Available coding/adaptation mods
On 03/01/2025 at 19:11, MadalinT said:
Anyone knows if there is like an 'advanced' kessy function for mk4? To lock the doors when you're walking away, without having to touch the door handle? ( Just like Renault)
Thank you !
Try this👇
  • Replies 82
  • Views 43.3k
  • Tried coding with VCTool using cheap $3 adpater LM327 V1.5 and it worked great: Bought 3 SFD tokens for 28€ + tax, try entering address not in EU maybe it will not charge you additional 21% ta
  • Dear Santa 🎅   I've waited patiently for my new Octavia mk4 and I've been a good boy all year. I hope you will bring me these "coding/adaptation mods" for christmas (in the following order o
  • No clue about start/stop, but considering that methods used in previous versions are not working and we don't have a dedicated start/stop button to be able to plug a start/stop eliminator harness ...
Hello, this seems to be from another car, I think it is from ID cars, right ? I don’t know if this is supported by Octavia Mk4.
2 hours ago, Pi3truch said:
Try this👇
The above coding is from Coding list Golf 8 by n3oka!
I've tested on My SK O4, pre-facelift version and it's working like a charm!
Cheers!
Cheers!
awesome! Now I just need to find a way to do the sfd unlock , are you from Bucharest ?
On 16/01/2025 at 09:17, Pi3truch said:
Try this👇
That's quite an interesting thing 🙂. Seems that this function is already released as an OBDeleven one click app but essential requirement is needed: ODX version 007001 in control unit A9. @djmartzian are you in a position to confirm?
I am running ODX version 006001 so I am not sure if this will work or not.
@Mario_Delgado, Please find below all the details about 09 - Central Electrics module  where, as mention before, the coding was accepted and the locking upon exit/leaving from the car is indeed working. ☺️
Awesome, thanks a lot for the info @djmartzian, I will take a look tomorrow, but for early versions I would say it's not going to work 😞
Did anyone find single gear display option to be enabled, like on older versions? so the DSG displays D1, D2, etc... instead of just D?
I found this info on FB, but for Golf:
image.png.d4e12eed36f83fb965f1ffa6dc85ee06.pngimage.png.532660353946ff428158e90fce8032ec.png
