Software Update available for Bolero?
On 26/03/2026 at 16:42, Fluski said:
Hello there everyone! I can't believe I missed this forum for such a long time! Let me know if there's a more appropriate subforum to say hi because I looked but thread look just informative and without replies..
I found this because I was looking to finally update my Scala 2020 bolero infotainment and looks like I'm in the right place? Mind that I missed all of the previous updates, may I jump directly to the latest one? If so, may I ask for it? Thank you and welcome to me 😁
Depends how old is your version, i had to do one in between to go to the 1800.
Edited by CrazySkoda
  • Replies 757
  • Views 183k
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
First of all thanks for the reply, I managed to check that my version in still 0464, I plan to update it next week. So I have all the files but I'd like to know how many folders I have to create before commencing.
I had both versions in their folders on the usb, i had to buy usb c to usb a otg adapter to attach my usb stick.
And after flashing 1st version. I checked that everything is ok. Than proceeded to second, latest version.
So you went from to 0464 to 0469 and then straight to 1800? And yes I already have a usb a usb c adapter.
I went from the bottom one to second and top one is latest(1800) dont know exact version number. (Check image that i posted above)
You can download only two versions SK370:
Ok I'll try as you said and give some feedback when I'm done, thank you very much in the meantime.
No worries, at first update, display stuck black. But after reset it booted and started to do the update.
Let us know how it goes
By reset you mean push for longer time the on/off button or from car scanner( I'm getting a recommended OBD2 scanner next week) And sure, I will let you now. ;)
Edited by Fluski
Yes when i started to update, it supposed to reset screen and start the update, but screen was black for 10 minutes. I forced to reboot by holding the power. (On off button)
Hello to all, i have the following MIB3 Bolero system in my 2021 Skoda Scala.
Can i upgrade the unit to MEN3_EU_SK370_P2345L that i found in MIB Helper?
You can go with P2345L version in between, then to the latest: P3355L (1800)
Cari,
quando inserisco la USB drive sull'ingresso USB e avvio il caricamento del firmware SK370_P0113P mi compare la situazione in foto.
Lì dove è scritto Partly o Nothing, cosa significa?
Nell'attuale software installato in corrispondenza di quelle voci (e ad altre successive) c'è scritto "OK" .
Ho il timore di fare un errore installando il nuovo firmware che potrebbe risultare non completo.
Cosa mi dite?
Grazie.
Edited by CiccioSkoda51
That means that there is no newer version of that part in firmware. Had the same thing when i was updating fw.
You can update without problems!
Skoda scala 2021
version 1540
ive used a 4,8,16g flash drive fat32 in usb a / b
try version 1800 / 1798 / 1790 /1760
but car did not detect update
Edited by llcoolr
27 minutes ago, llcoolr said:
Skoda scala 2021
version 1540
How did you connect it to the car?
hi bro
thx for replay
i used a flash drive usb A and an adapter USB-A/USB-C
also copied some mp3 files on it and it worked well
1 minute ago, llcoolr said:
hi bro
thx for replay
Hi, i think that you need to use USB C OTG adapter instead, 1779038745225499889115722866658.jpg
Yes i did
12 minutes ago, llcoolr said:
Yes i did
Please try to unzip the content from the folder to the root of usb instead?
Check this out if you havent already. Thats the correct steps to update:
https://youtu.be/o0RIdpKQ2b8?is=Yn6CeyB0U3i_uPQ1
do engine need to run to update ?
I dont think so, havent run my engine when updating. But i know that i needed to buy USB OTG, normal usb a to usb c didnt work. Is there difference or it was just bad cable. I dont know. Try other cables or usb drives if you have?
Now worked
So im in 1540
What steps i need to follow according to my unite
P3355L is 1800v and its latest on mibsolution
You can go middle one, and then download the 1800 if you want, or stick to 3225l which is 1798v
Successful update to 1760
Will trst if android auto still have problems
