Bilstein B6
15 hours ago, Gabrielem said:
Do you know sportline springs that are lower than the standard ones? That they are not Eibach because in the end they go down too much ...
Here's a list of standard rear springs (including KYB RA5337) for the Superb MK3 Estate 2.0TDI 4x4 190PS showing that they are sold to replace OEM part number 3Q0511115M
https://www.autodoc.co.uk/car-parts/coil-springs-10213/skoda/superb/superb-estate-3v5/115169-2-0-tdi-4x4?criteria[100][0]=HA
The "VW Online Parts Catalogue" shows that 3Q0511115M is used on the VW Passat 2015 onwards. The VW online parts catalogue only goes up to 2016 so doesn't include the Superb MK3.
Take a look at the following 11 sports springs (lowered 15mm) that are used on the VW Passat 2015 onwards. The list goes from softest to hardest, or weight range 1 to weight range 11.
3Q0511115S
3Q0511115T
3Q0511115AA
3Q0511115AB
3Q0511115AC
3Q0511115AD
3Q0511115BH
3Q0511115AE
3Q0511115AF
3Q0511115AG
3Q0511115BD
However, autodoc don't list any matching aftermarket springs for these 11 sport springs. You could order any of them through a Skoda parts department, but you won't know the specification, other than knowing what the weight range is on the Passat or where that particular spring is in the above hierarchy.
rear axle | Volkswagen Passat/4Motion/Santana 2016, suspension shock absorbers fr.wheel drv
1 3Q0511115AH coil spring
Model data: PR-1JA+0YA
1 3Q0511115AJ coil spring
Model data: PR-1JA+0YB
1 3Q0511115AK coil spring
Model data: PR-1JA+0YC
1 3Q0511115AL coil spring
Model data: PR-1JA+0YD
1 3Q0511115M coil spring
Model data: PR-1JA+0YE
1 3Q0511115N coil spring
Model data: PR-1JA+0YF
1 3Q0511115P coil spring
Model data: PR-1JA+0YG
1 3Q0511115Q coil spring
Model data: PR-1JA+0YH
1 3Q0511115R coil spring
Model data: PR-1JA+0YJ
1 3Q0511115BC coil spring
Model data: PR-1JA+0YK
1 3Q0511115S coil spring
Model data: PR-1JC+0YA
PR-UA0+0YA
1 3Q0511115T coil spring
Model data: PR-1JC+0YB
PR-UA0+0YB
1 3Q0511115AA coil spring
Model data: PR-1JC+0YC
PR-UA0+0YC
1 3Q0511115AB coil spring
Model data: PR-1JC+0YD
PR-UA0+0YD
1 3Q0511115AC coil spring
Model data: PR-1JC+0YE
PR-UA0+0YE
1 3Q0511115AD coil spring
Model data: PR-1JC+0YF
PR-UA0+0YF
1 3Q0511115BH coil spring
Model data: PR-1JC+0YG
PR-UA0+0YG
1 3Q0511115AE coil spring
Model data: PR-1JC+0YH
1 3Q0511115AF coil spring
Model data: PR-1JC+0YJ
1 3Q0511115AG coil spring
Model data: PR-1JC+0YK
1 3Q0511115BD coil spring
Model data: PR-1JC+0YL
1 3Q0511115BG coil spring
Model data: PR-UC7+0YA
1 3Q0511115AN coil spring
Model data: PR-UC7+0YB
1 3Q0511115AP coil spring
Model data: PR-UC7+0YC
1 3Q0511115AQ coil spring
Model data: PR-UC7+0YD
1 3Q0511115AR coil spring
Model data: PR-UC7+0YE
1 3Q0511115AS coil spring
Model data: PR-UC7+0YF
1 3Q0511115AT coil spring
Model data: PR-UC7+0YG
1 3Q0511115BA coil spring
Model data: PR-UC7+0YH
1 3Q0511115BB coil spring
Model data: PR-UC7+0YJ
1 3Q0511115BE coil spring
Model data: PR-UC7+0YK
http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/PA/year/2016/drive_standart/793/hg_ug/511/subcategory/511000/part_id/0/lang/e
VW/Audi/Seat/Škoda Option Codes Decoder
1JA = Rear shock absorption, basic design 1
1JC = Rear shock absorption for sports design
UC7 = Rear shock absorption, chassis with increased ride height
http://igorweb.org/equidec.aspx
Edited by Carlston
  • Replies 86
  • Views 29.8k
  • I fitted B6 a couple of years ago on my 2.0 TDI Combi and I noticed exactly what I wanted: More body control on high speeds but no harshness at all. I was very surprised with that, as I have a Mini R5
  • I already have them at home, only took 4 days to ship from Germany to Barcelona. Due to "reasons" I won't be able to fit them until mid July... can't wait!
  • I p/x my 2013 Octavia Mk 3 for a 2016 Superb Exec.  with 17 inch wheels last May. I was disappointed with the  soft suspension, especially over speed humps. So I purchased Bilstein B6 shocks, and my i
@Carlstonstrikes again!
Mine has "1JP = Rear shock absorption"
....and "G04 = Shock absorption in front"
It has factory DCC, non Sportline.
Edited by JR RS
Mine is the same.
206 kW (280) 4x4 Sportline DCC Wagon
1JP and G04 refer to  models with electronically regulated shock absorber (DCC).
Model numbers differ for the springs, but the part numbers are often the same.
For example,
1JP (DCC): Rear spring PR-1JP-0YD = 3Q0511115AK
1JA (non-DCC, Standard, no Sportline): Rear spring PR-1JA-OYC = 3Q0511115AK
Source:
http://www.catcar.info/audivw/?lang=en&l=c3RzPT17IjEwIjoiQnJhbmQiLCIyMCI6IlNLT0RBIiwiNDAiOiJTdXBlcmIgRXVyb3BlIiwiNTAiOiIyMDE5IiwiNjAiOiJSZWFyIGF4bGUifXx8c3Q9PTYwfHxicmFuZD09c2t8fG1hcmtldD09Q1p8fG1kbD09U1VQICB8fEVwaXM9PTg1MXx8RWluc2F0ej09MjAxOXx8TWFpbkdyb3VwPT01fHxCaWxkdGFmZWw9PTUxMTEwfHxHcmFmaWs9PTA1MTExNTc0Ng%3D%3D
On 26/09/2021 at 17:28, Haystack1 said:
Mine is the same.
@Haystack1 could you take a look at the springs on your car for color codes or actual part numbers? Front springs have painted color codes. Rear springs have paper tags with part numbers printed on them.
  • 3 months later...
Hi All,
I am looking for Bilstein B6 Sports for the front of my 2016 Superb MK III 20 TDI Hatch, I am having difficulty sourcing in Ireland.
If anybody could point me to a dealer even in the UK. I think that part no. is (35-229872)
Thanks.
Try  [email protected]
I have purchased front and rear shocks for both Octavia 3 and my now 2016 Skoda Superb 1.4Tsi Exec.
They are very helpful.
Thanks VAK,
I have just sent off a mail.
Thanks for your help.
Do you know the Lesjofors docks? Are good?
Quick question - is there any difference to the sportline suspension compared to SE-L trim?
Yes the SportLine is 20mm (IIRC) lower
I ask because there's no mention of it in the brochure.
Does that mean the spring rates are also different?
On 17/06/2021 at 16:58, Txmax said:
My car is about to reach 100.000 km, so I just ordered off ebay a set of Bilstein B6 dampers to assemble with the original springs maintaining the original ride height. I'm sick and tired of the bouncy ride specially at high speed roads.
https://www.ebay.es/itm/401530447405
Part numbers are:
35-229872 + 24-229890
Can't wait to have them assemblied!!
Hi there
just joined the superb mk3 with my 2020 2.0 TSI 184bhp saloon version. Am based in Singapore and the car here is right hand drive
may I know what is the bilstein B6 damper part numbers? The current suspension setup is too soft and wallowy
Thank you
Just now, monza said:
Hi there
Thank you
My car is front wheel drive and non DCC fitted.
please advise
  • 4 months later...
A question for those who have gone down the B6 + stock spring route.
When fitting the spring to the damper, did you still have to use the item marked "13" on this diagram, for the bottom of the spring to sit in ?
https://www.lllparts.co.uk/product/shelf/mpn/5Q0412545D
Many thanks!
Many thanks!
Yes!
Cheers, yes already got it in my autodoc basket, just waiting for a day with a better discount!
On 2/7/2022 at 13:22, muddyboots said:
Una pregunta para aquellos que se han ido por la ruta de primavera B6 + stock.
Al colocar el resorte en el amortiguador, ¿todavía tuvo que usar el elemento marcado como "13" en este diagrama para que la parte inferior del resorte se asiente?
¡Muchas gracias!
If you install them, tell us if you lift the body, please.
When my shocks go B6 top of the list for replacements. Can is a standard SE, my priority is comfort, not sportiness.
Can B6 drivers confirm if the comfort has been retained, or has any harshness crept in since swapping?
When I fitted B6s to my octavia with stock springs there was a definite firmness added.  On short low speed journeys it felt more jiggly, particularly when the shocks were cold (this could be cold bushes).  Medium and higher speeds it was definitely more comfortable to the point that I felt fresher after long journeys (compared to stock shocks).  The lowering changed the dynamics once again but that's a separate discussion.
To answer your specific question:  no harshness but a definite firmness.
I fitted them to my Yeti a few years ago, I found them just as comfortable (in fact given the old dampers were knackered and thudded/crashed about - it was a big improvement), but with more body control, exactly what I feel our Superb needs.
I'll let you know in the week when I fit them! But if you are going to get them, be prepared for 6 weeks of waiting... Thats how long it's been for me....
Edited by Dahmich
Typo
