Travel assist retrofit
You need one with a travel assist button top right. It is blank on the SIII steering wheel if it does not have capacitance.
  • Replies 157
  • Views 64.4k
  • Check if all below is done :   Select Driver Assistance A5 - Select Long coding - Select KLR - Set to Coded - Select Point of intervention - Set to Early - Select HC Warn Intensity -
  • East_Yorkshire_Retrofits
    New wheel isn't covered under warranty. Rest of the car should be unaffected    Ensure you replace the bolt that secures the wheel, and torque it correctly. Also ensure you don't mark/damage
  • Update from my last post. It appears I forgot to add the following changes A5 -> Hc_Variante: 2 A5 -> Klr: Enabled. This one will enable capacitivesensors.   Travel ass
I do not have PNs for the steering wheels with touch sensors, but it will be just like your 2 spoke steering wheel WITH the TA button on the right.
What’s with the Plugs when changing the steering wheel? Is there some adaptation needed or just plug and play?
On 21/12/2022 at 15:41, East_Yorkshire_Retrofits said:
No, you'll require a new steering wheel control module/clock spring & additional wiring
The new module will be needed online svm or will work right away?
And the additional wiring you mean the red and brown ones or is something more than that?
I am not sure what "svm" stands for, but plugging it in is plug and play. You just need to code it in later.
Some modules are vin locked so when you replace them you need online acces to code it for your car
But this one look like is not one of them so good
It's possible to enable TravelAssist without button. Need SW module that can reassign Assistance button logic - single press TA, long press - Assistance
