.tsd.system.swdl.planbuilder] don't enable user defined selection
swdl: 12:53:35.867       [Info] [iMX6.SwDL.tsd.system.swdl.planbuilder] Try metainfo key file from emmc.
swdl: 12:53:35.871       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    using fused key
swdl: 12:53:35.873       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x7050001
swdl: 12:53:35.874       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x7050003
swdl: 12:53:35.875       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x7050005
swdl: 12:53:35.876       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x7050011
swdl: 12:53:35.877       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x7050009
swdl: 12:53:35.878       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x7050007
swdl: 12:53:35.879       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x705000b
swdl: 12:53:35.880       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x705000f
swdl: 12:53:35.881       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x705000d
swdl: 12:53:35.882       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x7050013
swdl: 12:53:35.883       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x7050015
swdl: 12:53:35.883       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.proxy]    will handle event 0x7050017
swdl: 12:53:35.884      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x7050001
swdl: 12:53:35.885      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x7050003
swdl: 12:53:35.886      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x7050005
swdl: 12:53:35.887      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x7050011
swdl: 12:53:35.888      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x7050009
swdl: 12:53:35.891      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x7050007
swdl: 12:53:35.892      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x705000b
swdl: 12:53:35.893      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x705000f
swdl: 12:53:35.893      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x705000d
swdl: 12:53:35.894      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x7050013
swdl: 12:53:35.895      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x7050015
swdl: 12:53:35.896      [Error] [iMX6.SwDL.tsd.communication.serializer]        Serializer already registered for event 0x7050017
swdl: 12:53:35.899       [Info] [iMX6.SwDL.tsd.system.swdl.trustedkey.theftpr.secComClient.Sender3695]  sent SPRK_REQUEST
swdl: 12:53:35.919       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Re-issuing download control command (Retry 1 of 2)
swdl: 12:53:36.031       [Info] [iMX6.SwDL.tsd.system.swdl.MetaInfoKey] key successfully read from file
swdl: 12:53:36.033      [Error] [iMX6.SwDL.tsd.system.swdl.checkSignature]      No valid exception list available.couldn't open file for reading
swdl: 12:53:36.036       [Info] [iMX6.SwDL.tsd.system.swdl.checkSignature]      Signature of metainfo2.txt is valid.
swdl: 12:53:36.038       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothUpdater::getFirmwareVersion: updater_hw=2 from alps_hw=0x201a, sop3, updater_fw=3194 from alps_fw=0xc194
swdl: 12:53:36.039       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothDevice::getDeviceHwVersion: hw=2
swdl: 12:53:36.874       [Info] [iMX6.SwDL.tsd.system.swdl.device]      BluetoothDevice::getDownloadType: btfirmware, Default#Application, download_type=application
swdl: 12:53:36.890       [Info] [iMX6.SwDL.tsd.system.swdl.planbuilder] btfirmware needs "/tsd/bin/swdownload/tsd.mibstd2.system.swdownload" : 3101.236
swdl: 12:53:36.891       [Info] [iMX6.SwDL.tsd.system.swdl.planbuilder] "/tsd/bin/swdownload/tsd.mibstd2.system.swdownload" is available
swdl: 12:53:36.945       [Warn] [iMX6.SwDL.tsd.system.swdl]    No download plan for device bluetooth! Is it a new device?
swdl: 12:53:36.947       [Warn] [iMX6.SwDL.tsd.system.swdl]    No download plan for device inic! Is it a new device?
swdl: 12:53:36.948       [Warn] [iMX6.SwDL.tsd.system.swdl]    No download plan for device powerc! Is it a new device?
swdl: 12:53:36.953       [Info] [iMX6.SwDL.tsd.system.swdl]    Found 2 modules to be updated.
swdl: 12:53:36.972       [Info] [iMX6.SwDL.tsd.system.swdl.customer]    No customer-updatable modules found.
swdl: 12:53:36.974       [Info] [iMX6.SwDL.tsd.system.swdl]    device uses partitions: true
swdl: 12:53:36.975       [Info] [iMX6.SwDL.tsd.system.swdl]    called stat() for /dev/hd0t177
swdl: 12:53:36.976       [Info] [iMX6.SwDL.tsd.system.swdl]    old partition table found
swdl: 12:53:36.977       [Info] [iMX6.SwDL.tsd.system.swdl]    try to (re)mount /dev/hd0t177 on /
swdl: 12:53:36.980       [Info] [iMX6.SwDL.tsd.system.swdl]    try to (re)mount /dev/hd0t177.1 on /tsd/etc/swap_keys
swdl: 12:53:36.982       [Info] [iMX6.SwDL.tsd.system.swdl]    Update Step: PreScripts
swdl: 12:53:36.983       [Info] [iMX6.SwDL.tsd.system.swdl]    Update Step: Bootloader
swdl: 12:53:36.984       [Info] [iMX6.SwDL.tsd.system.swdl]    Update Step: System
swdl: 12:53:36.985       [Info] [iMX6.SwDL.tsd.system.swdl]    Update Step: Application-Exclusive
swdl: 12:53:36.985       [Info] [iMX6.SwDL.tsd.system.swdl]    Update Step: Applications
swdl: 12:53:36.987       [Info] [iMX6.SwDL.tsd.system.swdl]    Update Step: Emergency Images
swdl: 12:53:36.988       [Info] [iMX6.SwDL.tsd.system.swdl]    Write DownloadState: 3 to persistence.
swdl: 12:53:37.012       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] startModuleUpdate cpuplus::emergency
swdl: 12:53:37.017       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] startModuleUpdate mainplus::emergency
swdl: 12:53:37.023       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 0]], ATTRVALIDFLAG_VALID)
swdl: 12:53:37.037       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 0], ["mainplus::emergency", 1, 0]], ATTRVALIDFLAG_VALID)
swdl: 12:53:38.293       [Info] [iMX6.SwDL.tsd.system.swdl.device]      Parallel Flash Write Protection disabled
swdl: 12:53:40.926       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 11], ["mainplus::emergency", 1, 6]], ATTRVALIDFLAG_VALID)
swdl: 12:53:41.793       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 13], ["mainplus::emergency", 1, 10]], ATTRVALIDFLAG_VALID)
j9/hmi: 30055644318  ERROR [0x1, 0x4000000, 0xe6c15f22] DSI timeout occurred. timeout=10000ms, request=org.dsi.ifc.keypanel.DSIKeyPanel[0].setGenericSetting: "genericSettingResponse" did not arrive.
swdl: 12:53:43.202       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 20], ["mainplus::emergency", 1, 14]], ATTRVALIDFLAG_VALID)
swdl: 12:53:45.005       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 26], ["mainplus::emergency", 1, 20]], ATTRVALIDFLAG_VALID)
swdl: 12:53:45.875       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 31], ["mainplus::emergency", 1, 22]], ATTRVALIDFLAG_VALID)
swdl: 12:53:45.930       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.mgr]     Re-issuing download control command (Retry 2 of 2)
swdl: 12:53:48.035       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 39], ["mainplus::emergency", 1, 30]], ATTRVALIDFLAG_VALID)
swdl: 12:53:48.081       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 40], ["mainplus::emergency", 1, 30]], ATTRVALIDFLAG_VALID)
swdl: 12:53:50.280       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 50], ["mainplus::emergency", 1, 37]], ATTRVALIDFLAG_VALID)
swdl: 12:53:51.078       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 52], ["mainplus::emergency", 1, 40]], ATTRVALIDFLAG_VALID)
swdl: 12:53:52.906       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 61], ["mainplus::emergency", 1, 46]], ATTRVALIDFLAG_VALID)
swdl: 12:53:54.103       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 65], ["mainplus::emergency", 1, 50]], ATTRVALIDFLAG_VALID)
swdl: 12:53:55.071       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 70], ["mainplus::emergency", 1, 53]], ATTRVALIDFLAG_VALID)
swdl: 12:53:55.942       [Warn] [iMX6.SwDL.tsd.system.swdl.device.most.stm]     Failed to set all MOST devices into download mode.
swdl: 12:53:57.103       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 78], ["mainplus::emergency", 1, 60]], ATTRVALIDFLAG_VALID)
swdl: 12:53:57.302       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 80], ["mainplus::emergency", 1, 60]], ATTRVALIDFLAG_VALID)
swdl: 12:54:00.105       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 82], ["mainplus::emergency", 1, 70]], ATTRVALIDFLAG_VALID)
j9/hmi: 49210319409   INFO [0x200, 0x2, 0x469c13ce] current.gui.language:=en_US;;protocol.version:=1.2;;skin.short.version:=Skoda_STD_Skin_C_80_S-STD2Plus_EU-3;;hmisoftware.version:=H28.28.197_STD2Plus_EU;;hmisoftware.base.version:=H28.28.197-201706191425;;generic.event.count:=180;;logmessage.count:=316/0;;active.debug.probes:=[DSIEVENTS];;car.time:=1713817405928;;generic.event.queue.size:=0;;logmessage.queue.size:=4/2000;;logmessage.data.size:=103KB;;time:=2024-04-22 20:23:25
swdl: 12:54:03.121       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 86], ["mainplus::emergency", 1, 80]], ATTRVALIDFLAG_VALID)
swdl: 12:54:05.609       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 90], ["mainplus::emergency", 1, 84]], ATTRVALIDFLAG_VALID)
swdl: 12:54:08.434       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 93], ["mainplus::emergency", 1, 90]], ATTRVALIDFLAG_VALID)
swdl: 12:54:13.226       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["cpuplus::emergency", 1, 100], ["mainplus::emergency", 1, 99]], ATTRVALIDFLAG_VALID)
swdl: 12:54:13.232       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] finishModuleUpdate cpuplus::emergency
swdl: 12:54:13.714       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] SwdlProgressListener.updateDevicesOverviewProgress([["mainplus::emergency", 1, 100]], ATTRVALIDFLAG_VALID)
swdl: 12:54:13.725       [Info] [iMX6.SwDL.tsd.system.swdl.dsi] finishModuleUpdate mainplus::emergency
swdl: 12:54:13.744       [Info] [iMX6.SwDL.tsd.system.swdl]    Write DownloadState: 1 to persistence.
swdl: 12:54:13.763       [Info] [iMX6.SwDL.tsd.system.swdl]    Update Step: PostScript
swdl: 12:54:13.765       [Info] [iMX6.SwDL.tsd.system.swdl]    MainUnit update detected, at least one module was successfully updated
swdl: 12:54:13.767       [Info] [iMX6.SwDL.tsd.system.swdl]    cpuboot Result: 2 Section: 1
swdl: 12:54:13.860       [Info] [iMX6.SwDL.tsd.system.swdl]    device uses partitions: true
swdl: 12:54:13.861       [Info] [iMX6.SwDL.tsd.system.swdl]    called stat() for /dev/hd0t177
swdl: 12:54:13.862       [Info] [iMX6.SwDL.tsd.system.swdl]    old partition table found
swdl: 12:54:13.862       [Info] [iMX6.SwDL.tsd.system.swdl]    try to (re)mount /dev/hd0t177 on /
swdl: 12:54:13.864       [Info] [iMX6.SwDL.tsd.system.swdl]    try to (re)mount /dev/hd0t177.1 on /tsd/etc/swap_keys
swdl: 12:54:13.878       [Info] [iMX6.SwDL.tsd.system.swdl]    Finish execution of update tasks.
j9/hmi: 61093087393   INFO [0x1, 0x100000, 0xe6c15f22] [AslTargetSWDL] Send Event: SWDL_SYSTEM_FINISHED for reboot popup
swdl: 12:54:16.880       [Info] [iMX6.SwDL.tsd.system.swdl]    Trigger SWDL restart.
swdl: 12:54:16.881       [Warn] [iMX6.SwDL.tsd.system.swdl.anim]        BootAnimFlasher::loopToCheckBootAnim(): Exception: BootAnimFlasher::checkFlashContent() did not get a chance to work
swdl: 12:54:19.428       [Info] [iMX6.SwDL.tsd.system.swdl]    Send restart Event.
j9/hmi: 66701363833   INFO [0x1, 0x800, 0xe6c15f22] [AslTargetSystemPowerManagementHandling] Update Power State: POWERSTATE_OFF (Or MMI_IOC)
j9/hmi: 66701840606   INFO [0x1, 0x800, 0xe6c15f22] <cp = ScreenAreaStage> <content = HMI_USER_PERCEIVED_OFF>
j9/hmi: 66704572984   INFO [0x1, 0x1, 0xe6c15f22] [ASLStartup v8]Powerstate detected by Startup Manager: 0
Hello!
Octavia MKIII 2017
If is possible to provide me latest software update for Device part number: 5Q0035874C
Hardware:H41
Software:0456
Thanks!
I would really appreciate if somebody could provide me with new firmware for this:
Also: Any info on updates/fixes included will be appreciated!
hello,
Can somebody help me with an update for my Amundsen?
How can i check if my car support CarPlay Wireless and how can it be activated or configured?
Hello! Do you know how I can add the Bulgarian language to the Amundsen MIB2 menu? With VCDS I can't add it. There are many languages, but only 10 are active.
Hello! Do you know what model this media is and is there a new update?
Всем привет. Может кто-нибудь поделиться последней версией? Шкода Октавия 5е. Заранее спасибо.
Edited by Maks
@pab567
Can you please provide a firmware for 5Q0035840c h41 newer than 0475? And how can i enable wifi android auto please?
Thank you
20240511_124125.heic
Hi @pab567!
Can I get a new update please?
2019 Karoq
Serial : 5Q0035840C
Hardware : H41
Software : 0468
Thanks a lot.
On 08/05/2024 at 19:35, andrei_horeica said:
hello,
You have the latest available firmware. This unit does NOT support wireless SmartLink.
This is Composition Media PQ MY16. Languages are coded in the firmware, I beleive BUlgarian is not available in this one and cannot be added just like that.
All others check your PM
@pab567
Thanks for the Quick support but it will not upload. Check photo please.
Thank you
Finally, update succeded.
Is there a way to activate wifi android auto? Works only by cable and with some chinese toy attached...
No native support, only via external third party adapter connected to USB
