No internet connection.
Any one else suffering from the car not having an internet connection? I have tried everything and looked at every ‘privacy setting’.
I even resorted to messaging Skoda UK who even after a few suggestions couldn’t help.
  • Replies 137
  • Views 43.2k
  • Hi.   As I received no reply from the dealer I pulled the fuses this morning. All ok now and back to normal. Greetings from Portugal and thanks for the love for the Costa Vicentina from
  • PrimozAmbrozic
    PrimozAmbrozic
    Good morning,   I try to take out fuse nr. 19 again and wait till SOS went offline (red). I put it back and on start it didn't change anything (garage) then I took a ride around the town and
  • Just tried this and worked for me, App is now updating correctly and Infotainment shows as synchronized
In last few days I got the same message (only the second one) twice. But it seemed everything was working as usual.
My isn’t syncing with the phone app, nor is it allowing me to use the online Satnav functions.
I'm in then same situacion. In the car, the skoda connect icon has been gray for 6 days and the mobile app does not refresh the data.
I wonder if it's a problem with my car or with the skoda connect servers.
Is there anyone with this problem who knows how to fix it?
I have today contacted my local dealer and awaiting a response from technical.
Don't know why I didn't check this earlier, but it looks like my Skoda App synced the car data the last time on 22nd od April. Around the same time when I got this message. So indeed my car doesn't have internet connection.
Same issue, last sync was April 21
On German FB group someone suggested to take out fuses 19 and 30 behind the drawer beside the light switch for 10 minutes.
Edited by TheUltraRunner
A few people confirmed that taking out fuses has fixed this connection issue. If it doesn't help the first time, just repeat the process. Make sure you leave the fuses out for at least 5 minutes until the green light on the SOS button goes out.
Worked here as well!
Yes exactly the same, no internet, same messages, started last week, been in the local dealer twice, both times having claimed "software updates" but has done absolutely nothing.  I have deleted all accounts, apps and data - factory reset - nothing.
Slightly glad I am not in the boat alone.
Thanks for confirming. I'll try that myself later in the day.
After dropping into my local Skoda dealer and speaking to the technician he said it probably just needs a hard reset via OBD.  I would try the fuse suggestion but I Will let them have a go at sorting.
It worked for me too.
Its working, but what happens with trip data? Is it lost?
Currently in myskoda app on my phone all the data, for the period when the car had no internet connection, are missing. I forgot to check the data in the car.
I'm a little scared about remove the storage compartment and taking out the fuses.
I put what I have done to solve the problem, I have already fixed it like this twice
- Remove the car from the mobile app
- In the car restore to factory settings and wait 1 day or until the skoda connect icon changes from gray to white
- Get in the car as the main driver (even if we already are). This is where it will ask for the two keys
- Wait about 10 minutes and add the car again in the mobile app. So the app should work fine and refresh the data
I think removing fuses is much quicker. :blush:
I had the same problem for one week. Today works again, required no action...
Nice to know. :thumbup: Were all trips from the last week sycned with mySkoda app?
At the moment, the app is unstable. Yesterday the last week was synced, but there was no current data. Now is the other way around, have data of yesterday but the rest of the week is gone again.  I expect that all will work eventually...
i am in the same boat now, I did remove fuse nr 30, but did not check SOS if its green or not, fuse was out for couple minutes max.
did not help.
I have removed both, 19 and 30, for 10 minutes.
lets see if that helps, but i am not sure i had nr19 :D
