Auxiliary radiator fan in Felicia, worth it?
3 hours ago, Thefeliciahacker said:
1.3 34% thermal efficiency
1.6 21.2% thermal efficiency
negative thermal efficiency
Something fishy is going on here
That's why it's regulated by a thermostat valve. The radiator often needs to dissipate more heat than the engine produces due to thermal capacity. Also, I have no idea how it's calculated, but it'll dissipate less heat during higher temps/lower speeds.
The diesel is indirect injection with pre-combustion chamber - that means that more heat goes into coolant (and less into exhaust), which is why it has the largest radiator of the three.
  • Replies 92
  • Views 8.2k
  • You have a well designed system functioning perfectly, the thermostat has never even fully opened and yet you wish to add more cooling! A solution looking for a problem.   Adding an addition
  • You already have an electric fan which has enough mass airflow capability to cool a hot but idling engine in city traffic. Been there, done that...
  • Felicia has a big hole under the engine, I could feel hot air coming out of the engine underneath and the car - and that was with the weak motor of the non-ac 1.3. With AC, you have two speed fan, if
It doesn't make sense.
If the 1.6 engine can output at most 40kw of heat energy in the system how come by adding ac you double the heat it will output into the system.
In fact how can it dump more heat than it's nominal power output.
That means it's negative percent efficient.
Obviously all these are based on a delta from ambient at a certain airflow.
That's what I meant. I guess it's something like 20° at 50km/h.
You don't add heat, but you decrease efficiency of the rad by putting hot condenser in front of it.
By accumulating a few kilojoules of heat when it's running without cooling.
This is the front-left
the front-right
and the Inside-right side.
I see an empty space down there, the hose is from the end of the radiator estimated about 8cm plus at least 3 from the other side is 11Cm
From the 1.3 radiator (485mm) to the 1.6 radiator (590mm) we have 105mm (10,5cm) so it may fit even a little bit tight.
It seems that if you moved the radiator to the left, it'd be covered by metal - negating the difference in area.. Only solution would be to route the condenser pipes properly, following the factory installation - which would be probably quite expensive.
@Thefeliciahacker Do you have, by any chance, an installation manual for the Alex AC unit for 1.6/1.9? It'd help to see their solution of the issue.
Edited by Papez
Sadly no but I can ask Alex.
My car has enough space and enough cooling.
Where does the upper pipe go? I can't see it in the photo. But that fan shroud looks nice :)
Enough cooling - there were instances where my Felly didn't have enough cooling (highway, 120kph, uphill, 30°C), even without condenser covering whole rad 😁
Isn't that for the thermostat?
It's the stock.
Edited by D.FYLAKTOS
Also @Papez It's a duct which increases the efficiency of the fan. I found this out when working on a 2.0l Cortina; I changed the cambelt and didn't replace the shroud, with the result that the engine temperature, which had been stable at about 90C, went up and down between 70 and 110C.
I have brand new mahle rad the upper rad hose sits right below the hydro steering reservoir
Yes, it has been mentioned elsewere that removing this plastic duct only makes things worst, the inclinations on the sides makes more incoming air to "hit" the radiator and not lost in turbulances around it.
It's the stock.
I know, I meant its shape, they are often covered with rust 😁
Yes, I know, 1.3 without servo or AC had just fan with a ring around it, which cooled only small portion of the rad.
I meant pipe to the condenser pipes/hoses.
I still had the original rad. It still worked most of the time and I wasn't sure which brand would be a good quality replacement 😁
To install the 1.6 radiator i had to pay a guy to modify the front duct to make it wider and pay a mechanic to modify the condenser pipes to gain few cm. On the other hand some cm will be lost on the other side since car's body metal sheet covers them.
So only few cm (with such a cost) will provide remarkable thermal efficiency to say that the project worth it?
The body shouldn't cover the rad - the plastic shroud on the passenger side is cut away with the 1.6 rad. Unfortunately that's where the condenser pipes are run in your car..
If the cooling is sufficient right now, it's probably not worth it. If you can get a good quality replacement once the original rad loses efficiency, it's not worth either.
Only if you cannot keep the temps in control, it'd be worthy to invest in a larger radiator and all the mods that are needed to fit it. But in that case, I'd jump straight to the 1.9D.
A 3speed fan switch
The 3rd speed activating the extra fan?
That could be okay for D.FYLAKTOS
I don't know if a local car refrigeration technician wants to start such a project (cutitng and diversing pipes etc).
Usually they start the excuses ''don't do it, leave it as is stock, don't mess with modifications, you are looking for trouble'' etc because they don't want to envolved, they prefer the easy tasks which bring them easy money.
The 1.9 hasn't that rectangle plastic duct in front?
I would just do the 3 speed fan mod based on my relay diagram
Our stock fan will work on 3 scales?
No
Our stock and one auxiliary
and one auxiliary
1) The position of the auxiliary is crucial? I mean as we look the radiator left or right? On the right is the stock fan and the auxiliary will push air to him.
2) Will work independently or together with the stock?
On the left passenger side, it can work alongside second speed or with a 3 speed fan switch as the 3rd speed with the 2 others engaged
I thought this auxiliary fan will have one scale only (manually by a switch from the driver) and will be used for harsh traffic situations only.
