Intelligent Octopus Go
On 05/11/2025 at 09:09, skier1066 said:
Any thoughts before I call Octopus again ?
Hi Scott,
Apologies for the late response, how are you getting on with your charging?
I have suffered with all of your issues but once IOG was linked to the car have not had any problems.
This is my process:
Ensure all schedules are deleted in the car and the Hypervolt.
Set up a home charging location in the car and make sure you have not enabled privacy mode and are sharing the location data.
Set car to not unlock cable after charging. Also check you have a cellular connection in the car at your charging location.
  1. Unlock HV3 and ensure it’s set to plug and charge
  2. Set car to charge immediately
  3. Plug the Elroq in and wait for the green light
  4. Reach in to the car and pause the charge on the infotainment screen (note don’t sit in or put weight on the seat
  5. Open the Octopus app and devices tab, car should now show as plugged in (but can take a few minutes to display and create a schedule). Refreshing the page by pulling down the phone screen can help.
  6. Lock car and walk away. Don’t open the MyŚkoda or HV app during the charging.
I find the above works well for me and hopefully this will help if you are having trouble?
HI Steve,
A wee update as of last night, I have had my second successful IOG charge, including a schedule with multiple stops and starts.
I stood out one night and watched exactly what happened when the charges failed. What brought about success for me was the following in the Hypervolt app, settings, charger settings : Random start disabled.
now I have the Elroq vRS connected to Octopus IOG as an Elroq 85 24
Hypervolt Pro in plug and charge mode, which happened automatically for me when I deleted it from the Octopus app.
Set up required charge to amount in Octopus app
I have noticed that when I plug in the car, the car will start to charge immediately (saw your workaround to that), so far, I have just left it charging.
The Octopus app doesn't see the car as plugged in for roughly 3 - 4 minutes, but does eventually 'sense' the car.
I believe once the car is seen by the Octopus app the car stops the immediate charging.
Then a few minutes later, the schedule eventually appears.
Car charges as necessary with stops and starts and changes as per the IOG schedule.
To summarize, I removed the Hypervolt from the Octopus app added the Elroq 85 24, disabled Random start in the Hypervolt 3 pro app and added the Generic 7Kwh charger in theOctopus app.
fingers crossed it continues to work (albeit with a few extra minutes at 28p)
Appreciate all the help
Scott
@skier1066 Ah I forgot about the HV random start, mine was already disabled from new but had read elsewhere that it confused IOG. I gather it’s there by UK legislation and may be a requirement to be enabled in the future, though IOG does this itself currently and also throttles charge power to balance the grid.
Glad you are now charging successfully, now enjoy your lovely vRS
  • 9 months later...
I am now very nearly into 1 year ownership. Love the car but completely ****ed off with the IOG charging issue. The car can't cope with multiple charging sessions. You constantly have to unplug and put it back in. A few times I've just had to use boost charge but that is a lot more expensive and defeats the object of having intelligent go. I've lost the will to live now trying to fix it.
I’m using OVO charge anytime and it works absolutely seamlessly with my Elroq. I believe it’s maybe more expensive than octopus iog but it actually works and there was a 3 year offer of 10,000 miles per annum of free charging with VW group vehicles when I got the car last year.
The OVO system is not tied to 0001 to 0700 or anything either, you set the app for the time you want and the level of charge and plug in.
Cheers for that I'll have a look into it🤞
Have you set the charge cable Auto Unlock to off? This is the critical step that most miss.
You can change it in the MyŠkoda app:
Battery range/settings (cog top right)/slider “Auto-unlock AC cable”
Edited by Steve153
Just to add, the OVO app is linked to the car in my case. It can control either the car or your charger depending on what is compatible. In my case my charger, which is a podpoint from 2021 is not compatible, but the car is. I’ve removed all schedules from the podpoint app and set it in “dumb, always on” mode. When I plug in, the car will usually immediately charge for a couple of minutes in which time the OVO app is working out how best (for them I presume) to do the rest of the charging to be ready for my requested time. It then pauses the charge and will charge as required to be ready in time. I work shifts with times that vary every day so I often alter the “ready by” time and it has always worked as expected. The only thing to ever check is that the max charge setting of the car is the same as the maximum setting in the OVO app.
Good luck.
Edited by classic
Grammar
