How-to Guide to Upgrade MIB2 to MIB2.5
5 minutes ago, Binx1310 said:
Thanks.
I really shouldn't look on ebay. Found a screen unit with a tiny scratch at an absolute bargain price.... so it looks like I'm going ahead with this after all!
I really like mine. I pretty much only use Android Auto so don't miss the physical buttons.
Just make sure you use a good SD card. Pretty sure mine was a fake and didn't have the capacity it claimed so the installation files weren't actually on it.
  • Replies 121
  • Views 41.5k
  • found another feature "unlocked" as a result of the MIB2.5 conversion - Sports (Performance) Monitor!!  woOot normally this only enabled on Sportline models.
  • I forgot to mention in the how-to-guide about the dashboard trim piece that needs to b changed, ideally, though it's not noticeable from the inside the car.... unless u look behind the screen, or thro
  • for the purposes of closure/completeness, the final piece of the puzzle was done - the centre dash trim piece.   So 6 months later after converting my MIB2 unit to a MIB2.5 unit, I finally m
Thanks for the tip. I have various good quality SD cards but they are all micro ones that I use with an adaptor, it seems to have been ok for maps updates, but as this is crucial I am going to buy a new full size San Disk one from Amazon.
I am the same thinking about it, 99% of the time I use Carplay and the steering wheel controls so I dont think I will notice it too much hopefully!
The screen is on its way. Looking at photos it looks to have a different plug. Assuming part numbers and looking at eBay listings it looks like my current 8” screen has the blue plug and the 9.2” has the black plug. I saw on a golf forum about shaving down a bit of the existing plug so it fits. Is that correct, It’s not listed in @JR RS guide.
Edited by Binx1310
Yes, Cutter and 1 Minute Work
Ok great thanks. Glad I’ve not bought an incorrect part!
@Binx1310 - both my 8" Columbus and 9.2" Columbus have the same black connector, so there was no need for me to trim/cut anything - hence not in my how to guide.
Interesting... in both of our Skoda models, kodiaq & Octavia 3, the 8-inch displays have the blue connector, while the 9.2-inch displays have the black one.
Looking at eBay items it looks like it’s part number dependant and the difference between std and high.
Both 8 inch screens that look the same
3v0919606 - black plug - high https://ebay.io/m/mzqBAe
Looks the same as
3v0919605a - blue plug - std https://ebay.io/m/YnuE5m
So looks like mine will be black plug. I was just assuming by how the screen and buttons looked. Didn’t realise there were 2 different part numbers that looked the same from the front!
Looks the same as
they aren't both 8" though? One is 8" and the other has a 6" screen - it has a massive bezel around it.
(also I sold my 3V0919606 for £40 on eBay so you can still get something for them)
Edited by nick6262
Well now I look dumb! Thats what I get for posting late at night from my phone!
Thats good to know on the resale. I've got a few bits on eBay currently that are the spares from my upgrades but they don't seem to be selling, even though I have undercut all the breaker's prices! Will be listing the screen and the trim piece too.
Hmm I appear to be stuck. It’s on this screen with the new 9.2” screen plugged in but I press skip and nothing happens. Almost as it the touchscreen doesn’t work. I don’t know whether to turn it off or what! I’ve tried unplugging and replugging in the screen. Nothing.
Any help? @Cairus ?
Hmm. While I was sat here contemplating my life choices. And about to pull the fuse to get it to retry. It went blank. And then rebooted. But back to the same screen. And I still can’t press skip.
Bad touchscreen?
I think it must be bad touchscreen. Contemplating ordering another from eBay. But now it won’t turn off! I’ve locked car and stood outside and the screen is still on and the fans still whirring. FFS why do I insist on fiddling!
Long press on the power button, screen will go dark and then keep pressing to reset.
I felt exactly the same when I messed mine up. There are many helpful people in the telegram group that can advise if still wonky.
Edited by nick6262
Done that. It boots back to the same place.
Right. After 15 minutes or so it did actually turn off with the car locked. And it booted back up to the same place so I think it will be safe to leave it.
I think I’m going to call it a night and order another screen and get a refund on this one. Maybe there was a reason this one was so cheap…
Edited by Binx1310
New screen should be delivered later today. Car was critically low on voltage so that may have also had an impact. All packages got an OK after installing and the log file on the SD card states all partitions etc completed succesfully. So I am hoping it was a voltage and/or screen issue. I ended up pulling the fuse for the radio as MIB unit was stuck at this point and draining the battery. Car now recharged to 98% SOC and I have bought a higher amp charger! Will make sure car is well charged before recommencing the task.
I have been in touch with @pab567 as the resident MIB expert and he is confident that it can be recovered if theres no improvement on the new screen!
Pg 8 of my how-to-guide says to make sure the car is connected to a battery charger prior to commencing with the firmware install!!
Anyways, all the best with the final few steps and that it successfully completes.
I did! Turns out it was a rubbish charger! And/or my car was already quite low on charge!
Unfortunately after an evening spent connected to @pab567 we had no luck. Cannot read or write to EEPROM so it’s being sent to him to repair on the bench. Fingers crossed it’s relatively straight forward.
I wrote a guide for connecting by UART should anyone need it in future.
Well it turns out my MIB is completely bricked. No hope of repair. Not entirely sure what went wrong. As far as I can tell all instructions were followed. Only thing possibly is battery was low but it didn’t cut out the MiB unit at all during the flash but fiddling about working out what to do when it stopped did drain the battery right down.
So a replaced plug and play mib2.5 unit is now being prepared and hopefully will get me back up to full speed.
