Software Update available for Bolero?
On 20/04/2025 at 21:53, Pollocedrone said:
Hi! How did you solve the problem with the USB-C device not being recognized? I have the same firmware as you (MEN3_EU_SK370_P2345L_1790) and I want to update to MEN3_EU_SK370_P3355L_1800, but my 32GB USB-C flash drive is not being recognized...
Initially on my Type C drive of 128GB , I had 1 NTFS drive and 1 FAT32 drive. I had copied firmware folder "MEN3_EU_SK370_P3355L_1800" in FAT32 partition. This had 2 sub foders Data and Meta. With this arrangement it was failing.
So I deleted all other partition, free disk space and kept only 1 partion of exFAT and copied folder "MEN3_EU_SK370_P3355L_1800" on it.
Then i switched off ignition of car and then switched on. Then plugged in my type c device and it worked.
  • Replies 769
  • Views 204.5k
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
Hello, can you please help me?
I have škoda Scala 2019 with this infotainment version.
The car has problems with my phone Motorola edge 50. It is still disconnecting and wrote problem with hfp. The another problem is with radio, sometimes is bad signal, but on another car the signal is ok. And the last problem is after turn off engine and turn on are not showing data about last drive on maxi dot.
Please is possibly resolve it with update infotainment? And is possible install version 1800? By mib-helper the last official version is 1760.
Thank you.
Who knows, but newest SW version for your HW is 742
@PeskyPerson Thank you for response.
I installed the version 742 and now I have to check it will be ok or it is still with some problems.
You wrote that the newest sw version is 742. It means that radio doesn't allow install newest version? Or it is possible but it is possible that it could broke something?
Thank you.
I am so happy that I found this forum. This issue with Android auto is getting me crazy! 😅
I have been through all pages, but I found some conflicting answers, so I'm still unsure if I can upgrade to version 1800. Can anybody help me?
My car has VC (Virtual Cockpit)
Thanks in advance!
Thanks in advance!
I was able to update to 1790 then 1800. But unfortunately still having problems with Android Auto connected to Samsung S24. Any ideias?
I restored the multimedia to factory settings, still having problems. :(
Hey can anyone help me update the mib to the latest version?
My scala has this:
SW: 0469.
Is there a newer version available? And how to get it? I a
m from Poland.
Edited by jack_scala
On 14/05/2025 at 19:20, jack_scala said:
My scala has this:
SW: 0469.
m from Poland.
On 13/10/2023 at 06:55, kuyon said:
AHello, I'm from Slovakia.  I followed this link:
Everything went well.  My goal is to activate the wireless android car after purchasing the official activation key here:
https://eshop.skoda-auto.sk/sk_SK/smartlink-wlan/p/6VA054830B
I requested the activation of wireless WLAN in the official service.
Unfortunately, the activation was unsuccessful after several attempts.  The detected bug is said to be higher installed software 1798.
My car is from 4/2019 and this model has the latest official software 742.
After returning from service I reinstalled my MIB3 unit to version 1760 successfully.
The problem is that after formatting the USB I can't see the 742 software file. I don't understand when I've already successfully installed it once before.
Friends, I need file 742 or older from another source for testing, so that the system in the car can see it on USB and be able to install it.
Can any of you send it to me?
PS:Please note that I tried to change the final letter P to L without success
My source files where the 742 USB software does not see
https://disk.yandex.ru/d/1V1uBTc8ssc3zA
I am sending a picture guide: 1. The USB, when plugged into the car, sees these files without the 742 version.
2. View all files saved on USB on mobile or PC
3. and 4. The picture shows the different installed versions in MIB 3
if I understand correctly, you updated the version on 1798 for car from 2019. And after went back to 742 for some reason. Can you please tell me why.
In another post you wrote that the max version is 742.
I would like ask you, is possible to update higher version than 742? For example 1760 or 1800?
Hi guys, i Have Scala 2022 and this software:
Shoul I just install this from the russian drive?
MEN3 EU SK370 P3355L 1800.7z
ANy chance I could get wireless android auto instead of wired?
Thanks to everybody here.
Upgraded my version from 464->469->761->1790 and I went from 30% change wireless working to 100%.
Thank you so much guys!
On 30/04/2025 at 02:35, Arch1 said:
Can someone give me also a note where to get it?
I think that Software 0472 is the latest version, isn it?
Have you found yet? If not, contact me with same user on IG or website
Hello, I have bought a 2021 Skoda Kamiq and I wanted to update the Bolero system because I have freezes and disconnections. I am posting photos of the system I have and what software you recommend I install, thank you.
  • 5 weeks later...
On 15/03/2023 at 14:48, varooom said:
Private message
My scala has this:
MEN3_EU_SK370_P0265L
strona MIB Solution
Hello,
I have 2020 Kamiq with
MEN3_EU_SK370_P9494P_0464
HW: 040
Could I ask you for files to update to maximum supported firmware?
@varooom maybe you are able to help?
On 07/08/2025 at 10:27, ziolek33 said:
Hello,
HW: 040
Hello,
I also have a Kamiq 2020 HW 040, 654035871B. I managed to upgrade MIB3 from version 464 to 1800.
My procedure: 0464 => 0469 => 0741 => 1790 => 1798 => 1800
Download from OneDrive: MEN3_EU_SK370
Do you have wireless CarPlay/AA activated by a chance?
Hello,
I have a Scala 2020 and my android auto (wired) is not working after getting a new phone (oneplus nord 5).
I read that it may be because my bolero system fw is old.
I checked with mib-helper.
My version is Firmware version: P0113P
According to MiB helper Latest official firmware update is: MEN3_EU_SK370_P1185L
I have the files for P1185L on a FAT32 usb stick.
When i try to do the update nothing happens. The car finds the files on the usb but when i press on it nothing just happens (see video).
Can anybody help? What am i doing wrong?
Follow this guide
Zapyus Media
No image preview
Skoda Scala Multimedya Ekranı Nasıl Güncellenir? [Rehber]
Skoda Scala Multimedya Ekranı Nasıl Güncellenir? Rehberimizde adım adım resimli bir şekilde anlattık. Daha fazlası için web sitemizi ziyaret edin!
On 12/10/2025 at 16:28, Tapsa30 said:
Hello,
i don.t thnik you got the correct firmware.
469 is update to 741+742 - the last official firmware for your hardware.
you are trying to update direct to 1800, a version for different hardware.
Edited by andreiro221
What would be the correct update? I thought what I had is the correct as it was recommended by mib-helper.
Currently what my MIB has is:
SW Train MEN3_EU_SK370_P0113P
MU SW 0469
What was said before: 469 is update to 741+742 - the last official firmware for your hardware.
Ahh, you mean these versions? I will test later.
Recently Browsing 1
