Amundsen MIB2 Firmware Update
I have 5Q0035842C unit with H41 and 0471
Any updates on this please PM
Thank you
  • Replies 4.6k
  • Views 852k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
8 hours ago, pab567 said:
Yes, you can but APP button will not work
Thanks, is 5E0919605M the one I really need then?
Edited by Strebord
13 hours ago, pab567 said:
So now you have Bolero MIB1, with Bluetooth, with DAB, part number 5E0035842A, with USB 5Q0035726B and fortunately you don't have CANTON sound system.
You can install one of four different OEM glove box units:
- MIB2 Bolero
- MIB2 Amundsen
- MIB2 Columbus
- MIB2.5 Columbus
You also need to replace display unit:
- for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N
- for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M
- for MIB2.5 Columbus the only display unit that works is 5E0919606D
If you woulkd like to use Apple CarPlay then you also have to replace USB port.
The question is what is your budget and which of listed below features are "must have":
- Video playback from DVD, USB, SD
- CD playback
- OEM navigation
- displaying OEM maps in Virtual Cluster (Active Info Display).
All units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. features that differ them:
- MIB2 Bolero - no OEM navigation, no CD/DVD drive, no video playback from SD/USB
- MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
- MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster)
- MIB2.5 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
Thanks for your reply Pab
Really I just want to be able to use apple CarPlay with a decent sized screen. How much are we looking at? do you supply them ?
- Video playback from DVD, USB, SD - not overly
- CD playback - maybe
- OEM navigation - no
- displaying OEM maps in Virtual Cluster (Active Info Display). - no
6 hours ago, pab567 said:
Usually it takes 10-20 minutes, can be done with ignition off.
Worked perfectly, 15 minutes and it was done, many Thanks
Great!
Edited by pab567
If you skip CD then Bolero MIB2 is enough. Yes, I can supply, just need your location and decisions on display and USB. Pls contact me in PM if you are interested.
This is your choice...
It doesn’t let me pm you @pab567 can you pm me please
Message sent
On 05/06/2025 at 13:44, Stingray77_NL said:
This is my system, Can anyone help me with the MST2_EU_SK_ZR_P0480T firmware to update to 480? Thanks!
Anyone has the MST2_EU_SK_ZR_P0480T firmware available for me? My New iPhone keeps disconnecting. :(
Please PM. Thank you!
Pab567 mam prośbę odnośnie mojego radia,możesz napisać do mnie priv ?
On 05/06/2025 at 07:29, pab567 said:
Pla wait until "Software" filed contains data and post again
PM
Subject: Request: MST2_EU_VW_PQ_P0480T (0480T-2) firmware
Message:
Hi everyone, I’m updating a VW Jetta 2018 MIB2 (PQ, Composition/Discover Media). Current version is P0478T. Could someone please PM me the download link (Mega/Drive) for MST2_EU_VW_PQ_P0480T(0480T-2)? Thanks!
Hello.
New to me 2016 Octavia VRS tdi. I would like to enable smart link for car play and android auto. But before that, should I update the firmware and do I really need a *4** version or can I just stick with the latest available *3** update?
Thanks.
@pab567
Hi pab567,
Is there a software update available for the below please?
Device Part # - 5Q0035842A
Hardware: H24
Software: 0252
Installed Software Version - MST2_EU_SK_ZR_P0253T
H25.14.89_STD2Plus_EU
Many thanks in advance,
Hello,
I hope you're doing well!
I would kindly like to ask if it's possible to get access to the firmware update MST2_EU_SK_ZR_P0480T for my Skoda MIB2 unit.
My current version is MST2_EU_SK_ZR_P0475T, and I would really appreciate your help if there is an available update.
Thank you in advance for your time and support!
Best regards,
Hi there,
Can anybody help me with the software MST2_EU_SK_PQ_P0253T
This should be the best firmware update for my skoda octavia III from 2016 wich now still has
MST2_EU_SK_ZR_P0245T
Ive been told my car needed that updat, but trying to find out if that is the truth or that i maybe need a different one.
I've been looking in the mib helper site for the p0253t version, but software wasn't there anymore.
Ik hope that somebody can tell or send it (the zip file) to me
Thanks already
Justin
@Jetmech
Hi. If you want to update to version 0480, I can do it for you and activate SmartLink. With the new software, the entire infotainment graphics will change and you will be able to switch from the classic menu to the square one. The system is also faster than the old version.
3 minutes ago, Joco776 said:
@Jetmech
Здравей. Ако искаш да актуализираш до версия 0480, мога да го направя вместо теб и да активирам SmartLink. С новия софтуер цялата графика на инфотейнмънта ще се промени и ще можеш да превключваш от класическото меню към квадратното. Системата е и по-бърза от старата версия.
Hello,
I would like to ask if there is a file available for the software update so that I can proceed with updating it.
At the moment, SmartLink is activated, but it only works via cable.
@VBGSKO
Smartlink will only work via cable as this unit cannot do that. MIB3 only.
9 hours ago, Joco776 said:
@Jetmech
Hello Joco776. Thank you for replying. I am interested. What is the procedure?
Exactly same position as all above me in this thread.
MIB Solution all folders empty.
Looking for "Latest official firmware update: MST2_EU_SK_ZR_P0253T"
I will continue to work to a solution and share update here for benefit of others. In the meantime, if anybody has a solution I would be eternally grateful if they could share.
20 hours ago, VBGSKO said:
Hello,
You need to get a wireless adapter. Something like this. WIRELESS ADAPTER
Seat Mib2 Std MST2_EU_SE_ZR_P0359T software ?
