MY17 Superb Retrofitted with Direct TPMS
Yes, mib2 and Dashboard same time
  • Replies 146
  • Views 33.8k
  • It depends what system your wife's car has. Indirect systems don't have physical pressure sensors, instead they rely on rotational differences between the wheels (via the ABS sensors) so would just ne
  • We can now, thank feck
  • I'll post up the exact VCDS/OBDEleven coding steps shortly. I'll also post up the link that allows u to create the RDX parameter file, to b loaded via VCP/ODIS.
Having MIB3 too?
Is normaly Dashboard Coding
Set Activ
Thanks! On Karoq I didn't see this voice (of course in English or Italian); looks like is not supported but I'll look better
No warrenty
Byte 11 Bit 02
Karoq Model 2025 have This Option
Edited by Cairus
Mine is 2022; have to check via obd11 if this coding leaves it permanently
On dash screen tyre pressure can I see it when I select my car on screen. If I have something else on dash screen , yes pressure come on display just if I got lost pressure in one of the tyre! I'm happy with that. Cheers!
Exactly as me; I thought there was a way to show the pressure even when a tire (or more than one) doesn’t loose pressure
You have Code my Information?
Look Here
Direct TPMS always displays the tyre pressure, regardless of pressure loss.
I told you so 😜
2 hours ago, Cairus said:
I told you so 😜
Yes! but @JR RS doesn't have the VC; however I sent the coding You provided me (thank You for it) to the mechanic. As long as he'll try I'll let You know!
For @JR RS : You can find this voice into the "vehicle status" on the menu of the Cockpit Cluster?
Edited by Benja77
It doesn't matter what type of speedometer is installed.
My TPMS retrofit on a MY18 Octavia works on both the headunit and virtual cluster at the same time...
Did You make the coding suggested by @Cairus ? Or if not, which did You do?
By Retrofit you need every time the Dash Coding
This post on rosstech feels about right https://forums.ross-tech.com/index.php?threads/30780/#post-258952
Certainly the changes to 03 and 17 seem to match my old logs - although it looks like I might have disabled address 17, byte 11, bit 1 as well as enabling bit 2. It was three years ago and I haven't got any notes weirdly 🤷
On 19.11.2025 at 16:43, Benja77 said:
Hast du den von@CairusOder falls nicht, was haben Sie getan?
News?
Not yet
Found it: It was in the CAR STATUS menu!!!
Edited by Benja77
Hello guys,
Do you have any idea about the TPMS kits that are being sold on Aliexpress? Are there any good or there is a big chance that I end up buying a fake OEM module?
I am thinking of retrofitting this on to my Skoda Karoq 2019.
Thank you!
"independent" kits definitely worth money which they cost,
just together with price, also quality comes down ☹️
the first full set i bought for 53 euros + 35 euros for additional 4x sensors for winter wheels
worked 6y for me and i sold car with working sensors
for current car i bought another model ~25 euros, as previous Tuao TY03-2 isn't available anymore
receiver looks exactly same, but sensors aren't compatible to previous receiver,
new have also different pairing logic,
shows last known values,
wakes up with loud beep and has no option to change wheels order
this set works
the next, same looking, i bought full kit for winter wheels to avoid pairing procedure
soldered bigger battery, in other case it asks weekly charge cable in November -> February period
after one year one sensor died, then i bought another kit with same title, but replaced just one dead sensor,
pared to receiver, it shows values, but never changes
receiver looks the same, but new sensors have screws to replace battery
some pictures of different kits
-> https://www.briskoda.net/forums/topic/434028-tire-pressure-monitoring-system/?tab=comments#comment-4893182
1 hour ago, Viorel_92 said:
Hello guys,
Thank you!
98% TPMS antennas from Ali are fake
