Amundsen MIB2 Firmware Update
2 minutes ago, pab567 said:
Ciò significa che hai fatto qualcosa di sbagliato. Usa SWDL manuale e seleziona tutto tranne emergency in Main ed emergency in CPU.
I actually did it with manual swdl and selected everything and then I gave it start update and tried it again twice. When I tried to update directly from the classic mode, it wouldn't let me start the update.
Do you have the 480t software to send me? I don't want mine to be incomplete. Although it is 4GB, I think that's correct.
Edited by augusto73roma
  • Replies 4.6k
  • Views 814.4k
Sent in PM
3 minutes ago, pab567 said:
Inviato in PM
Thank you very much but the one you sent me is Skoda I have VW :-)
Sent
4 minutes ago, pab567 said:
Sent
Thank you very much. You are truly a kind person. Is the procedure always the same? I do the swdl patch and then modify the metainfo file, right?
@pab567 could you provide me with an firmenware update for my navigation system? Thx in advance.
Edited by Sanbu
Yes, it is the same.
@Sanbu sent in PM
Edited by pab567
Thank you so much !! 👍
16 hours ago, pab567 said:
Sì, è la stessa cosa.
Good morning, I tried installing with your software but it does the exact same thing. It only updates two parameters and that's it and nothing changes. But could it be that I have to apply the patch now that I've installed the 480t and then try to reinstall from scratch? Otherwise, I don't understand why this is happening. Unless my infotainment system has some strange blockage caused by the previous owner that I don't know about. I have everything working fine, Android Auto, CarPlay, etc. I just wanted to have nicer graphics. But is there a way to load nicer or more custom skins? Thanks a lot.
Look dont get this wrong, but simplest explanation to your question.
Device itself “knows” which modules will upgrade due to file versions allready installed.
As for infotaiment you cant change hardware resolution of the screen to have nicer picture,
It is what it is…
Br
Djadjo
17 minutes ago, Djadjo78 said:
Guarda, non fraintendermi, ma la spiegazione più semplice alla tua domanda.
Il dispositivo stesso "sa" quali moduli verranno aggiornati in base alle versioni dei file già installate.
Per quanto riguarda l'infotainment non è possibile modificare la risoluzione hardware dello schermo per avere un'immagine più bella,
È quello che è…
Fratello
Djadjo
Thanks a lot, bro, yes, but I meant to be able to change the icons with the latest version of the software. I still have the old theme icons. Isn't there a way to activate the new ones? Thanks.
Pls contact @ricSKODAoct he has prepared some nice manual
26 minutes ago, pab567 said:
Per favore contattaci@ricSKODAoctha preparato un bel manuale
Okay, thank you so much.
@ricSKODAoct
Can you help me, please? 🙃
Hi this is current version on my infotainment. Is there a software update available? Many thanks
Hi!
Can someone send me this update? :)
MST2_EU_SK_ZR_P0480T
I was able to download my desired MIB from mibsolution web. Seams like Cloudflare is blocking the connection cause server has some issues and is slow with unstable connection. But its there. If you can write the link as specific as possible you may be able to get the right spot. You might try starting website as not secure http://. It took me lot of patience and multiple tries with multiple browsers but I finally got it.
So I looked for MST2_EU_SK_ZR_P0369T and figured out the link for the folder is like this
https://mibsolution.one/#/1/9/MST2 - TechniSat Preh/Firmware/SKODA_ZR/EU
Yes now it is available as you wrote. Thank you!
Hi, to my understanding, this should be the latest official firmware update for my car: MST2_EU_SK_ZR_P0253T
Could someone send this to me, thanks?
Should this update also help with the Android Auto issue as it suddenly stopped working after updating phone to the latest software version? I have already tried everything possible, but phone still says there is the Android Auto communication error 8.
No image preview
MEGA
MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB now
Password write PM
11 hours ago, Skodaillaan said:
That website is down, bad gateway error.
Now it works, great. The website is very slow and download speed is unstabble.
Edited by Skodaillaan
Hi, I would like to ask if there is an update for this version?
Hello @pab567 Can you send me the new Firmware pls?
