Mib 2 high and 2.5 high SW update
2 hours ago, RomanB said:
Nothing, except 1555 FW update error (could be found while scanning) could be easily deleted by odis VSDC obd and so on, rest of function will be the same.
Great thanks. I’ve read some people say that you need to do the update with the ignition on or can I do it with the engine running?
  • Replies 143
  • Views 91.9k
  • There are 2 versions of Columbus:- - MIB2 with buttons on the side - MIB2.5 without buttons (from MY18 onwards)   Mine is MY17.
  • SkudMissile21
    SkudMissile21
    Just a word of warning to anyone here doing a diy firmware upgrade, it seems it’s possible you may end up with a fault code logged that cannot be cleared afterwards (Carista lists it as “01555 motors
  • VCDS CODING 5F (Infotainment) module, Adaptations, channel: 'Confirmation of installation change' Note your current coding Start Windows calculator and set it to 'Programming mode' and select 'HEX'
Official way, turn off engine, use charger for battery, open the door turn on emergency stop lights.  But you can do it at any way I did it while my driving.
Great, got it updated with no issues with the engine running. I noticed in one of the other MEGA directories is a file called MHI2_ER_SKG13_P4526_MU1440_PATCH.7z - Not sure what this is for as when downloaded its a weird file type. Im assuming its a more up-to-date patch for the one I installed?
It was described here and here
Can someone please tell me which file to use? The links seem to be down.
3 hours ago, RomanB said:
If you have mib 2.5 last fw is 1440 https://mega.nz/folder/b4VkmDJJ#PE2C7Te_Yl0pw1TydB--Bg/folder/u49kwACD but you need check your train first (press menu for 10 sec)
Thank you for your Reply RomanB. I will download that file. Thank you for the link. And yes, it is a mib 2.5.
The software train:
The software train:
So then 1440 last available fw
Thank you for your help RomanB. Updated this afternoon. All went well and smooth. For others: due to the size of my SD card i was unable to format it in FAT32. Used exFAT and all went well.
Is it just me or are the links no longer working?
Not sure which link you did try, but this  works OK or torrent
MIB Solution (4).torrent
I would like to ask for an advice. I have MST2_EU_SK_ZR_P0456T. Which version should I update to?
The Mega link you provided is protected by password.
Thank you so much for your help and time.
14 minutes ago, Luei said:
https://mega.nz/folder/b4VkmDJJ#PE2C7Te_Yl0pw1TydB--Bg/file/O81SRAhD 478 LAST AVAILIABLE ONE
hi,
Do you know what does the upgrade to 1440 add to the 1382 ?
Currently on MHI2_ER_SKG13_P4523_1 SW MU version 1382, and wondering if this is worth upgrading to?
Does it actually affect warranty at all ? still have 1 year left(private buy) so do no want to give them (skoda) excuses later down the line if somethings goes belly up ?
ta
8 hours ago, sahar said:
hi,
ta
Hi i don't have TPI to give you an answer what they fixed in 1440, it defenetly will not give you any significant changes. It will not affect for waranty if you will delete 1555 error after update.
if I'm only doing a standard up to the latest that my train supports, do I need to worry about 'patching'?
Patch are need only if you want to unlock some feature. if not just update FW
Hi, i yesterday installed SW update 1433. How i can change theme/skin to interface SuperB 3FL ? Thanks
Where I can find what futures does it unlock? Thank you.
List of features that could be unlock of cource most of them you already have
SupportedFSC]
fsc = "00030000" # AMI
fsc2 = "00030001" # Gracenote
fsc3 = "00040100" # Navigation
fsc4 = "00050000" # Bluetooth
fsc5 = "00060100" # Vehicle Data Interface
fsc6 = "00060200" # Skoda/Audi Connect, VW CarNet
fsc7 = "00060300" # Mirror Link
fsc8 = "00060400" # Sport HMI
fsc9 = "00060500" # Sport Chrono
fsc10 = "00060600" # LogBook
fsc11 = "00060700" # Online Services
fsc12 = "00060800" # Apple CarPlay
fsc13 = "00060900" # Google Android Auto
fsc14 = "00070100" # SDS
fsc15 = "00070200" # SDS for Nav
fsc16 = "00070400" # Digital Voice Enhancement
# Skoda MIB2 NavDB LifeTime
fsc17 = "083000FF" # EU
fsc18 = "083D00FF" # ROW
Hello, i have octavia 3 - can i use this two link for update?
How i have use a patch for unlock fsc8 = "00060400" # Sport HMI ?
many thanks for help.1615205065693.thumb.jpg.c3a6db3f98935ba99efbc78e832f1481.jpg
I heard that the MIB2 could be software updated somehow to 2.5, and that you'd just then need the bigger screen. Does anyone know if it's true, or know how that's done?
@RomanBso i have HMI2_ER_VWG13_P3637 0913, and i downloaded MHI2_ER_VWG13_K4525 1367 but in the metadata2.txt it doesnt come under the supported firmwares but it also not under the blocked trains too. so what do you think i may need?
also i extracted it and tried to open the .img file but it comes up it corrupted, any ideas on that too?
many thanks
VWjap
