Penultimate Sportline-a-like upgrade.
8mm black trim strip added to the the lower door trim.
https://a.aliexpress.com/_EISPHpy
OEM has a recess so would have had to change entire colour matched lower trim piece to get a completely stocked look. Yet again @JR RS leads the way with adding an external trim strip to achieve the same effect.
Just the roof rails to change now for the full black out of chrome.
  • Replies 66
  • Views 5.4k
  • Part 2 The car was originally supplied with a pump and goo repair kit. The goo was now out of date and I travel quite a bit for work so it makes me nervous not having a spare. I was keen on having a
  • Binx1310
    Binx1310
    Now fitted on the car and much better clean look I was after.
  • Binx1310
    Binx1310
    A couple of jobs done today. Replaced the drivers door inner seal as the original one had worn from driver getting in and out. The second hand one I got from eBay had a little wear but hadn’t split s
Replaced the drivers door inner seal as the original one had worn from driver getting in and out. The second hand one I got from eBay had a little wear but hadn’t split so I just rotated it about 45 degrees so the wear was on the back edge where it won’t wear any more. Pretty simple fit, you just have to take a couple of trim pieces off.
As I had already had some of the trim off and it was finally a sunny afternoon I thought I would tackle installing the black roof rails. Thanks to @Kosin for the install tips. Pretty much remove anything attached to headliner around the edges, all pillar trims and top boot trims. To remove the sun visors and handles you need the OEM/Laser long nose flat pliers at £60 to £30. Luckily Ali express to the rescue again with a cheap tool that does the job perfectly for £3
https://a.aliexpress.com/_EHRShvy
To access the rear of the front pair of bolts you have to disconnect the plug from the curtain airbag igniter. Not too much bother with the battery disconnected and an appropriate wait time to make sure everything is powered down. Apart from when I had fully reinstalled the liner and trims and got an airbag error warning and realised I had forgotten to reconnect the passenger side! Doh! So that half all got disassembled again to reconnect it. Now all done everything back in its place and all fault codes cleared with no issue. All in about 3hrs work. It would have been 2.5 without my airbag mistake!
So that’s the last of the dechrome jobs done and now full Sportline-ish exterior spec (apart from wheels and stance both of which are outside the budget for now!)
Edited by Binx1310
Good Job
That looks Very smart, the roof rails do make such an impact, I’m still waiting on my first delivery from AliExpress to turn up,,, the 2nd one has just left the factory….. now I’ve had to make a 3rd one to get the little tool Widgety thing as I’m gonna need it to run the rear dash cam cable to the back when I actually get a chance to work on the car 🤪
I ran reversing camera the low route along side trim which was pretty straight forward. If you want to go along the top I reckon if you just take off pillar trims and release liner from the door seals there is enough play to tuck a small cable in without removing all the bits that keep the headliner in place. Just need to be mindful to topic it behind the curtain airbags.
I’ve got all the manuals and the interior one describes how to remove all the trim. if you want access I can send you the link.
Also this is a great guide. https://www.briskoda.net/forums/topic/491232-front-and-rear-dashcam-installation/
The only thing I would say is I’ve seen on another post where someone made a little bracket where their rear dashcam mounted to the back wedge of the headliner so it saved you having to run cables into the boot door.
Changed the front brake discs and pads this morning to try and finally cure the brake wobble. Seems ok so far but let’s give it 200 miles or so to reappear like it did before. All went without drama using the excellent @Bap33 guide Here.
I also swapped back to my standard wheel without paddles. For the small amount of instances that I used the paddles I would rather have an airbag that fits properly!
Today I started the blind spot detection project. Trying out a basic AliExpress kit for £50 rather than OEM for £500.
Bumper is a pain to remove thanks to two awkwardly angled torx screws under the wheel arch which requires the car jacked up to access.
First problem after that was that the OEM radar brackets I bought from eBay to make mounting the radars easier didn’t fit. Turns out I had bought hatchback ones rather than estate so they didn’t fit!
A bit of fettling and the brackets that came with the kit were made to fit, mounted onto one of the studs that holds the plastic trim on. All set to the correct angle.
Cables routed into the car through a couple of grommets. Bumper back on and that’s the first step done.
Edited by Binx1310
Got the blind spot project to 95% complete this afternoon. All wires run in and loomed up to protect them.
Boot trim came out to run cables and all power and indicator lights connected up and all working well.
Not the most elegant finish just yet but this is proof of concept stage.
Final bits to finish this bit is to tap in to the rear light feeds so the BSD indicators flash at you if you are indicating whilst something is in your blind spot. Just waiting on some posi taps to come for the connection points.
Then if I’m happy with how it operates , next step is some experiments with the multimeter to check how the standard LEDs operate and then see if they will run the OEM BSD indicator LEDs. If they do then wires will be run in to the doors and OEM LEDs installed in the mirror housings so that it looks standard.
it would have taken me ages to do a job like this,, as soon as id have got the rear bumper off id have been side tracked into cleaning all the hidden white-ish panels ,,, i get easily distra,,, ooh squirrel !!!!
Ha yeah. I knocked off the caked on mud in the back of the bumper but that was about it. I’ve never massively been in to the cleaning part of car ownership. Would rather pay someone else to do it. But if there’s something to take apart and put back together I’m there!
Final connections made on the aftermarket blind spot detection kit this evening. All working well as intended. Next step is to experiment with OEM LEDs to see if I can make them work.
This evenings task was to get out the cardboard spray booth again. This time painting parking sensors for the front sensor retrofit project.
I used the punch for the bumper to cut holes in a small cardboard box and taped them in place as an easier way of masking up the sensors.
The loom has also arrived but is missing the 18 pin plug and is for LHD so some wires also need extending.
Today’s task was to add LED lights to the back doors in place of the reflectors.
Using information from this post.
Lights - https://a.aliexpress.com/_EjjRwBg
Wiring - https://a.aliexpress.com/_EzQJ6DU
Small Posi taps - https://a.aliexpress.com/_EIUKgwe
Large posi taps - https://amzn.eu/d/00FkY8MK
Tapped into red and white/ brown and yellow wires using posi taps and tidied up with cloth tape.
They project “Superb” onto the floor the same as the front ones. Will get a picture this evening in the dark.
Note - it’s always worth having some spare door trim clips on hand as they seem to be a sacrificial part!
https://vehicleclips.co.uk/products/door-card-trim-moulding-clip-with-rubber-seal-skoda-5j0867276
Why not do it properly at the control unit connector by building a Y-adapter?
For me, this solution is unacceptable.
Edited by Cairus
I’m ok with it. I know there’s no tension on the wires, it’s insulated and it’s reversible.
Recently Browsing 2
