Error: selector lever...
Mine is a Octavia IV (petrol electric) SEL estate 21 plate, unsure on month (second hand purchase) but should be first half of the year. I believe it's NX5 also.
Yes I agree they're annoying but not serious.
It was relatively easy to lift it up using plastic to lift & separate it.
I suspect in the lever, one of the microswitches is stuck, meaning the car knows what position it's in from the others that are triggered but is still hi lighting a problem.
I popped into a dealer today and the parts guy said the selector lever module comes fitted with the trim, (at a substantial cost as previously mentioned earlier in the thred). He did say he'd ask his technical department to get back to me if they know of a way of separating it. I Will let you know if I hear anything. Please let us know if you're able to separate out the module yourself 👍
  • 3 months later...
  • Replies 105
  • Views 76.5k
  • VW released few days ago a firmware update for the transmission.. they installed it in my car and apparently the problem looks to be fixed without replacing the parts.. hope this can be helpful.
  • Very common issue, failure of a microswitch in the selector tower.   A repair kit can be had that replaces just the internal switch with a bolt on external one.    Im assuming your
  • That’s mad! I had that on both my MK3s years ago. Can’t believe it’s not fixed yet.
I have the same exact issue.
Followed up with previous tips from the community, and faced this exact problem. Couldn't separate the silver module, which I suspect must be some computing device.
If anybody has any information on how to deal with this DIY I would highly appreciate it.
  • 4 months later...
On 15/11/2025 at 14:41, Mitchg98 said:
Hi, so I've taken the centre plate out, and unfortunately it's different underneath than what was posted before.
I've unplugged the cables and removed the combined trim / selector module,
I want to see the selector part number as its obscured. As that's likely the problem part.
I've released the 4x plastic tabs on the side, so it wiggles, but it won't fully release from the plastic housing.
It feels like there's something else retaining it, but obviously don't want to force it.
Any suggestions / instructions somone can point me towards please?
Thanks in advance
Hi! I have this newer version as well. Has anyone found a solution to repair this type of selector?
I'm still dealing with the same problem. From time to time the error disappears, but especially in the summers in hot weather it pops up again.
Although there's no significant in the driving or usage, it's just annoying.
I'd love to know how to fix it DIY.
Nothing’s happened these past few days, despite the heatwave. The 37VQ campaign was a blessing.
On 02/06/2025 at 03:41, ChanCW said:
i have a 2022 Octavia 1.5 TSI and for the first time , the selector level error appeared on Saturday when i crack start, i restart the car the error gone and didn't happen anymore on Sunday. My car warranty will end in August and since the error didn't appear again, if after the warranty period, how much would be the cost to self repair it?
I just googled the part number and it costs between £250-350.
Even though it may not show up on the dashboard, it logs the error into the OBD log. This means if you take it to the service station, when they connect a odb2 reader they will be able to see the malfunction.
As your warranty is about to end, I would strongly advise you to visit ASAP.
