DCC Slider adjustment option mod
https://www.briskoda.net/forums/topic/535341-dcc-slider-mode/
  • 11 months later...
  • Replies 140
  • Views 49.6k
  • Well that was all surprisingly easy...   Flashed the DCC module:   Uploaded the Passat dataset (closest in size, weight and wheelbase to the Octavia):   I alr
  • Ok, with some serious help it's been done!   Here is the overall sequence of events that was encountered and followed: Original gateway was 5Q0. Most examples seem to use the 3
  • Youre in luck, this is what youre after.   https://www.glaskugelservice.de/codierung/dcc-auf-index-c   https://github.com/jilleb/MQB-FPA     The first link is bringi
Hello new member here.
very interested in the DCC slider mod and would like to get the contact details of Julian if possible.
Have Prokit springs fitted with whiteline sway bar.
coming from a golf mk7R, suspension in superb is disappointing.
cheers
cheers
They're different beasts; Superb is larger MQB-B chassis; longer and heavier. The car isn't a hot hatch and is a Passat equivalent so better at motorway munching with much better interior space.
Whiteline rear arb is good - hopefully on the stiffest setting. I found although the droplinks weren't necessary, you can notice the firmer bushes based in uprated ones.
Yes definitely love the extra space and superb is e beautiful car. Was terrible and looked silly with the original springs, sway bar really fixed the boat feeling. Just like many on here, I drive in normal mode, mostly but find sport the best setting when driving harder. Comfort should be the normal setting, normal, sport setting and then a tighter setting for sport. But yes it’s not a hot hatch, not a golf r, I had the golf r wagon.
Once I had the prokit springs fitted the ride was harsh and felt like it bottomed out over holes etc, luckily I came across this forum and used ob11 to reset suspension settings but yes eager to get the slider mod done.
@DALEB - I'll reach out to Julian for u and see if he's happy for me to give u his contact details.
In the meantime - after lowering it, u should get the DCC Recalibration done, which is easy to do with 4x jack stands and VCDS or OBDeleven.
It will help.
With regards to the DCC Slider Mod - it has made a massive difference to many peeps with the 280 Superb, including mine which is a 220.
For some reason Skoda put the wrong (default.....common) suspension dataset into the Superb, making it boaty, bouncy and bottom out from factory.
The DCC Slider Mod loads the suspension dataset for the Arteon, which is much more composed and responsive.
A must do if u have the means to get it done.
Far far cheaper, and better in my opinion, than APR's current SCU offering.
Edited by JR RS
thanks, yes done the recal and fixed everything, but yes agree on skoda putting the wrong dataset into the suspension.
cheers.
On 16.11.2025 at 12:21, Cairus said:
https://www.briskoda.net/forums/topic/535341- dcc -slider-mode/
All the data required for the mod can normally be found here.
Hi all,
I'm in a similar boat (literally 🤣) and have never been happy with how either of my Superb's have been on DCC.
If there is anyone within a couple of hours of Hampshire/Surrey I'd be more than happy to pay for the time etc.
Any help welcome. Thanks
Does anyone know if the mod can be undertaken on an early 2016 280? I’m sure it’ll need HW and SW changes but I’d really like to have the flexibility the mod gives.
provided u have the 3Q0 gateway and 5Q0 suspension modules.
MIB (infotainment) doesn't matter.
Cheers JR. I have 3Q0 on ABS and 5Q0 on the DCC/Suspension; is that what’s required?
Not ABS.
Need 3Q0 for Gateway.
The Gateway gets parameterized.
The DCC (Suspension) gets a software update.
Nothing is done to the ABS (Brakes) module, for the DCC Mod.
Edited by JR RS
Ahh. Yeah. Good point! 😳
The gateway is a 5Q0 so it’s a no-no then? Could the gateway be changed JR or would this create issues with other systems?
Gateway Change, but it is CP Master, you need a Skoda Partner with odis online
You will need to re-enable the functions; otherwise, certain features will not work. Do not forget the coding and the dataset.
Edited by Cairus
Thanks for this. I don’t know what a “CP Master” is, but with the need to involve a Skoda partner, who’ll no doubt say of course we can do it, it sounds like an expensive and a potentially disaster-filled project, so I’ll swerve it….
