Octavia iV reversing camera retrofit service!
  • Replies 79
  • Views 24.7k
  • East_Yorkshire_Retrofits
    It takes us around 2.5-3 hours    It's a genuine camera, it integrates with the vehicle electronics as if it was factory fit
    You don't have to use an SVM adapation document   It just means if the Canbus gateway or the infotainment unit is returned to the factory configuration by a dealer for any reason then you'll
  • Excellent service from East Yorkshire Retrofits, had my reversing cam done a couple of months ago.
Do you do all around the UK? I live near Guildford.
We're based in Bridlington, East Yorkshire
Hi East Yorkshire,
Can you retrofit a heads up display on my VRS ?
1 hour ago, daveovrs said:
Hi East Yorkshire,
We certainly can, however I've just checked parts prices and the HUD alone is £1280 + VAT, then there's the brackets & fittings + labour. You'd be better trying to get one used and bring it to us
Worth noting you'd also need a replacement windscreen & ideally a replacement dashboard
Edited by East_Yorkshire_Retrofits
Quote
genuine integrated  camera
According to the picture your camera is missing the washed nozzle?
It's a Saloon pictured, there's no rear washer. Estates will have a washer system.
Hmmm also sedans have a washer option. Instead of using a wiper stalk to wash the camera, sedan has an option in the camera menu to initiate the wash.
https://youtu.be/YZ1dUQlu81M
Thats a nice touch
However it's unlikely people would want to pay the additional cost for this as none of the plumbing is in place. Genuine hose isn't cheap 😓
21 hours ago, East_Yorkshire_Retrofits said:
Thats a nice touch
Yeah, good point about the retrofit of the plumbing. I guess you would also need an additional motor/pump?
 I think its connected to the washer nozzle on the wipers. So no extra motor/pump needed.
Correct. But only in case you have the rear wiper. ;)
I’m looking at purchasing a VRS estate that has all the options I want in it except the reversing camera. Is this just a simple install and uses the actual OEM display on the screen when it is active?
Hi Richy59,
To be honest with the reversing camera I personally wouldn’t use it, but if you ask East_Yorkshire_Retrofits they give loads of advice and help. By the way my new VRS Estate is great I love it, I did have MK7 Golf GTD estate and wanted the new MK8 version, but went for the Octavia.
  • 4 months later...
1 minute ago, Avi1407 said:
Do you have both front and rear camera for the 2022 Octavia sedan? If so, how much is it?
Please send us a message with your VIN
Ok, once i finalize the purchase at the dealership by end of this week i will get the VIN from them and send to you
if i get a reversing camera fitted by yourselves would i not lose my warranty?
The camera wouldn't be covered under the manufacturer warranty, it would however be covered by our warranty
sorry what i meant if i got one fitted by yourselves ,would it not make skodas warranty on the car invalid.
Skoda won't invalidate the whole vehicles warranty because the camera is fitted. They'd only invalidate parts which have failed and can be attributed to the camera - which is none, as nothing else is touched.
The camera is a completely independent electrical system that connections to the intended connection points. It connects to a dedicated point on the canbus gateway & a dedicated position in the fusebox
Please find VIN number below, it currently has rear parking sensors only so i was thinking of retrofitting both front and rear caneras to the existing 10" infotainment MIB3 system, is it possible?
Yes it's possible, we've successfully fitted 360° cameras to a Cupra Formentor
Front + rear uses pretty much the same parts but without the cameras in the mirrors
